Question about Chi Mei Corporation CMV-946D/A 19" Monitor
My text is blurry even after using auto-adjust and reset. How can I correct it?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 30 Answers
You have to play around with the color, black and white settings. Google it for a more exact answer
Posted on Aug 30, 2010
I have a lap top plugged into the monitor and the display is blurry. How to I make it clear
Doreen, try going into display settings and make changes there, veiw changes if you find better choose ti.
Feb 16, 2016 | Princeton Digital VL1916 19" LCD Monitor
Samsung 55" blurry picture and words are blurry...netflix comes in perfect...whats wrong
Is it a 3D TV. Try changing the refresh rate in the Picture Menu 60HZ is normally the standard but try others. Or if you're TV has Auto Motion Plus options you try turn it on it can be found in your television's menu under Picture Options. The Auto Motion Plus menu contains several options, including On, Off, Clear, Smooth and Standard. If changing your Auto Motion Plus options doesn't correct blur, call Samsung.
Jan 24, 2015 | Samsung Televison & Video
Toshiba Satellite C55-A text is blurry when on the internet
Is it windows 7 or 8? Internet Explorer modern (tablet mode), or desktop mode (the one that opens while on your desktop)? Internet Explorer 10 or 11? Ia the text very large or small? Does it only happen in Internet Explorer, or does text appear blurry in other apps? Are those apps desktop mode or tablet mode apps?
Nov 17, 2013 | Toshiba Satellite Computers & Internet
My Fuji 5000 is not performing like it used to on action shots - even when on auto mode. The blurriness is terrible and all my shots have the blurred look unless the subjects stand still.
Have you gone to the manual? It might be the film speed setting is too low which is adjusted through the menu button. If my memory is correct it would be in the setup mode. If you haven't already checked this, the higher the speed the better the action shots.
Nov 09, 2009 | Fuji FinePix S5000 Digital Camera
I have a Dell monitor and the text is blurry and fuzzy, how do I fix this?
this is actually from dell support website.. hope it will correct your problem...
1 Ensure the correct resolution is set for the monitor. Flat panel monitors display the sharpest, clearest images when set to their optimal resolution. Sometimes games and other programs will change the resolution then fail to set it back once they are closed. This will then make the desktop look big, distorted, and grainy. Perform the following steps to adjust the resolution:
  1. Right-click an empty area of the desktop, and then click Properties. (Or, click Start, click Control Panel, and then double-click Display.)
  2. In the Display Properties window, click the Settings tab.
  3. Under Screen resolution, move the slider to the desired setting. For most flat panels the optimal setting will be all the way to the right.
  4. Click Apply, and then click OK.
  5. If prompted, restart the computer.
NOTE: If the resolution will not adjust to the appropriate settings, the video driver may need to be reinstalled or updated.
2 Ensure the screen is clean. Finger prints and smudges will make the screen look blurry. Clean the screen with a soft lint free cloth. If needed, dampen the cloth with warm water or use a LCD cleaning kit that can be purchased from most electronics stores.
3 Use the On Screen Display (OSD) on the monitor to select the Auto Adjust feature. Selecting this will synch the video signal and can sharpen the video image.
4 Reseat the video signal cable to ensure a secure connection.
5 Use the On Screen Display (OSD) on the monitor to select the Factory Reset feature.
6 Test the monitor on another computer or test another monitor on this computer. If available, testing different hardware will isolate if the problem stays with the computer or monitor
Sep 12, 2009 | Gateway FPD2275W LCD Monitor
Ricoh CL7000 text is blurry/fuzzy
probably only when printing in colour? Black only, is ok right?
It needs to have it's line adjustment procedure done. This is a series of complicated trial and error adjustments performed in service mode that the individual colours are adjusted based on printouts generated by the printer. Can only be adjusted by a service tech with experience with this adjustment.
Jul 11, 2009 | Ricoh Office Equipment & Supplies
RCA model DRC8335 Loosing the date and time
That will be a problem from the text side of the broadcast, the clock is set from the text transmission, ( in other words a problem from the transmitter ) possibly due to digital switchover or work on the transmitters. One possible solution would be to turn off auto clock setting, and/or auto summer time adjustment.
May 16, 2009 | RCA DRC8295 DVD Recorder/VCR Combo
53HS10
You probably just have dust build up on the lenses. You can remove the lower back (with the set unplugged) and once you have that done you now have access to clean the lenses using a soft cloth and wipe them down. Don't adjust the lenses as you will spend more time correcting a problem that you create by doing so. Good luck..
Dec 06, 2007 | Sony KP-53HS10 TV
Standard TV - text is blurry
on the flyback transformer it has two controls one is a focus control should be able to adj. this and take care of it.
Nov 26, 2007 | Zenith SY2772DT TV
Chi Mei Corporation CMV-946D/A 19" Monitor Logo
178 people viewed this question
Top Chi Mei Corporation Computers & Internet Experts
giarcnameloc
Level 1 Expert
Jax Planet
Jax Planet
Are you a Chi Mei Corporation Computer and Internet Expert? Answer questions, earn points and help others
