Question about Canon I960 InkJet Photo Printer
I have a canon I960 printer at work, the waste ink tank is full, how can I fix this problem myself.? Can you give me step by step instructions? Please? Thank you
    Genius:
  • 1,040 Answers
Visit to the service station and they will replace the in absorber....
Posted on Aug 30, 2010
Canon i960 printer. Error message is "waste ink container full" where is it and how to empty?
That is actually a secret code that you need a new printer!
Here is a video. It is not your Canon, but it shows you just how deep they are inside a machine.
https://www.youtube.com/watch?v=nB-WXaO_ViM
This shows disassembly in words and pictures for your printer.
i960 Waste Ink Tank Pad Replacement Nifty Stuff com
Jan 19, 2017 | Canon Office Equipment & Supplies
Waste ink tank full
hi can yo please give out the part number and more detail of the problem
Sep 07, 2008 | Cannon Office Equipment & Supplies
Waste tank near full
Hi
The waste ink take is actually just a felt pad that sits under the printer mechanism inside the case and absorbs the ink from your cleanings
Try this:
1 Power off printer
2 Hold RESUME button then press and hold POWER. (The beeper MAY sound once, or may not depending on your model.)
3 Hold POWER and Release RESUME.
4 Press RESUME twice then release both POWER and RESUME buttons.
5 When the indicator lights steady, press RESUME 4 times (for the S900, 3 times for the 8200 apparently).
6 Press power to set data.
7 Print away!
Let me know if that didnt solve your problem
Jan 10, 2008 | Computers & Internet
Waste tank is full, How do fix it, can I clean it myself?
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink full" error.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you. Once they are replaced, it'll be functional again.
May 15, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Canon i960 puts up an error code "USB003" used ink tank almost full. how do i reset the printer? please.
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Mar 06, 2009 | Canon i950 InkJet Photo Printer
Canon i960
I cleaned the waste tank pad following the directions at
http://forums.techguy.org/hardware/421538-solved-printer-used-ink-tank.html
These were from Lanmaster.
Note carefully how you take it apart - with photos if necessary - so re-assembly goes well.
Wear gloves!
Nov 03, 2008 | Canon I960 InkJet Photo Printer
Waste ink absorber full--where do I get it serviced? or, can I do anything?
I sent you a solution
here it is again
let me know if you require anyhthing else
Reporting solution by daweed:
"WASTE TANK ALMOST FULL or FULL ERROR MESSAGE PROBLEM
This is true with many Canon Ink Jet Printers: Eventually, you'll get an error message "Waste Ink Tank Almost Full, Contact Your Canon Repair Center". Canon is totally sly about this, and is actually a pretty ridiculous design flaw that they should be ashamed of- planned obsolescence. Anyway, don't let this problem discourage buying an otherwise fantastic Canon printer.
This problem will also be indicated by flashing orange lights on your printer. Different flashes for different models.
LOOK IN YOUR PRINTER MANUAL TO KNOW WHAT NUMBER OF FLASHES INDICATE. In any case, your computer printer software will also tell you exactly what is going on.
You need to do this after you get the WASTE TANK ALMOST FULL message and the printer continues to work, but BEFORE the WASTE TANK FULL message and the printer completely stops. I think. ;-)
Here's the fix:
The waste ink take is actually just a felt pad that sits under the printer mechanism inside the case and absorbs the ink from your cleanings. From what I gather, its both a time consuming and expensive proposition to take to Canon to fix. And they won't tell people how to do it themselves. Well, I WILL. And this works.
Remember of course, you've got to cycle the cleaning process a huge amount of times to get this to occur.
But when it does, there is a fix-it-yourself solution that is both safe and effective for the printer, and free. You have to be slightly mechanical to do this. If you get this message and you've never used a screwdriver and are all thumbs, well, Canon gotcha. But give it a shot even then, or give it to someone halfway coordinated to do this for you.
You may RESET the printer code first if you like or do it after you clean the pad
In some cases you may need to REMOVE THE PRINT HEAD FIRST or the reset code will not work. This was true of the S900 and i960 so, remove the print head first before doing this reset.
This is the correct code for the S and I (like i960) series of printers. (M series below this)
1) Power off printer
2) Hold RESUME button then press and hold POWER. (The beeper MAY sound once, or may not depending on your model.)
3) Hold POWER and Release RESUME.
4) Press RESUME twice then release both POWER and RESUME buttons.
5) When the indicator lights steady, press RESUME 4 times (for the S900, 3 times for the 8200 apparently).
6) Press power to set data.
7) Print away!
For other codes for other printers and more info go here to this big forum (but try the above first) Fix Your Own Printer Generally many of Canon's models use exactly this same code, the i models use the same code, all the s models use the same code.
I did this and it works fine! No more error messages and so..."
Sep 04, 2008 | Office Equipment & Supplies
Canon i950 will not reset counter for waste tank full.....
For Canon i850, i950, S600
2. release RESUME
3. press RESUME twice, then release POWER
Jun 04, 2008 | Canon I990 InkJet Photo Printer
I get an error message on Canon i960 printer that tells me the waste ink tank full. How can I empty this myself?
Read it all here.
Scroll about half the page, to:
WASTE TANK ALMOST FULL or FULL ERROR MESSAGE PROBLEMThere is explained how to get rid of the error message very easy, and how to clean the waste ink pad manually. The latter seems not to be necessary, though.
Mar 27, 2008 | Computers & Internet
Waste Ink Absorber full - Canon Pixma
Here's the fix:
7) Print away!
Mar 13, 2008 | Canon PIXMA iP90 Mobile Printer
Canon I960 InkJet Photo Printer Logo
233 people viewed this question
old marine
old marine
