Question about Sony Cyber-Shot DSC-W220/B Digital Camera
How do I change my timer from a 10 second wait to less
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 30 Answers
Some sony cameras only let you have factory settings. im guessing your has it because when you go to the menu, it should let you change it
Posted on Aug 30, 2010
My bathroom heater shuts off after it's on for less than a minute. After a 10 minute wait, a click can be heard and it can be restarted. But only for another 45 seconds
The click sound is the thermostat. It closed and the allows power to the fan heater. The thermostat is faulty and won't allow you to select a higher heat setting.
Jan 19, 2012 | Broan-NuTone Dryers
I lost all power in a 2005 Trailblazer. Called GM and they said to kick the key forward and wait 10 min, and this would reset it. It did but now the radio A/C door locks and windows don't work. What...
Do it three times in a row.
1. Perform a security system relearn.
2. Let the vehicle sit for more than 10 minutes with the key off.
3. Attempt to start the engine, leave the key in the run position monitoring the security system indicator.
4. After 10 minutes, the security indicator will change state.
5. Turn the key off and wait 10 seconds.
6. Attempt to start the engine. If the engine stalls, wait another 10 minutes with the key on.
7. After the second 10 minute timer has expired, turn the key off for 10 seconds.
8. Attempt to start the engine. If the engine stalls, wait another 10 minutes with the key on.
9. After the 3rd 10 minute timer has expired, shut the key off for 10 seconds.
10. The security system will relearn on the 4th starting attempt and the engine should start and run.
Here is a link about the security problem
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Aug 12, 2011 | Chevrolet TrailBlazer Cars & Trucks
How to rekey a pontiac sunfire 2004
Im assuming you are refering to the anti theft security key relearn process.
If that doesnt work, look into this link http://vatspasslockpasskeysecurityhelp.yolasite.com/
Aug 07, 2011 | 2004 Pontiac Sunfire
Programing a key fob
If this doesnt work, you may have a failure in your system. If the security light is on, and the reprogram doesnt work, you might want to look into bypassing that antitheft system.
Aug 06, 2011 | Oldsmobile Alero Cars & Trucks
How to reprogram key
If this doesnt work, and you are having STARTING issues, go to this link.
Jul 29, 2011 | 2005 Pontiac Grand Prix
I need the manual of breil milano shosholoza.the model is bw0480
The crown has 3 positions.
Normal screwed down.
First pull out position.
Second pull out position.
Setting the Time:
Pull out the crown to position 3.
Rotate the crown to set the exact time.
Ensure that you are in the daytime12 hour segment by allowing the hands to pass 12 o'clock and notice if the date moved on or not.
If the date changed, then you will need to advance at least 2 hours before moving on to set the date.
If you do not need to change the date, return the crown to position 1.
Setting the Date:
DO NOT DO THIS IF THE WATCH IS BETWEEN 8pm & 2am
Pull crown to position 2.
Rotate the crown clockwise to set to the correct date.
Return the crown to position 1.
Setting the Alarm [12 hour]
Pull the crown to position 2.
Rotate the crown anti clockwise to move the alarm hand to the desired time.
To activate the alarm, press the 8 o'clock button. You will hear 2 beeps.
To deactivate the alarm, press the 8 o'clock button. You will hear 1 beep.
NB If the alarm is not cancelled while it sounds the first time, it will repeat again in 2 minutes time. The alarm sound last for 15 seconds. If the alarm time coincides with 1 beep of the countdown, the alarm function will be cancelled.
Battery EOL [End Of Life]
The Swiss ISA 8270 movement uses a 395 cell and will signify a low power state by advancing the small seconds hand 4 steps every 4 seconds.
Setting the Countdown
You can specify a countdown of between 1 and 10 minutes.
Press the 4 o'clock button to enter setting mode. You will hear 1 beep.
Press the 4 o'clock button to move the central timing hand successively to the desired countdown time.
Wait 3 seconds for the watch to automatically exit the setting mode.
You can change the duration of the countdown [except in the last minute] at any time.
e.g. If the countdown is set to 10minutes, and you now want to change the countdown to 9 minutes, press the 4 o'clock button. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing.
Activating the Countdown:
Press the 2 o'clock button to start the countdown. You will hear 2 beeps.
When the countdown begins, the hour/seconds counter sub-dial indicates the seconds with 1 step every 2 seconds, and the central timing hand indicates the minutes with 1 step being 2.4 seconds.
Countdown tone:
There are 2 beeps every minute.
in the last minute:
50 seconds=1 beep.
40 seconds=1 beep.
30 seconds=2 beeps.
20 seconds=2 beeps.
10 seconds and less=1 beep every second with zero being 1 second long beep. Timer function automatically starts.
Timer:
After countdown has finished the timer starts automatically.
The central timing hand indicates the minutes with 1 step every 12 seconds. The hour/minutes counter sub-dial indicates the hours up to a maximum of 96.
Press the 4 o'clock button to see the timer seconds [display lasts up to a minute].
Press the 4 o'clock button to see the timer hours.
The timer has a maximum time of 96 hours [4 days] after which the hour/seconds sub-dial counter will stay at 0 and the central timing hand will stay at 12.
Start/Stop Timer:
Press the 2 o'clock button to stop the timer. You will hear 1 beep.
Press the 2 o'clock button to resume the timer. You will hear 2 beeps.
Setting the Countdown & Timer:
Countdown reset:
Press the 2 o'clock button to stop the countdown. You will hear 1 beep.
Press the 4 o'clock button to reset.
Setting the Timer:
Press the 2 o'clock button to stop the timer. The hour/seconds counter sub-dial will show the elapsed hours and the central timing hand the elapsed minutes.
Press the 4 o'clock button to view the seconds elapsed on the hour/seconds counter sub-dial.
Resetting the Hands:
If the hands do not zero correctly, which might occur after a battery change or a violent shock, you can make adjustments by doing the following settings as long as the countdown is not in operation.
To correct the hour/seconds counter sub-dial, pull the crown out to position 2 and wait 1 second.
Press either the 2 or 4 o'clock button; the central timing hand will turn and stop [not necessarily at 12].
Press the 2 o'clock button to increment the hours/seconds counter sub-dial hand to position it at 60.
To correct the central timing hand, press the 4 o'clock button to increment the hand to the 12 position.
If the battery had been replaced, the central timing hand defaults to the 10 minute position. If the battery had not been replaced, the central timing hand will return to the previously set position.
Oct 05, 2010 | Watches
Chevrolet cavalier 1996 mod.cannot start the car security system light on
u have to reset the PC car
first step .. try to start the car ,, and sure it will not start and the thefth system light will turuned on
soo keep the switch opened until the thefth system light stop .. it will take 10-15 min
switch it off for 10 seconds
again switch it on but without starting the car .. and wait for 10 min "not less than 10 mins,, if little more no problem" .. do the same thing one more time ..
finally switch it off .. wait for 10 seconds and start the car ..
Oct 03, 2010 | 1996 Chevrolet Cavalier
Blinking Timer Light
Relay or capacitor on or by the power supply
Jul 08, 2009 | Pioneer DV-285-S DVD Player
Canon Powershot S3 IS self timer problem
Press the 'drive mode' button to the left of the shutter button on top of the camera until you see a clockface icon with a 2, 10 or C in the upper center of the LCD (2 second delay, 10 second delay, or custom setting from menu).
Apr 13, 2008 | Canon PowerShot A520 Digital Camera
Sony Cyber-Shot DSC-W220/B Digital Camera Logo
18 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
