Question about Honda Horizontal OHV Engine for Non Pumps 160cc GX Series Threaded 58in x 2 716in Shaft Model GX160UT1TX2
Engine stats and then shuts down immediately - Honda Horizontal OHV Engine for Non Pumps 160cc GX Series Threaded 58in x 2 716in Shaft Model GX160UT1TX2
  • 4 Answers
Open drain on carb to check if water in fuel if water in fuel drain tank and take carb float bowl off and clean and filter bowl
Posted on Aug 31, 2012
  • 44 Answers
Sounds like the coil
Posted on Sep 09, 2010
At night its shuts down when the therm is satisfied,but trys to restart right away and when it does start it shuts down right away and just keeps doing this
The thermostat has a differential built into the temperature sensing operation. The differential is normally a degree or more. If the stat shuts down at 72 degrees it should not start the unit again until the temperature in the room reaches 73. If the AC runs and cools properly until it shuts down, I would check the thermostat. The AC can not restart immediately after it shuts off because the pressures in the system are too high at the compressor. It takes a few minutes for the pressures equalize allowing the compressor to start. If the stat tells the unit to start under high pressure, the compressor will shut down on overload. It will start and run after the pressure falls enough for the compressor motor to run.
Jun 04, 2015 | Dometic Rooftop RV Air Conditioner
Ssangyong Kyron 2007 shuts down when driving
run fault codes and look for a problem with the TCM ( possible reading and engine over speed which shuts the engine down)and it should re-engage gears immediately upon reselection
Feb 09, 2014 | 2007 SsangYong Kyron 2.0D
Air conditioner turns on, then off, then on again immediately after
going out on safety or relay getting erratic connection from t-stat.
Nov 07, 2013 | Dometic Rooftop RV Air Conditioner
Hi I have an xl80 the burner lite and heats up till at desired temp, after burner goes out the fan keeps on running 15 minutes or so. If I go down and shut off power switch to furnace then the fan shuts...
Hi, sounds like you have a problem with the heat anticipator in the thermostat. If you replaced the fan limit, and with it running that long after the burners shut down, it would be in your stat. If it fires up after resetting breaker, was the stat set to call for heat? If not, the stat is faulty. If you remove the front to get to the stat wires, take a jumper wire and jump from RH or RC to W. Heat will start. Let it run for a minute or so and remove wire. If the fan shuts down with in a min. or so, you will know it was the stat. Good Luck and let me know the out come!
Shastalaker7
A/C, & Heating Contractor
Feb 11, 2011 | Heating & Cooling
Heil heating unit ran out of lp will no restart fan runs no fire up
if you ran out of lp you my need to purge the line. shut off power and crack gas line as close to gas valve as you can.try a 5 sec. count. reconnent and check connenction with soapy water for leaks. if none return power and turn t stat up. if it cycles and doesn't lite turn t stat down and then recycle may take 2-3 times. the fan runs on a timer. when the t stat is in demand the fan will run by turning the t stat down below room temp the fan will shut off.
Jan 29, 2011 | Heating & Cooling
My heater keeps clicking and trying to turn off, but pops right back on before it acutally shuts down. The little control box next to the fuel heater is the noise maker
Will it shut down if you unhook the t-stat wires???
If so then the problem is not in the heater...
Other wise you may have a t-stat/wiring problem....
turn down the t-stat and check if it stops....
then if it goes like that when the t-stat is calling for heat the flame sensor of the t-stat is bad...
My first iclination would be the flame sensor and/or ignition control...
heatman101
Dec 28, 2010 | Heating & Cooling
2000 - 300 M - engine ran hot QUICKly, shut down
Check your coolant level in the run-off tank and radiator. Something might be blocking the flow, t-stat could be stuck close not allowing to circulate coolant, check for leaks.
Mar 01, 2010 | 2000 Chrysler 300M
87 Ford Taurus 3L engine shut down when warm - will not restart
after it has shut down check for gas at the fuel rail with the key on their should be gas squirting out constantly it sounds like the fuel pump is going out
Jul 28, 2009 | 1987 Ford Taurus
Engine keeps shutting down
Most Honda engines have an oil pressure switch that prevents engine damage due to low/no oil pressure. Make sure there is sufficient oil in the engine and that the wire is connected to the pressure switch.
May 28, 2009 | Karcher 2500 PSI Pressure Washer
Honda Horizontal OHV Engine for Non Pumps  160cc GX Series Threaded 58in x 2 716in Shaft Model GX160UT1TX2 Logo
178 people viewed this question
Top Honda Plumbing Experts
Matt Olenzek
Matt Olenzek
JonSnell Electronic
JonSnell Electronic
Timllfixit
Are you a Honda Plumbing Expert? Answer questions, earn points and help others
