Wash machine There is a washing machine for sale (ref above) but I want to know hold old this model is and what is the size of the drum (load?). Are they still available new and If so, how much very roughly would I expect to pay? Is this something you can help me with, please? Many thanks in advance. Gen
    Scholar:
  • 150 Answers
Model and make are not in your message
Posted on May 08, 2008
How do you remove inner drum on top loading LG Washer WT5170HV?
The whole top of machine must be removed.
unplug electronics and hoses remove upper splash ring remove cap in center of agitator remove bolt holding down remove .
remove inner tub Nut center tube should lift up and out.
next step if your changing shaft is all from bottom.
lot more down there. Take picture b4 and as you remove for ref. to resemble
Jul 03, 2016 | LG Wave WT5170HV 27" Top-Load Washer with...
Drum fallen to one side
I don't know which model you have, but there are plastic suspension pads that hold the tub level, if one of those wears out the tub will tilt. This can happen when you get a heavy load out of balance.
Jun 01, 2014 | Maytag Centennial 3.2 cu. ft. SuperSize...
Wash machine - DST10146P Problem - After switch on and without any load in the drum, the kgMODE indicator appear, and the level load indicator starts blink the 10% levels from the mini to the MAX. The LED...
THIS MAY be your defective part!
BE VERY careful handling this switch because it's quite delicate!
1885374 "PRESSURE SWITCH" $89.68
Use THIS LINK:
http://spares.bigwarehouse.com.au/index.php?cPath=64618_64688_109010
These YOUTUBE video MAY help you!
Here is another YOUTUBE that discusses "Pressure Switches"... and that MAY be your problem. KNOW this is general information and not specific to your Hoover!
Diagnosing Washing Machine Pressure Switch Problems
How to Resolve Pressure Switch Problems in Washing Machine
Hoover and Candy Washing Machine Error Codes
TROUBLESHOOTING Link:
Dynamic Model No DST10146P 80 Product Code 31003253
Another snip-it:
..."Kg MODE Indicator". On Cotton and Synthetic cycles, during the first 4 minutes of the cycle the intelligent sensor will weigh the laundry and adjust the cycle time, water and electricity consumption accordingly. ...
More: The intelligent KG Mode sensor weighs the laundry and adjusts the cycle time, water and electricity consumption to suit the size of the load. This gives you the optimum consumption even if you are only washing one shirt.
During the first minutes of the cycle, the "Kg MODE" indicator remain on while the intelligent sensor will weigh the laundry
• Through every wash phase "Kg MODE"
allows to monitor information on the wash
load in the drum and in the first minutes
of the wash it:
- adjusts the amount of water required;
- determines the length of the wash cycle;
- controls rinsing according to the type of
fabric selected to be washed it;
- adjusts the rhythm of drum rotation for
the type of fabric being washed;
- recognizes
the presence
of lather,
increasing, if necessary, the amount of
water during rinsing;
- adjusts the spin speed according to the
load, thus avoiding any imbalance.
Dec 25, 2017 | Hoover Washing Machines
A lot of lint left on the clothers after load finished. Rinsing twice more only helped a little. My machine is about 12 years old. Don't know model but it's a top-loading with mini-basket.
Have you ever cleaned the lint trap? many people do not realize that washing machines have lint traps too. It is usually located under the fabric softener cup in the agitator -- not sure on yours without model number. It has a lot of tiny holes in it that clog fairly easily. One trick to clean it is to put it down in the drum where the wash goes and run a wash cycle, but you may have to do a bit by hand as well. Hope this helps.
Feb 15, 2011 | GE Washing Machines
Bosch Maxx (ref WFL 2450). stopped during wash and switch on
Remove the front lower panel, screws underneath. Drain off water. Be prepared for more water. Check filter for clogging. Sometimes when the load is unbalanced & the machine cannot adjust the load it stops. To avoid this make sure your wash is mixed with big and small clothes.
If this does not work remove the rear panel & check belt, should have half inch ‘give’. Still not good, remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes, if it is any shorter than 5mm replace brushes.
Apr 01, 2009 | Bosch Washing Machines
Kenmore Oasis HE Top Load
there are 4 rods holding the drum up, check to make sure all 4 are attached.
Oct 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Lint on clothes
The lint filter should be in the agitator. Pull the softener dispenser off the top of the agitator and check for a filter. You might even find that the agitator shaft is very dirty. Put through a warm wash with a solution of 1 cup vinegar to one cup bicarbonate of soda and let it go through complete wash. This should solve the problem.
Oct 14, 2007 | Kenmore Elite 45986 Front Load Washer
LG WF-764STP
Remove the belt and check whether the motor spins and let us know with your result. Good luck !
Aug 16, 2007 | LG WFT1071TP Top Load Washer
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
