Question about Kenmore 64802 Top Freezer Refrigerator
My ice maker is not making ice and the bottom part is not cold.
    President:
  • 2,702 Answers
Check the fuses and then the thermostat and motor,,
Posted on Aug 30, 2010
GE refrigerator PFCS1RKZSS no ice
check for ice build up in the lines to see if that's blocking the air. Make sure your water and your solenoid are working.
Dec 11, 2015 | GE Refrigerators
Ice maker has water but no ice
HI.TERRY.freezer has to work at its optimum.for the ice maker to work. i would try to defrost the freezer completely first and try.good luck.Ali
Jun 28, 2012 | Samsung Refrigerator Ice Maker -...
Bottom Ice Maker
is it getting water? if not it could be the water solenoid. if it is and there is ice in the ice maker frozen then it could be the icemaker its self. make sure arm is down in the running position. if water is not frozen solid then the freezer is not cold enough.
May 26, 2012 | Refrigerators
Our GE Profile Ice maker is not making ice,and water is not cold?
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Aug 24, 2010 | GE Profile PFS22MBS Bottom Freezer French...
Ice maker not making ice
check the water solenoid for the ice maker on the back
Jun 11, 2010 | Maytag MFI2266AES Stainless Steel Bottom...
Ice maker makes ice, but not nearly as much as it used to. What do you suggest. Water flow out dispenser is fine. Filter has been replaced.
I would suggest making sure the coils under the refrig are clean of dust , lint , pet hair , etc . Also , letting the ice build up so it gets closer to the bottom of the ice maker (coldness of the ice will help keep the ice maker cold ) will result in ice maker cycling more often (making ice) .
Sep 08, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Jenn-Air bottom freezer ice maker not working
I took the arm of the ice-making machine out of the slot and put it back in, pushing it snugly inside the slot, then raised and lowered it several times. Then, with the arm in the up (stop making ice) position, I felt inside the ice-making tray, where I noted there were ice cubes as well as a sheet of ice at the base of the ice-making tray. I poured approximately 24 oz. of hot tap water into the tray to melt the sheet of ice. I turned the freezer temp control to "warmer". I think the freezer temp setting was too cold, causing the ice maker to freeze the water before it could make cubes. I have a working ice maker again!
Cynthia
Sep 07, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Bottom freezer "on" but not freezing and not making ice
Refrigerator running but not that cold, freezer running also but not freezing at all. Also not making Ice
May 17, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
1)First check you have a water line that is getting water to the ice maker.
2)Ice makers have a valve at the bottom that open and close when told by the ice maker replace that cheap fix.
3)The ice maker needs to be repaced.
(how far into the line will the water freezehow far into the line will the water freeze)
.The valve at the back opens and closes will not leave water in the line to freeze.
Dec 21, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kenmore 64802 Top Freezer Refrigerator Logo
32 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
