Philips tv I have a philips tv model 55pp9401 the remote got broken so we bought a hormony universal 550 remote. we need to adjust the color theres a yellow and blue tint and everything in writing is showing double. P lease help
  • 121 Answers
The problem you are describing is your convergence ic's are bad you need to replace them both...you need 2-STK392-120's you can get replacements at this link i posted as well as picture installation instructions and free online tech support
http://servicemanuals.vstore.ca/
Posted on May 08, 2008
Can't get colors right projection tv
Go into menu with remote and select convergence--see if skewed will it adjust or not?
Apr 27, 2012 | Philips 55PP9401 55" Rear Projection...
We no longer have the remote for model 55pp9401 and we have a convergence problem what can we do
Here's the Philips support URL for your TV:
www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=55PP9401&slg=en&scy=US
PDF download of your Owners' manual:
http://download.p4c.philips.com/files/5/55pp9401/55pp9401_dfu_aen.pdf
Here's what Philips FAQ says about your convergence procedure:
Question How do I adjust convergence (align colors)? Answer Note: For best results, the Projection TV needs to be turned on for 15 minutes or longer before adjusting the picture tubes (convergence).
Press the INTELLISENSE button on the remote (under the flap). During the convergence process DO NOT press the INTELLISENSE button again and DO NOT move the Projection TV.
So, I think you're going to need to order a replacement remote.
search "replacement remote" at http://www.philips.com
May 13, 2011 | Philips 55PP9401 55" Rear Projection...
Intellisense button
If the model number on the set is 55PP9401/55 you have an interesting set----this model says Philips but was made by Hitachi---they made them for Philips for one year while Philips was gearing up to produce their own sets---very good set and is better than the Philips sets that came after it.
It uses (if it is this model) two STK-392-110 CONVERGENCE IC's----both need to be replaced and the set adjusted---no need for an original remote---with the set engaged in the convergence adjustment mode( there is a micro switch on the front of the main circuit board) A HITACHI REMOTE CAN THEN BE USED TO ADJUST THE CONVERGENCE. Hope this was helpful.
Aug 11, 2009 | Philips 55PP9401 55" Rear Projection...
Magnavox energy saver projection tv-cannot remove closed caption
If you can bring up the FEATURES menu and can navigate with the Harmony remote scroll down the the CAPTIONS options. If you can turn display OFF then you should be all set.
If you do not have the manual for this set you can see it at:
http://www.p4c.philips.com/files/5/55pp9401/55pp9401_dfu_aen.pdf
Feb 27, 2009 | Philips 55PP9401 55" Rear Projection...
Tv is showing red shadow
I understand that you already have 'universal' remotes but the link below refers to Philips brand remotes that may access the settings you now need:
Remotes
I can't say how responsive Philips is today but it might be worthwhile to email them with the model numbers of your set and the remotes offered above to see if they will let you kow if either of those will access the adjustment settings you need.
I wish the makers of those aftermarket remotes would introduce some honesty into their spiel by calling their NON-universal remotes 'multibrand' instead. I have a half-dozen so-called universal remotes in my junk drawer, including even a 'learning remote' that still doesn't program with the original.
Oct 27, 2008 | Philips 60PP9202 60" Rear Projection...
Need tv code for phillips model # pl5120 c121 for rcr311w i cant adjust color
There are a few codes you can try for the Philips TVs:
1002, 1003, 1004, 1008, 1012, 1019, 1062, 1068, 1069, 1075, 1076, 1087, 1219, 1238
To look up these and codes for other TVs, go here:
http://remotefinder.rca.com/default.aspx?site=rca
The manual for the remote can be found here (as of 06/07/2009):
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr311-manual.zip&area=other
Jul 19, 2008 | Universal Remote Control DIRECTV Universal...
Where can i buy remote control for phillips 55pp9401?
get a full universal at your local walmart for less then 20 with full menu and program functions, get a phillips brand and no programming required.
Mar 16, 2008 | Philips 55PP9401 55" Rear Projection...
Televison & Video Logo
94 people viewed this question
Top Televison & Video Experts
