Question about JVC TH-A35 System
I used to use my TH A35 via scart to tv ext 1, when i moved i had a virgin media box installed and because i hadn't unpacked by TH A35 the guy used ext1 scart on my tv and tuned in all the programmes to this, now whenever i try and use my THA35 via scart ext2 my tv screen wont appear, any suggestions welcomed. Thanks
  • sam_warmley Aug 30, 2010
    Yeah i got one of those but it isn't working, thats why i asked for tech help!!
    I have a manual and followed instructions, it doesn't work, i want tech help pls.
  • 4,102 Answers
Hi you need to make sure you have pushed the scart lead in all the way at both ends as having it not quite right can cause the problem you are having.
also you need to put the virgin media into standby ie turn it off using the remote then turn the jvc on and put the telly on av2 or ext 2 what ever you use then it should show up then, it wont show up if the virgin box is switched on it needs to be in standby
let me know how you get on or if you need further assistance ok
Posted on Aug 30, 2010
    President:
  • 1,070 Answers
Welcome to FixYa
Dear User
This Guide can Help you to Configure your Device Properly. Click here to Read/Download the Guide[You should need Acrobat Reader to View this Guide-You may Download from Here ]
Thanks for Connecting FixYa
My TV will not stop switching itself off
Hi, The first thing to do is troubleshoot your TV independent to any other service provider that has a box that probably connects to your TV via a HDMI cable or old version scart.
Simply turn off your TV and turn off the socket that the TV is plugged in for 20 mins. Also turn of any Virgin media boxes.
After 20 mins turn on the TV. Do not worry if you get a message saying no signal detected. Wait and see if the TV stays on with no messages such as auto-standby. If the TV remains on with no problems then turn on your Virgin Media Box. The box will need to initialise ( about 30 seconds ) and then the TV should recognise the HDMI signal and you will see the Virgin TV.
If your TV turns off at any point during this process you have a fault with the TV, If when you turn on the Virgin box and no signal is detected you have either a cable connection problem or a Virgin Box problem, so using your TV REMOTE turn your TV back to ARIEL input to receive the normal television broadcasts via your Ariel that give you the normal freeview television that all modern TV's can receive, if you can get the normal reception contact virgin support who will troubleshoot your problem.
Nov 07, 2017 | Internet Computers & Internet
I purchased yesterday a 42"
I came across this very same problem a year or so ago regarding a Plasma TV and connection via scart. It turned out to be a problem with the scart lead. Replacing the lead with an all pins connected type fixed the problem. It was caused by the TV not being given the +ve voltage on pin8 and the TV thought it was not a proper signal and shut down.
Hope that helps.
Feb 27, 2011 | Televison & Video
I have a JVC RM-C60 TV. I'm trying to tune it in to my Virgin Media HD box using a standard SCART lead but having no joy. It's completely failing to find the cable channel (or any other for that matter)....
Tuning of the TV not required when using scart lead, just select external input that the scartis connected to, ie AV1,AV2 (EXT1,EXT2) etc. The problem is possibly to do with the Virgin box, it may be set to HDMI out in which case it will not output anything via the scart lead, you would need to connect via an HDMI lead (small socket on the rear of the unit looks a little like a USB socket). Problem is if your TV is a CRT television its unlikely to have this socket. Your Virgin box can be reset to output via the scart but you would need to contact Virgin for this process.
Feb 17, 2011 | JVC Televison & Video
How do i connect a virgin cable box with only scart output to a sony str dh810 AV reciever?
If your TV has audio outputs of any description, connect the V box to the TV via SCART and then connect the TV's audio output to your AV amp. This will allow you to use the amp to listen to the Virgin box's output being displayed on the TV. If you want to listen to mp3, connect the MP3 playing device to the AV amp. Select this source rather than t he source being used for the TV's audio. THe video output of the V box will still be displayed on the TV while you use the amp to play audio sourced via a different input on the amp.
