I have a Kenmore 110 20692 000 washing machine. Last week it stopped working, and wouldn't spin. It would go to that part of the cycle, but made a kind of grinding noise. I asked on fixya what the problem could be and was told it was probably a coupler. I followed the instructions to take it apart and found the coupler and sure enough, it was broken. I replaced it, but noticed that the oscillator would turn one way, but still locked when I tried to turn it the other way (the person from fixya said this was caused by a locking in the coupler mechanism before I fixed the coupler). I ran a test cycle and it filled with water, did the oscillating, but when it was going to go to spin, it just shuts down and doesn't even attempt it - I don't even get to where it was grinding before. Now I can't even turn it ahead in the cycle and drain the water - it's like everything past the first step is no longer working. Could this be another problem that started when the coupler went or is this a problem caused by my repairs? Any help would be appreciated!
  • scottedwards Aug 30, 2010
    would a bad lid switch also cause this? Mine wasn't working before, but was jimmied into a closed position. However, when taking off the cabinet I think it did get jostled. Could this be the culprit or are these two different symptoms?
    I actually think it was just the lid switch. It has been a problem in the past, and was kind of juryrigged to keep working, but when i removed the cabinet it got jostled a bit. I have pulled it apart and bypassed it by connecting the wires, and am doing a test cycle now. So far, I have spinning.
  • 10,865 Answers
Hello. Chances are likely that the coupler broke when the transmission froze up. Now your choice is to replace the transmission or replace this machine all together. IF the machine is over 3 years old, I strongly recommend replacing it. J.
Posted on Aug 31, 2010
  • Washing Mach... Master
  • 909 Answers
Normally that motor turns one direction for wash, and another direction for spin. Suggest you undo the coupling again and run the motor firstly in a wash mode. If all is well, forward dial to spin mode then watch if motor changes direction. If it doesnt, very possibly the timer is faulty. If it does change to the spin direction then your gearbox has a problem. Once the reverse direction comes into play, it is supposed to activate a series of gears in the gearbox which will engage the large drum into a spin direction. If there is a loud grinding noise then possibly a gearbox issue. email address is terfou@imaginet.co.za
Posted on Aug 30, 2010
We have a kenmore front loading washer that won't go in the spin cycle.
Try this site for answers. They have been very helpful for me. They also have parts I needed.
Apr 28, 2014 | Kenmore Washing Machines
Kenmore washing machine didn't spin @ end of cycle
If you tried a different cycle and it worked this means that the timer is probably bad on the main cycle that you use. If the machine does not spin on all cycles, then please check out the LID SWITCH.
Nov 12, 2009 | Washing Machines
Kenmore HE2 Plus Front Washer knocks very loud on spin cycle and a belt or something has been coming out in pieces for the last few weeks
I just took the back off my older kenmore front loader and discovered that the concrete counter weight had come off the drum and fallen to the bottom of the machine. Reattached it and knocking has stopped, lucky it didn't trash the machine as it is normally attached to the top of the drum.
Oct 13, 2009 | Kenmore HE2 Plus Front Load Washer
Will not complete a wash cycle or rinse cycle, stops short
I think it maybe your lid switch. If the lid switch is out it will not spin and sometimes spin or drain. can you give me a model number so that I can further assist you?
May 12, 2009 | Washing Machines
The washer does not spin during washing cycle or drain & spin cyc
I can a very simple part called the motor coupler...you can find the part at www.repairclinic.com. It costs 13.95. I am fixing my washing machine today, as this happened before and was the answer. Goodluck
Apr 11, 2009 | Kenmore 46462 Front Load Washer
Kenmore 80 Series - machine won't rinse or spin
Manually move the timer to the SPIN mode and turn it on.
If nothing happens, replace the lid switch.
With a model number I could be more specific.
Feb 27, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series - not draining
On your console there is two side panels that pop off from the top and two screws to remove and then swing the console back. You will notice a molex plug going into the washer on the right hane side. Unplug the machine and the top portion of that plug. Get a meter for continuity and if it beeps with a open lid or not when closed I would replace the switch.
Aug 05, 2008 | Kenmore 22422 Top Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Washing Machines Logo
168 people viewed this question
Top Washing Machines Experts
