Question about Xerox Phaser 3200MFP/N Laser Printer
Dark strip when coping from the tray at top the copies have a dark strip down the center. when coping from the scanner the copies are clear. How can i solve this difference. I have cleaned the black wheels pulling the paper through the tray however this did not work thank you for helping
  • CherieKory Oct 21, 2008
    Thank you great help!
    Problem Solver:
  • 5 Answers
Your scanner glas is divided in two. There is a very small strip of glass on the left side of the big glass. Clean that little strip and copying from the DADF should be fine again.
Posted on Oct 20, 2008
  • 35 Answers
LIFT THE COVER UP AND CHECK FOR A SOMETHING ON THE NARROW GLASS IN FRONT OF WHERE THE FLAT BED SCANNER SCANS .
COULD BE WHITEOUT OR GREASE MARKER OR EVEN A DIRTY PEACE OF PAPER
Posted on May 09, 2008
2 Suggested Answers
  • 2072 Answers
SOURCE: dark strip down center of page when coping from tray
There is a small strip of glass on the left side directly under the edge of the scanner, About a half an inch wide. It has something on it.
May be very hard to see, use a strong glass cleaner or some alcohol and a regular piece of paper to clean it with.
Posted on May 08, 2008
What will be the reason for canon sensys fax-L 150 coping dark page but faxing and printing is ok.
First things first. Try and print report from the fax. Any kind of report. If it is printing OK, then the next step is to check if:
Your clients receive your faxes OK? If they are dark as well, then your scanner head is at fault.
When you make Copy on your fax and it prints dark it could be simply set with dark settings _or_because of the white calibration strip or roller being soiled or dirty, which acts as the ultimate white reference point for scanner _or_ the Scanner CCD sensor is in paper jam release position (too far away from reading the originals) just pull it back to normal feed position.
Or simply faulty scanner.
Sep 30, 2016 | Canon i-SENSYS FAX-L150 Laser...
Black lines when you fax and copy
Open up the document feeder and clean the small scanner glass.
Feb 18, 2009 | HP Officejet 6310 All-In-One InkJet...
Copies are very dark; almost grey.
Is this a color copier? If so are you using the color copier setting? If you are it is coping the color of the paper and it is comming out gray. Not sure but I have had this happen before.
Jan 17, 2009 | Office Equipment & Supplies
Black line down page when coping from copy feed
The small glass surface at the top of the scanner bed had some gunk on it. I scrapped it off and the line went away! Yay!
Jan 01, 2009 | Brother Multi-Function Center MFC-240C...
Paper Jam wont clear and there is no paper in it
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} When printer does not have visible paper jam and printer is showing error paper jam
Check if the Encoder Strip is Broken or Missing
1.Power down the printer and unplug the power.
2.Slide the cartridge carrier inside the printer a couple of inches to the left.
3.Locate the encoder strip (Figure 1) on the right-side of the cartridge carrier encoder strip
Note:
The encoder strip is a plastic strip with small markings over its entire length. The strip may appear to be translucent.
Reposition the Encoder Strip
1. Remove the power cord from the printer.
2. Lift the scanner unit to expose the inside, where the printer cartridges are located.
3. Gently slide the ink cartridge carrier to the middle of the printer.
4. Gently move the top part of the printer belt to the right.
5. Using an index finger, gently push encoder strip (Figure 1) down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
6. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
7. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
8. Once the encoder strip has been re-seated, close the scanner lid.
9. Re-connect the power cord to the printer.
Ensure the Paper Tray is Not Overfilled
Each printer tray has a maximum capacity rating, and this rating is based on a specific paper weight and or thickness. Consequently, situations might arise in which the tray will not be able to accommodate the maximum number of sheets listed in the printer specifications. Verify that the paper is not packed too tightly in the paper tray.
Aug 17, 2008 | Dell 924 All-in-One InkJet Printer
Clear paper jam message but no paper jam
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Check if the Encoder Strip is Broken or Missing
Note:
Adjust the Printer Paper Guides
Adjust the paper guides to fit the size paper being used .The guides should be close (1/16" or less) to the paper without touching, so that the paper stays properly aligned without continually rubbing the guides.
Locate and Remove Any Obstructions Inside the Printer and Input Tray
1. Open the front cover and make sure the kickstand (if there is one) is engaged.
2. Locate and remove any obstructions within the printer, such as paper pieces, staples, tape, or other objects.
3. Close the cover.
4. Remove all paper from the input tray.
5. Inspect the input tray for any obstructions.\
6. Remove any visible obstructions.
7. Reinsert the paper.
Clean the paper feed roller on the printer.
1. Power down the printer and disconnect the power cord.
2. Remove all paper from the input tray.
3. Wipe the roller gently with a damp cloth.
Aug 13, 2008 | Dell 924 All-in-One InkJet Printer
Dark strip down center of page when coping from tray
May 08, 2008 | Xerox Phaser 3200MFP/N Laser Printer
Not printing properly....alignment
It is possible that the guides in the paper tray have moved?
If they are universal trays (meaning they are not locked down to only use one particular size), they could have easily shifted, causing what you have described.
Try copying using a sheet of paper through the bypass tray, and see if the image is centered. This will at least narrow down the problem to a particular tray.
Feb 05, 2008 | Toshiba 2060 Copier
Black line on my fax copies!
You sure can - the issue is that there is something on the thin strip of glass where the copy goes through from the feeder at the top - follow these directions and you should clear the problem right up.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00671260&cc=us&lc=en&dlc=en&product=1119598&dlc=en&lang=en
Jan 22, 2008 | HP OfficeJet 6310 All-in-One Printer...
Printer putting line down the page
I had a hp 3050 yesterday with two vertical lines running down the page when making a copy. All I had to do was to pull open the top cover where you put the paper you want copied and cleaned the glass strip with a rag and alcohol and the lines were gone.
Jan 21, 2008 | HP LaserJet 3050 All-In-One Printer
Xerox Phaser 3200MFP/N Laser Printer Logo
179 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
