Question about E-Machines eMachines Desktop PC
Got a machine but it keeps switching off after few minutes could it be power switch on front if so where can i get one
    President:
  • 635 Answers
It isnt the power switch, it's the power supply itself. You need to get a new one from bestbuy.com, Tigerdirect.com or Geeks.com.
Emachines are notorious for their bad power supplies, and they usually burn out the motherboard when they die. Stop pushing that button and get a new Power supply before your board messes up.
Posted on Aug 30, 2010
FIXYA The power supply output of my Dell Dimension 8200 desktop pc is delayed for minutes after i press the ON button in the tower front. The momentary button switch is OK. The delay is 15 minutes if
It's not about the switch, a problem may be caused by bad power management control driven by XP. Ask on DELL's forum about any patches about this. Finally, check-up your power management scheme.
PC Servis Kompjutera Kod FONTANE Popravka Odrzavanje Laptop Racunara
Mar 06, 2014 | Dell Computers & Internet
Maytag front loader 2000 series code LF followed instructions in manual and has no power. Outlet works
Hi, is this a new washing machine? If not, then these Maytag front loading washing machines use a paraffin locking switch in the front panel to lock the door during operation. Now, if the switch has gone south and trip the the lock switch without locking the door. Then the washing machine want turn on.
What is a parfin locking switch work is a small container with paraffin (wax) in it with a heater. When the washing machine is turn on. The control board indicate that the machine is in operation and a small amount of current is applied to the paraffin switch to the heating element. This make the parfin to expand trip the locking mechanism and locking door during operation. Keep the door lock from accidental openings. It will take about 4 minute after the washing machine has quite it running operation to open the front loader door. The paraffin needs to cool down to release the locking mechanism. stewbison
Aug 20, 2011 | Washing Machines
Washer keeps shutting down after running for a few minutes
Check the program controller unit, check if there is any loose connection to the wiring to the controller, the relay or the motor and the power plug.
When the machine shuts down then check on the power to the unit , check the door switches, the sensors , in case there is a false alarm..
Jun 14, 2011 | Kenmore Elite 45986 Front Load Washer
My Brother MFC-8680dn keeps giving me a "Print Unable 72" error message. Any ideas how to fix?
According to Brother Solution Center:
The machine may not work properly because of the condensation inside of the machine caused by a temperature differential between the inside and the outside of the machine.
To clear the error message please follow the steps below:
  1. Keep the machine's power on and open the front cover.
  2. Leave the front cover open for 30 minutes.
  3. Close the front cover.
  4. Turn off the machine's power switch and turn it on again.
If you are satisfied, please rate or/and leave a testimonial. Thanks!
May 09, 2011 | Brother Office Equipment & Supplies
Dell all in one 942 ink jet printer reads "clear paper jam" there is no paper stuck. How do I fix?
Try this; Remove the cartridges, disconnect the usb cable, turn off the machine, unplug the power chord and switch off the adaptor from the wall switch, leave the machine for few minutes while you do some cleaning, like cartridges contact points, clean the rear panel door, also open the front panel door and check for any foreign particles, you should remember that even a small/tiny piece of thread or hair can create this problem. Now connect the power chord, switch on the wall switch, and power on the printer without the cartridges installed and the usb cable connected. Use the Power Button the switch on the printer. Leave it Switched On for few minutes and again turn it off, install the cartridges, connect the usb cable and again reboot the unit. Press the power button once and again keep pressing when it starts booting. If the problem still persists, your printer needs service.
Good luck.
Thanks for using FixYa.
Jun 20, 2010 | Dell 942 All-In-One InkJet Printer
Washing machine starts then stopps after a few minutes if you push on the door and hold it the machine will start again but once the door is released it stops machine is a front loader .
Safety switch on the door itself is possibly bad. This isn't an easy fix due to the location of the switch. Good Luck hope this helped some
Dave
Oct 27, 2009 | Washing Machines
Hi, my switch keeps going around and around without stopping
Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
regards
Michelle
Jan 24, 2009 | Indesit W 123 Front Load Washer
Washing machine
usually switching off at the mains and the machine and waiting for a few minutes should do it. Make sure the programme select dial is at the correct position. Have you tried emptying out the water first? (either by putting it on a spin cycle or physically removing the outlet hose from the pump and catching the water in a basin or bucket)
Mar 23, 2008 | Washing Machines
Water dispenser keeps running
Allen, one of two things here. The dispenser target switch has gone bad or the actuator arm is not releasing the switch. Remove the front cover by using a small screw driver to unlock the tabs at the bottom. Slide the panel down and out. Disconnect the wire harness. Remove the 4 phillip screws in the door dispenser housing. Slide the housing out and disconnect the target switch and light connectors. Now you can spread out the locking tabs and examine the switch. If this all checks good, then the board is the problem...Catriver...post back.
Dec 11, 2006 | Hotpoint HSS25GFP Side by Side...
E-Machines eMachines Desktop PC Logo
54 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