Feb 03, 2011 | Televison & Video
Tv connected via scart cables through dvd and virgin media box. Picture sometimes goes yellow the flickers then back to clear.Other times it can go red. Plays dvd's okay though. Is this a connection...
This will be a problem with either the Scart leads (9 times out of 10) or the virgin media box. Not a problem with the signal coming from Virgin Media. Try checking the scart leads are not loose, or looped through the wrong way.
Hope this helps
TV_Doctor
Jan 03, 2011 | Sharp LC-32P50E 32 in. LCD Television
I have a toshiba 19w330db tv and already have a virgin media box and toshiba SD220EB dvd player connected. I am trying to connect a nintendo wii using the AV cable provided and am using the audio L R...
Do I understant this correctly? You are using a composite video cable (A/V y,r,w) and connecting it with the component video input (and then telling the TV to use the YPbPr source). You need a component video cable (3 RCA plugs on each end - red, green and blue) and an audio cable (2 RCA plugs - red and white) for the Wii. It wasn't included with the Wii but it does have the component video ports. Otherwise you would need a SCART to composite connector to work with the input. Alternatively, you could get an HDMI cable and connect that between the Wii and the TV (depnding on the age of the Wii).
If I've read this correctly, you have the media box and dvd player sharing the SCART input (EXT1).
I hope this helps.
Dec 26, 2010 | Toshiba Televison & Video
Have samsung 40inch lcd colour no good on ext 1 and 2 but on hdmi via virgin fine want to play dvd but no good on ext 1 and 2 will new hdmi dvd be ok via hdmi cable instead of scarts
Correct you wiring, color stream uses red, blue, green and they have to be hooked up correctly. the problem is obviously not in your tv or the DVD player.
Nov 08, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
TELEVISON MODEL:SAMSUNG LE32B450C4W my gran just recieved this tv today she also use virgin media digital on tuning in the television i noticed i could not find digital tv and that i had to go through...
In short: No.
Virgin Media is received via an external box and there is no way to simply program the tv so that your gran can just press one number.
There is a complicated way, but it would be even more confusing. Some Virgin boxes have an RF (i.e. regular tv aerial) output in addition to the usual Scart output. The RF output can be tuned into a regular terrestrial channel, but reception quality is poor compared to using the Scart. Your gran will have to remember to ensure the tv is set to terrestrial reception and to use the source button and ext when she wants to go back to Virgin. This also will not work when the tv uses it's own inbuilt digital Freeview receiver so it's both confusing and useless after the digital switchover.
Either leave the TV permanently set to ext and tell your gran to only ever use the Virgin remote to change channels, or be patient with her as she takes time to learn how to select between terrestrial, Freeview and Virgin.
It's less than ideal and when I worked for a tv rental company this kind of complication was a major pain for older customers (and younger non tech savvy ones!)
It may also be worth looking for a simplified universal remote control with clear buttons. There is one which has large buttons but the controller is almost the size of a sheet of A4 paper.
Nov 11, 2009 | Televison & Video
I want to connect a Virgin HD box to my Panasonic TH-42PV500B TV currently connected to a Panasoniv DVD recorder On Scart AV1. How do I switch between Virgin and existing equipment which I would like to...
what you need to do is obtain an HDMI cable for your Virgin HD box. Leave the rest on scart (you can probably even add a another box now that you've freed up one port). Basically just press the button on your TV remote, saying 'Source' and you can flick through all your scart soxkets and HDMI ports. Simples.
Oct 24, 2009 | Panasonic Televison & Video
Connecting a dvd 250gb hard drive recorder to tv and virgin box
Right then, on the back of the virgin box there are 2 scart outlets, connect one scart from the TV scart port to the scart in on the DVD recorder, then connect one scart lead from the scart out on the DVD recorder to the TV.
Find the DVD recorder source channel on the TV and then use the DVD remote control to find the digital input on the DVD recorder, this is usually AUX channel.
Post back if you need any more help
Good luck and thanks for using Fixya!!
Feb 22, 2009 | Televison & Video
JVC TH-A35 System Logo
90 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
