Question about Nexgrill 720-0234 (LP)
I have a 720-0439 model. Just this year, I can only get 2 of 3 burners to light at one time. If I turn on a third burner, they all go out. I can get each of the burners to stay on individually. Also, I cannot run the searing burner and any of the main burners. Any ideas? Thanks.
  • 43,501 Answers
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Posted on Sep 05, 2010
Hello, I have a Amana Air Command 80 model #GHI90A50, 22 years old. This furnace is on its third ingnition module (last one two yeras ago). The symptom I am trying to diagnose has been ongioing since this...
If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Dec 05, 2010 | Heating & Cooling
Jenn-Air Model 720-0061-LP. Burners will not
burner is blocked needs cleaning out remove burner and clean it or put it in clr , or buy new one
May 18, 2010 | Grilling
Only two of 5 burners will work at any one time.
Your problem lays in one of two area's.
Either your regulator needs adjusted or most likely it is your LP tank
Look in the tank fitting for a small brass ring It will have 2 small slots on either side. This ring can back off over time and then will not allow the male fitting to fully depress the valve in the tank thus reducing your gas flow. I have had this happen on several tanks a bit of caution and a small flat bladed screw driver has always fixed the issue
Mar 13, 2010 | Grilling
Very low flame, like very little gas is getting thru, tank is ful
Okay, what you are dealing with is called "vapor-lock". The way these grills need to be turned off is, close the tank valve first and after the burners go out, then turn the burners off. The way you are doing it is trapping the gas and you are getting a weak flame. Fortunately this is an easy fix. First, light the grill by turning the gas valve open, then turn the burners on to light the grill...as soon as that is done, close the gas valve on the tank then turn the burners off. Repeat this procedure until you get a good flame. If this procedure hasn't fixed the problem after the third time, you need a new regulator and regulators are easy to find in any home improvement store like Lowe's or Home Depot.
Dec 15, 2009 | Weber Genesis Silver B Grill
QPS Burner for Roland VS-2480 crapped out again...
Listen. I had one of those. DO NOT BUY ANOTHER. They were made in Canada and the company has not been in business in over 5 years. Search for one that is compatible. TRUST ME Throw it away.
Mar 25, 2009 | QPS (rw522452e2i) Burner
Loss of pressure on Kenmore 16322
I can tell you EXACTLY what is wrong. Remove the tank and open all valves to the grill. Reconnect the tank and turn it on just slightly. Relight the grill.
Ther is a safety device in the tank that needs to be reset. The only way to do it is removing the tank.
Dec 17, 2008 | Kenmore 16322
Grillpro model # 236464 owner's manual
Don't buy GrillPro grills they are junk!!!!!! I have had a GrillPro Model #236464 Stainless Steel Grill and after Three Seasons it has rusted to peices!!!! All Three burners and all Three Flavor Guards and both Channel Cross lites have rusted to a big pile of rust peices. I called GrillPro which is Manufacturered by Onward Manufacturing Company Limited in Canada and all of these pieces have been on back order for over a month and the company says they don't expect the parts anytime soon. Onward Manufactures the following brands:Broil King, Broil-mate, Sterling, Barbecue Genius and GrillPro. I have looked at several of these brands at Menards and they all use the same type of Burners and Flavor Guards that are in my grill so unless you want a big pile of Rust after three years of use I would avoid all of these Brands!!!!!! Forget the problems Take it back where bought and buy something else!! These brands will let you down! Al Gavin - 515-238-3920
Sep 17, 2008 | Brinkmann 810-2300-B Grill
Ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Aug 15, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Nexgrill 720-0234 (LP) Logo
431 people viewed this question
Top Nexgrill Grilling Experts
80stech
Gary Kenady
Gary Kenady
Michael Vincent Cruz
Are you a Nexgrill Grilling Expert? Answer questions, earn points and help others
