Question about Saeco Vienna De Luxe Espresso Machine
Coarse Grind Hello All, I?ve had a Saeco Vienna De Luxe machine for many years. On a regular basis I clean the brew group and associated parts. Recently I had to get my machine repaired and the shop owner told me I needed to be cleaning the grinder on a regular basis as well. So I cleaned the grinder. I followed all of the directions, cleaned everything, installed the rings at the ?zero position? and made a test cup of espresso. The grind was super coarse, not fine as it should be. I?ve adjusted the grind using the knob on the machine and verified that the adjustment ring has moved. Still, I seem to just get this coarse grind that results in a weak cup o coffee. Any ideas? Thanks
Il y a de l'eau qui passe en dessous du plateau avec du café moulu
Posted on May 08, 2008
I cant take out the brew group of my saeco vienna espresso machine
have to make sure the group is in part. turn machine off and on should hear the motor go. if the group is stuck take the small screw out of group and will release piece thats on the injector. MUst hold the lever on the front of the group to relase the lock then gently pry it out .
Dec 12, 2009 | Saeco Vienna De Luxe Espresso Machine
Change the grind in Saeco Vienna Deluxe coffee maker
Hello kgspco.
You will need to work the 'dial knob' untill it free's it-self.
The higher the number the Coarse(r) the grind.
If you want rich - dark - strong coffee, set number between 4 - 8.
(if you can free it up - keep trying
Jul 06, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna de luxe no coffee comes out
The brew unit is blocked, remove unit and then remove the screen located at the top, clean screen and reassemble.
Jul 03, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna Deluxe leaking problem and grinder problem
I would repair it, it sounds like the grinder needs to be adjusted (burrs may be dull), and the leak on the bottom may be coming from the small drain hole on the back of the brew chamber. If you remo;ve the chamber you will see the white water valve that the chamber connect to, if you look below the white valve the small chamber in there will be filled with water, below that there is a small discharge use a stit stick or paper clip to clear hole.
May 07, 2009 | Saeco Vienna De Luxe Espresso Machine
Grind settings
The factory setting should be 8. The higher numbers are finer. The + and - knob is the doser amount, the amount of coffee in a shot dose. Average is 7 gm, the middle. The highest is 14, I think. Generally, the highest dose shouldn't be used consistently because it can cause stress on the brew group. Just brew two shots.
Apr 17, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe not transferring grounds to brew group?
Make sure there not comming any damp into the grinder and the grinder is dry. If there was some damp in the grinder then you have to clean the grinder.
Aug 07, 2008 | Saeco Vienna De Luxe Espresso Machine
Coffee tastes burnt
Hi Adrienne,
I think you have to replace your printed circuit card, make sure all cable inside the machine is on place.
Hope this will help you.
Jul 23, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco De Luxe Coarse Grind
You could have knocked it out of its shaft or worse, Cracked the shaft itself.
Settings could be off too, It fairly common. Recheck the chamber, and make sure the plastic casing isn't cracked and the grinder doesn't wabble at all. It should be fairly firm.
If it isn't firm, bad news, cracked shaft.
May 08, 2008 | Saeco Vienna De Luxe Espresso Machine
Problem getting a Full Cup of Coffee
besides descaling you need to lube the brew group, especially the bit that accepts the group nozzle. You might have a leaking boiler too, 6 years is pretty good for a vienna.
Remove the brew group and look for the two red o-rings on teh brass bit, smear some lube on it, they might need replacing by now, but luckily they aren't too expensive and readily available albeit a bit tricky to install, a good light and some patience is very important.
Dec 14, 2007 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe Espresso Machine Logo
297 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
