Question about Xerox DocuColor 3535 Copier
My IBT JAM / OR IT NOT BE ROLLING WHEN MACHINE IS RUNNIGN WHEN I WASHED IT VACUME CLEANER AND CLEAR THE DUST THEN IT WAS EASY ROLLING, PLEASE TELL ME WHAT IS MY IBST BELT PROBLEM
  • 33 Answers
Please give me the fault code first.
Posted on Sep 07, 2010
When cleaning the cyclone head can this be flushed with water?
Hi Len, it's Jack at Dyson.
The cyclone pack on your DC14 should never be washed, flushed with water or submerged. Any residual water left within the assembly could cause permanent damage to your vacuum not covered under warranty. It could also contribute to an unpleasant odour from your machine in use.
To clean the clear bin and shroud, you can remove the clear bin from the cyclone pack using the catch on the rear of the cyclone pack, as shown below. A soft brush or dry cloth can then be used to remove any clinging fluff or debris from the shroud. Gently tapping the cyclone pack will also help remove any clinging dust particles.
You can also rinse or wipe the inside of the clear bin with a damp cloth to remove any dust particles, but make sure it's completely dry before reassembling.
I hope this helps, but if you'd like any further guidance on maintaining your vacuum, please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Aug 11, 2014 | Dyson DC14 FS Telescope Full Kit HEPA...
My xerox dc12 have this error system fault 3-380 what can i do to fix it
Did you recently replaced print cartridge? Because,if you did one thing that could be a problem is that you are using illegal or not original PC. Second thing that could make you some problem is IBT cleaner. IBT cleaner has two brushes on the each end of the assy. Their job is to clean silver patch on IBT. So maybe your IBT cleaner is worn out and those brushes does not do it's job anymore or maybe the sensor that "reads" that patch is dirty.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Apr 07, 2011 | Office Equipment & Supplies
Please i need technical help and be able to speak to a live perosn via phone to help with a xerox workcentre 24 color machine. will pay a fee of course. Does anyone have the XEROX software to tell the...
You have to have a fully configured laptop with several levels of Xerox software.
Once that is accessed though you can change those numbers to max them out for the life of the machine.
Where do you live? Maybe I can find someone to do it for you.
Aug 02, 2010 | Xerox WorkCentre M-24 Color Copier
Error code 3-380 what does this mean
That error describes a number of things that can be foulty on your machine. First Did you recently replaced print cartridge (PC)? Couse if you did one thing that could be a problem is that you are using illegal or not original PC. Second thing that could make you some problem is IBT cleaner. IBT cleaner has two brushes on the each end of the assy. Their job is to clean silver patch on IBT. So maybe your IBT cleaner is worn out and those brushes doest do their job anymore or maybe the sensor that "reads" that patch is dirty
Aug 05, 2009 | Xerox DocuColor 12 Printer
Xerox DC12 What does code 3-380 mean and how can I correct it
Aug 05, 2009 | Office Equipment & Supplies
9-345 occured what to do what is retract explain what to do
Your IBT cleaner blade retraction mechanism seems to have failed. Pull out the Paper Path Module totally (push the two clamps at either side of the module with a nail or something similar and pull). Pull out the CPC and the Dev. waste container. Now you can see two screws fastening the IBT assy to the chassis. Take out the screws and pull the IBT assy. It will come out. Now lift the IBT assy out of it's holder. and place carefully on a table. Inspect the right side, that is where the cleaner blade is located. Check it out.
May 06, 2009 | Xerox DocuColor 12 Printer
DC 12 EROR NO 3-380
i solved this problem it ibt belt problem
Jan 23, 2009 | Xerox DocuColor 12 Printer
Xerox docu color 12
u check drum,ibt belt,2nt btr roller and fuser life... then do full service, then calibrate ur fiery also.. first u check developer bios plate.. if its have more dust print comes like that.. all the best..
Aug 14, 2008 | Xerox DocuColor 12 Color Copier
XEROX DOCUCOLOR 12
Remove drum unit. check charge wire for contamination. clean or replace. Visually check fuser for an even glossy appearance. If it looks dry or damaged in any way a service is needed. IBT is a bit more difficult to check. If you have the know how to remove it. You should see a very shiny surface free from contamination of toner or paper dust, ect. clean if necessary and replace. If contamination reoccurs suspect cleaner. Last is the BTR check for proper operation and clean, repair or adjust if necessary.
May 26, 2008 | Xerox DocuColor 12 Printer
Brother 2820 Says clear scanner jam and press stop
Make sure there is nothing caught where the documents go it. List up the scanner cover and look inside. It may need a separator pad or clean the feed rollers with some alcohol. Lawrence
Mar 23, 2008 | Brother IntelliFax-2820 Laser Fax
102 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
