Question about Samsung SyncMaster 710N 17 in. Flat Panel LCD Monitor
Whener i connect it i get a blinking box with message "non optimum mode- reqired 1280X1024" the service centre guys says the board is damaged (of the monitor) and requires replacement what to do??
  • 11,361 Answers
That is the recommended native resolution for this monitor, do you have your PC video resolution setting to this number? If you do and it stills get this pop up then you may have problem in the logic board, I would also check the DC voltage to make sure it has clean DC feeding the logic board, it may be due to bad caps.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Please post back what you find.
Posted on Aug 30, 2010
My computer is on but all I see on the monitor is a floating box with the message "Not Optimum Mode Recommended Mode: 1280X1024 60Hz.
Try connect a different monitor on your computer and change the resolution to 1280x1024. After that, replug the new monitor and it should work.
Feb 28, 2011 | Samsung Computers & Internet
I have the same problem. I get a box with "not optimum mode. But what I need is a picture of the mainboard with the 50 ohm resistor between pin5 and pin6.
hello
I am a technician-informatic. I have repaired about 80 Lcd Samsung monitors with theese problems. I offer the repair manual.
Manual has been done with the experience of the repairing Samsung Lcd monitors. Manual was made by me and shows how to open monitor, how
to solve dark screen problem, how to check and replace capacitors, how to solve the problem non-optimal mode (without reprogramming MCU or
changing the main board) photo are included. 100% functional. The repair process is very simple 30-40min. (does not need a lot of
experience in electronics and expensive instruments) and is not expensive. With this manual you can solve problems by yourself and save
money.
"Not Optimum Mode 1280x1024 60Hz"
- The monitor turns on but turns off by itself, the LED blinks green.
- If you detach from the PC points to "control cable" the picture runs continuously in the vertical direction or presents while line , and
as soon as it is reconnected, the monitor goes off.
- The monitor does not turns on and dont dispaly anything, the LED blinks green-lit, if you detach from pc points to "control cable".
- The monitor turns on, works well some time, but after a window apiers "Not optimum mode. Mode recommended 1280X1024 60Hz"
- The monitor turns on, works well only with low resolution 800x600, when try to change a window that reads "Not optimum mode. Mode
the manual you can find on ebay (my ebay name is asnerejas123):
Samsung monitor repair manual guide 710n,913v,510n more
220498646211
Riparazione - repair Lcd Samsung monitor 710n,913v,510n
220498645860
Reparaturhandbuch für Samsung 710n,913v,510n und
Sep 14, 2009 | Samsung SyncMaster 710N 17 in. Flat Panel...
Samsung 713N screen goes black
OK. IN XP GO TO DEVICE MANAGER AND CLICK ON THE MONITER AND UPDATE THE DRIVERS.IF IT TELLS YOU IT CAN NOT FIND A BETTER DRIVER UNINSTALL..REBOOT AND DOWNLOAD NEW DRIVERS FROM CO. WEB SITE.RICHARDM69
Aug 31, 2009 | Samsung SyncMaster 713N 17" LCD Monitor
New Samsung monitor returns only a blank screen when turned on. what can I do?
hello
money.
220498646211
220498645860
Reparaturhandbuch für Samsung 710n,913v,510n und andere
220499443698
Feb 04, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
Samsung 710V Comes on for a second then shuts down
the fault is the backlight, Samsung has designed it as when one of the baklights are faulty the unit shuts down.
Sep 02, 2008 | Samsung SyncMaster 214T 21.3" LCD Monitor
Samsung Syncmaster 710n monitor - screen goes black for no reason. All cords connected properly. Computer works with other monitors. Switch on front of computer is on - green light on. Get floating...
in safe mode adjust the resolution lower than 1280x1024
then restart and then install the driver again the driver is crrupted than install the right driver problem could be solved
May 16, 2008 | Computers & Internet
Samsung 19" monitor 913n
screen has about 12 small opening page instead of a normal one page
Jan 11, 2008 | HP Pavilion dv9005us Notebook
Samsung 710N
hi, try with another crt monitor to check if the display card is ok..if that works fine then u will have to take it to the service center.. let me know..
Jan 10, 2008 | Samsung 710N V2 17" LCD Monitor
Samsun 710v not optimum mode problem
you must chang your Mainboard for LCD to fix it
Oct 03, 2007 | Samsung 710V 17" LCD Monitor
Samsung SyncMaster 710N 17 in. Flat Panel LCD Monitor Logo
49 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
