Question about AOC LM 720 17" Flat Panel LCD Monitor
I need a power cable for an LM720a monitor - AOC LM 720 17" Flat Panel LCD Monitor
    President:
  • 635 Answers
There is a new one at Amazon.com.
heres the link.
http://www.amazon.com/HQRP-Adapter-Monitor-Replacement-Coaster/dp/B0025UAFYE
Posted on Aug 30, 2010
Do I need both cables for windows machine or can the USB connected to the machine and the mini dp plugged into the monitor work by itself
Is this an external monitor cable? Where the monitor cable that connects to the computer has two USB cables attached at one end?
If so, no. You do not need to plug both ends in. If one is powering the monitor fine and you see no performance problem occurring with the monitor you are OK to plug in just one.
The extra USB end connected to the cable is for additional power supply. If for some reason the machine you are plugging into does not supply enough power to the external monitor you would plug the second end it to the machine and boost the power to the monitor.
Hope that helps.
Oct 20, 2015 | Computers & Internet
Power cable for a computer monitor E210250054
l have a computer monitor l need a cable for power supply the is it moDer E210250054
Mar 14, 2014 | SVA-USA VR-15BU 15 in. Flat Panel LCD...
I have a dell studio 540 desktop, I need to restore to factory settings but my monitor will not stay open. It opens for a few seconds then immediately goes into power saver mode and turns off, how can
I see two things here, but need clarification;
1) Monitor goes to Power Saver Mode, then turns -> OFF?
Sure that monitor didn't go into Standby Mode?
2) Why are you performing a restore back to factory settings?
Pick up a virus?
Primer;
The monitor receives a signal. A video signal. The video signal comes from the computer.
If the monitor is NOT receiving a video signal, then the monitor will state No Signal.
This is for older monitors.
New monitors do not state No Signal anymore.
It's Power Saver Mode, or Sleep Mode.
If the monitor is truly OFF, the Power On button will Not be lit up.
Or the Power On LED light on the monitor.
Monitor power on LED is lit, or Power On button is lit?
Monitor is not receiving a video signal;
Use a monitor cable from a KNOWN to be working monitor, for a temporary test.
OR,
Use a Known to be working monitor, and it's monitor cable.
Need to find out if monitor cable is good.
Monitor cable checks out good?
Then problem is computer.
The two leading issues with desktop computer failure, is;
1) Computer is dirty inside
2) Power Supply inside computer is bad.
Please post back in a Comment.
Regards,
joecoolvette
Mar 27, 2013 | Computers & Internet
MY PC MONITOR AOC LM720A HAS A BLACK SCREEN WITH THE MESSAGE OUTPUT NOT SUPPORTED CAN YOU HELP
if u are changing ur old monitor to new u may face problem ,
press F8 when the system starts and select the safe mode option and login admin mode change video settings resolution(control panel/display properties) into higer like (1020 pix) and if it visible give yes and restart
May 19, 2010 | AOC LM720 17" Flat Panel LCD Monitor
Hi, I have an AOC LCD Monitor LM720A and I can't get it to turn on, ie a power issue possibly, I have changed the fuse and there is still no life, any help would be greatfully appreciated. Thanks Tony
anthony_salt, If the fuse you replaced is still good, then I would first check the "switch-mode-power-supply" for bad electrolytic filter capacitors. By the way, was the original fuse bad? I also highly recommend you pay a visit to YOUTUBE, search out and view the longer vid clips of lcd monitor disassembly and lcd monitor repair. FYI try a website run by another fixya guy nickname is "buddymc" and the site is www.ccl-la.com/badcaps.htm They refurbish (rebuild) lcd displays of all kinds and all manufacturers. You can also check out these other sites FYI. www.lcdparts.net , www.badcaps.net I hope that this info steers you in correct direction. Good luck guy. 12fixlouie bye
Nov 09, 2009 | AOC LM729 17" LCD Monitor
Please help for Cable and Power supply for KOGI monitor L7EH-TA ???
the power cable is as the simple attach to run the pc..
the vga cable u have to buy it from computer/monitor shop..
ask them for cable by telling them the model and spec. of your monitor.
regard,
dont forget to rate it
Jun 14, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Monitor stand and power cable needed
Hi Kiran,
If the power cable matches the power cable of your computer, it's a standard 3 prong power cable and you don't need a specific kind. If it's a small circular type you will need an external AC adapter, the type will depend on the manufacturer and make of your monitor. These can be found on eBay usually. Most monitors use different types of stands, but if your monitor has the standard VESA 75 or 100mm mounting holes on the back, you can find many monitor stands that are compatible with it. The standard VESA mounting holes are usually used for wall mounts but lots of stands connect to the monitor this way. You can tell by a set of 4 holes for screws or bolts on the back that are either 75mm or 100mm apart (vertically and horizontally). Don't forget to get the right kind of bolts for the stand, if it doesn't include them.
Jun 10, 2008 | AOC Computers & Internet
Liquid Video Monitor
Ebay sells them do a search for monitor cables. Good Luck I get them all the time
Mar 07, 2008 | Computers & Internet
Lm720a 17" monitor switches it's self
try to resolder all lost contact on flyback transformer..............................
Oct 11, 2007 | AOC LM 720 17" Flat Panel LCD Monitor
I have a problem vith a monitor aoc lm720a
Try to connect another monitor to verify the problem is related with your video card or the monitor itself
Jul 31, 2007 | AOC LM720 17" Flat Panel LCD Monitor
AOC LM 720 17" Flat Panel LCD Monitor Logo
104 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
