Question about Hamilton Beach BrewStation 47224 Coffee Maker
Brews for about 10 secounds have to turn of an turn back on a few times just to get a pot of coffie
    President:
  • 2,702 Answers
This sounds like a thermostat fault to me,,check that part out first
Posted on Aug 30, 2010
Why won't my bunn coffee maker turn on
You should check to insure that the tank inside the machine is full of water. Pour in 1 pot of water at a time until you get water to come out of the brew basket. If you haven't done any internal damage it should be ready to brew a pot of coffee inabout 20 minutes.
Sep 21, 2014 | Bunn 10 Cup Home Coffee Brewer
How can I fix my coffee maker when the water resovior will not drain?
Try cleaning it by brewing a 50/50 mixture of white vinegar and water. You may have to run it through a couple of cycles with a fresh mixture each time. Then rinse by brewing water only a couple of times. Over time calcium and lime builds up inside the tubes of the machine and restricts the flow so this should be done once every few months or as needed. The vinegar will loosen the mineral deposits and flush them out.
Jun 01, 2014 | Cuisinart Grind and Brew 10 Cup Coffee...
Cleaning coffie pot
You can run a cup of vinegar through a brewing cycle.
This will clean everything. a particularly dirty machine run through twice. Just be sure to run clean water through a couple times to rinse any vinegar residue out of the machine. It will be like new again.
good luck!
Apr 03, 2014 | Chefmate Cm-1250 Coffee Makers
This coffee maker (10 c maker with grinder) beeps it's done every few minutes with water left. we have to brew about 5 times for a full pot, what gives?
Presume this is the Grind & Brew Thermal™ 10-Cup Automatic Coffeemaker, Model # DGB-600BCC
An instruction booklet is available here: http://www.cuisinart.ca/pdf/ibs/en/DGB-600BCC_en.pdf
Review the sections beginning on page 11 of the pdf on Turning Off the Grind Function (if not using the grind feature) and Making Coffee.
Make sure you are turning off the grind function if using preground coffee and that the reservoir lid is securely closed.
Check the Cups Setting button; is sounds like the 1-4 feature may be turned on.
Jan 30, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
Kenmore Elite coffee maker Model # 100.9101670A Is this model on a recall? How can I get a manual for it? And what is the filter reset button?
I have a manual with mine and as far as "recall" goes on this model, I've not found anything recalling this particular model...<br /> <br /> The most important thing in the manual, that I have found, is how to clean and change the filter. If all else fails unplug the pot for 10-15 seconds; replug it...this resets it...(if it ever acts up, do this; it helps)<br /> <br /> The filter reset button: Your coffeepot should flash a small message stating: "change filter and clean" To do this you first, turn off the pot, remove filter~(the filter is in a long thin black plastic thing and the filter cover simply snaps and pulls apart to expose the charcoil filter; Remove the Filter, then fill the coffee pot with 7 cups of vinegar plus 7 cups cold water; Place a paper type regular coffee filter in the brew basket, or a thin paper towel works well too~(This traps and holds particles that get trapped inside the pot)<br /> <br /> Before brewing; PLEASE NOTE, brew the first pot of vinegar/water mixture only HALF WAY then TURN OFF and let it sit for a good 15 minutes to soften any deposits...<br /> Turn the pot BACK ON and brew the remaining solution. When brew stops turn OFF coffee pot, empty the solution, and discard the paper filter...<br /> <br /> Refill reservoir with cold water and turn ON; you may want to dump this and refill with more cold water to ensure the vinegar taste/smell is gone...<br /> <br /> Now, wash the brew basket and the glass pot...Open the black skiny Water Filter and replace with a new charcoil filter...Put Filter back in pot...fill brew basket with coffee and brew some mighty fine tasting coffee!!! Hope this helps....Good Luck
Jun 29, 2010 | Coffee Makers & Espresso Machines
My Cuisinart 10 cup Grind & Brew does not finish the brew cycle. After brewing 2 cups of coffee, it beeps 5 times as if the brew cycle has ended. Then it continues to drip very very slowly. It's only...
you need to run a few pots of straight white vinegar through the machine to clean out the lime build up in the tubes. the first time you do it, after it starts to pump the water, shut it off for a few hours and let the vinegar sit in the tubes. after doing this run a few pots of cold water through before making coffee.
Nov 07, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
I Have a Cuisinart Automatic Grind & Brew Thermal that when you start brews a small amount of coffee and then shuts off. I shut off grind and start. After I do that it brews a full pot. We have cleaned...
I do love our Cuisinart pot...but find they only last 2-3 years...so my suggestions is: if the pot is still in warranty, call Cuisinart for a new one...they are great about it. If you don't know if it is still in warranty, call them, give them the number and they will tell you.
jlo
May 30, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Do not know how to program fresh start oasis full button over fil
Remove the brew basket and water defuser (sprinkler head) it should come off with a 1\2 turn.
Place your measuring pitcher or empty pot in place.
Turn the main power switch off in back of unit.
Press and hold the Brew(full pot) button.
While holding the Brew(full pot) button turn the main power button in back to on.
Once the red light flashes over the Brew(full pot) button release it, then press it once to start the brew cycle.
Let it flow until desired level in pot or measuring pitcher.
Press the Brew(full pot) button once to Stop.
Press the Brew(full pot) button once again to lock the settings into memory. Memory will store the settings even if machine is unplugged.
Half pot button is automatically set.
Apr 09, 2009 | Oasis FreshStart 80 oz 10-Cup Coffee Maker
Pot keeps shutting off after coffee completely brewed.
This may be an electrical issue, but I would try holding in the on/off button for a few seconds and see if it still displays 2 hrs as the auto-off time. If 2 hrs does display correctly, unplug the unit for 16 minutes or longer - do not plug it back in a single second shy of 16 minutes. Then reset the clock and reprogram the auto-off Try one more time.
If that fails, it may be replacement time.
-Tha Mp3 Doctor
Nov 28, 2008 | Cuisinart DGB-500 Coffee Maker
Cuisinart DCC2000 quits brewing after 1or 2 cups
Finally, I got my coffee pot to run through without stopping several times. To fix it I had to run vinegar through eight times! Never before has it taken so many cycles to clean out a pot. It is still spluttering a bit so today I am going to get more vinegar or maybe even CLR and run it through a few more times.
Nov 18, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Hamilton Beach BrewStation 47224 Coffee Maker Logo
67 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Greg Cann
Greg Cann
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
