Question about Cobra 148 GTL 120-Channels Base CB Radio
Can not recieve properly
Ex . i can w/ another radio ,recieve a good carrier from someone.like a 7 w/ a 2 noise level.w/ my radio , i recieve a 2 noise level w/ a 3 1/2 carrier. note; the radio was modified when i purchased it.i sometimes can not hear someone because of this ,when i should?
  • 27 Answers
Mounted on the circuit board is a tiny black encased rx/tx
changeover relay. It is almost in the center of the board and one third to the left (facing the controls) and may be etched MRATA.
I would be looking at that. These sets are subject to a lot of problems as they age and can be fixed with a BIG HAMMER!!
CHEERS flyingfox@people.net.au
Posted on Jun 22, 2008
This is a confusing website. But my problem is with a pair of Uniden FRS 420 two way radios. Have replaced batteries, gone through manual, have every option set properly but still have no reasonable...
Are you stating the volume is not loud enough when someone talks or just idling. If if has a squelch knob turn it til it makes a hissing noise or rushing noise. then back to where the noise just quits. This is the proper setting. Then when someone talks increase volume to listening level you choose. If this does not work take them back and get your money back.
Dec 22, 2013 | Uniden 2 Way Radios Frs 420 Family,14...
My uniden walkie talkie has the RX button stuck on the screen i can talk to the other person but it always makes a screeching noise
Hi Laura,
When you see the Rx sign on the screen, it indicates that someone else is transmitting (Tx) on the channel, this is also caused by "BOOF HEADS" who like doing nothing more than dropping carriers by holding down their PTT button during a conversation, something that happens a lot on CB and without a doubt on FRS radios.
There is no problem in your radio, it's Just someone else probably dropping a carrier as per above.
Not much can be done about this problem, No License, No Joy.
The fact you can hear the other person over the screach indicates to me that I am right, and your radio is fine.
I hope this clears up your query.
Warm Regards,
Peter
Jan 13, 2013 | Uniden GMR-1088 2-way Radio Walkie Talkie...
One of our two radios (Motorola T5720) recieves but when you go to talk to someone else they cant here you. I have made sure that we were on the same channel.
Check your Code (interference eliminator code) and your Qt filter (if any) to see if they match the other units.
Best regards.
Aug 29, 2011 | Motorola Talkabout T5720 (7 Channels)...
Tub makes loud thumping noise when spinning
Good morning! It's common to hear a loud thumping noise during spinning because the load (clothes) are not properly place in the tub. Please try to put the load in order & compress it down. best regards.
May 02, 2009 | Washing Machines
IN your CB there are 25 tuneing slugs (square matal cans with
ferrite tuneing slugs) if you speaker output is low leavel but still
clear and free of hash the set should be ok , but you will need to tune these slugs with a small jewlers screw driver (WITH GREAT CARE) as the slugs break easy. If you want to email me it will not be a problem ,cheers , DENNIS FLYINGFOX@PEOPLE.NET.AU
May 08, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
On rx , i have a low carrier , sometimes cannot hear someone vs another radio
Depends on how it was modded? Were both the TX and RX broadbanded and tetuned?? Possibly poor work..
Radio Mic
Check the squelch on your radio thats not recieving. If there is a monitor button ( when pushed you will hear static) try pushing it.. then get someone to call you so you can check if you can hear them. On these radios you have 2 types of squelch....1 is called carrier squelch.... it basically opens when there is a strong enough signal. This lets you only hear strong signals and "squelch out" the distant ones and background static. The2nd. is "tone squelch" ... with your radio they are often called privacy tones. If you have 2 radios set with the same privacy tones you will only be able to hear each other... only radios that are transmitting with that privacy tone will be heard on your radio. Its a high frequency tone that can't be hear by the human ear that gets "embeded" with the transmitting signal. The recieving radio hears it and opens the squelch. So... if the radio thats rxing (recieving)your signal has its squelch set for just carrier squelch it will hear any signal thats strong enough to break the squech open.... basicaly any radio within a certain range. But if your radio (one with problem) has its squelch set for privacy tones you will not hear any other radios except the ones set with the same privacy tone.... the squelch will not open until it gets a tx signal with the right tone.... so if the txing (transmitting) radio is not using tone squelch but is using carrier squelch.... and the rxing radio is set for tone squelch... the rxing radio will not hear it. With tone (privacy tones/codes) squelch you need a tone to open the squelch and then the audio can be heard... with carrier squelch the squelch will open if ANY radio is within a certain range. Check the squelch setting on the problem radio... it could have a privacy tone set. Try pushing in the monitor button so you can hear static ( you want to hear everything including static) on both radios... tx on one radio at a time and listen if it can be heard on the other with the monitor button pushed. If you can't hear any audio when the broken one is transmitting then it COULD be the mic.... if you can hear both radios with the monitor button activated than the radios are txing and have tx audio and are working... if thats the case its the privacy tones that are the problem. Take care
Sep 12, 2007 | Garmin Rino 120 2-Way Radio
Making the recieve work better
Hello lugnut, the lack of receiver sensitivity may denote a problem with the RF input amplifier or the IF stages. before attempting to boost the incoming signal I would first want you to check the RF and IF receiver functions first. If there is a problem it would be more advantagous to fix it first. You will need the following equipment 1)schematic (To locate components and test points) 2)digital multimeter (to measure voltages and test points) 3)Radio Frequency (RF) Generator (to provide test and reference signals) 4)IF demodulator probe (to test for proper IF signal amplification along the IF stages) 5)Oscilloscope (To see if audio is being properly reproduced at the audio detector stage) 6) SWR meter(to test the standing wave ratio between (along the coaxial cable path) the antenna and the CB unit. 7)Antenna Dummy load (to emulate the antenna, under FCC law you can not transmitt into the air while testing and repair any transmitter or transceiver). I hope this provides insight into what you will need to work on this problem. These pieces of equipment are needed to properly troubleshoot a CB radio
Sep 12, 2007 | Galaxy Radios DX-66V Base CB Radio
Communication problem with my brend new T5720.
I have seen some problems with new out of box radios, one of them is out of frequency and recieve with noise and works with low range coverage. I can not clarify what you mean with feed back, check if you set in low volume if the radio works fine. That will tell you that the speaker or the Synth circuitry has a problem. Neto.
Dec 06, 2006 | Motorola Talkabout T5720 (7 Channels)...
Cobra 148 GTL 120-Channels Base CB Radio Logo
67 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
