Question about Microwave Ovens
Gas cooker elc starter not working , iv have all ready change fuse in plug.
    President:
  • 2,702 Answers
It could be the coil in the spark ignighter,,,or dirty spark plugs!
grease can get into the switch as well
Posted on Aug 30, 2010
Has stopped working. light gone off at same time. plug fuse has not broke. any ideas ?
There is a fuse inside the microwave also.It is a ceramic fuse,usually 15A.It has to be replaced with another ceramic fuse of the same rating.Bear in mind,the fuse blew for a reason,so if it is the interior fuse replace it after a search for a fault.
Dec 17, 2014 | Microwave Ovens
CAN a ZANUSSI gas cooker be converted to utilize NG ? Without affecting its programs and controls ?
usually any gas cooker can be converted as long as the gas jets are changed to the right size. they also have to be the right fitting. it would involve a lot of work as you will need to get into the nitty gritty of the gas lines inside the cooker and if you make a mistake it can cost to get it fixed.
Jul 02, 2017 | Microwave Ovens
Where are the fuses in my microwave oven,?
Inside behind the display panel on a small circuit board.
Jan 01, 2013 | Magic Chef MCO160UB Microwave Oven
Iv'e purchased a 5 cup homemaker rice cooker but your leaflet dosen't explain how much rice or water ratio
I am sure that there is some official rice water ratio, but my method works for me.
1. Rinse the rice until no more "white" comes off of it and the water runs clear.
2. Let sit for one hour in water.
3. Drain water.
4. Add water to 1" over the top of rice and start in cooker.
5. Add 1 cup of water per day until rice is used up.
Jun 25, 2011 | Microwave Ovens
I had bought the electric pressure cooker 2 months ago and was working fantastic, suddenly it stopped working this week and there is no power light even coming up - PLEASE help
Probably the main wire is faulty or the fuse has blown out.open the cooker from below
{find,check the fuse with a continuity tester}do check the main wire with the help of a continuity tester too for any kind of breakage.If there is no continuity or the tester bulb does not light up there is a fault with the component.Replace the wire/Fuse with the same rating or quality and your cooker will surely work
Dec 04, 2010 | Microwave Ovens
Cooker is not working checked fuse and plug socket was working then just stopped
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 28, 2010 | Microwave Ovens
No power to microwave all ready checked fuse box and ok , changed microwave fuse ,and still no power and solutions it a whirlpool
the circuitry has probably gone bad, try plugging it into a different electrical outlet, but if that doesnt work, its probably dead. and it will be cheaper for you to replace than have serviced, unless its still under a warranty
Jan 15, 2010 | Magic Chef MCD1311ST Microwave Oven
Oven electric starter shorted out and no display on display
hi, have you changed the fuse in the plug, if the starter has shorted out then the chances are you will keep shorting out untill you replace the starter.
If you have replaced the fuse and you still have no power then the chances are you have blown the circuit board if this is the case then this would need testing and any parts replacing.
The problem with doing this is you would need a copy of the schematics and also testing equipment to test the board .
Let me nkow how you get on or if you need further assistance ok
Nov 07, 2009 | Microwave Ovens
MY cookers not heating up can anyone help iv put a new element on but no heat
the magnatron needs replaced....may be cheaper to but a new one!
Dec 09, 2008 | Microwave Ovens
Microwave Ovens Logo
21 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
