Question about Bosch Washing Machines
Suds or blocked pump - Bosch Washing Machines
  • mikerking Aug 31, 2010
    Thanks for your help. Found access to pump, behind removable front panel. Cleaned out some trash in pump and all seems O.K. now.
  • 4,323 Answers
Hi
To access the drain pump, remove the front of the machine. Remove the kick panel at the front bottom of the machine. The 2 screws need just 1 turn to loosen, use a flat head screwdriver. There are a couple of hidden clips on the Kick panel that secure it to the machine. These are located at the top edges of the Kick panel, and can be pressed on (by sliding a wide, flat knife between the top of the Kick panel) to release the Kick panel from the front of the machine. Now you’ll be able to see the screw cap for the drain pump, it is located on the left hand side. Before removing this cap make sure that you have a container and lots of towels to clean the water as there is a risk of flooding the floor with water. Clean the pump and your issue will be resolved now. please post back for more information. Hope this helps...
Daniel
Posted on Aug 30, 2010
ERROR CODE F09
A typical HE3 Kenmore Elite washer the F09 code indicates and overflow has been sensed. This can be because of suds or a failure of the pump or pressure switch.
Suds is a common problem with the newer 2X-3X super concentrated detergents.
A pump that is partially blocked might cause this error
Oct 06, 2014 | Washing Machines
The "SUDS" code appears at the end of every wash
If the suds error starts happening suddenly even though you used the same HE detergent and amount that you always have in the past, you probably don't have a excessive sudsing problem, caused by the soap. The most common problem relates to the pump. Some foreign item blocking the inlet of the pump. Foreign objects can make their way down to the pump and either clog the entrance or enter and damage the pump impeller.
Nov 10, 2012 | Washing Machines
Gives code f02 and sud
The F2 error codes means LONG DRAIN TIME and the suds code the washer detected water in tub after normal alloted drain time...so basically the F2&SUDS means the same thing. A lot of times when it does not drain fast enough,its caused by a blocked filter on the pump being biult up with debris. This tip i wrote will show ya how to clean the pump filter.
http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
GENE
Sep 21, 2011 | Maytag EPIC MFW9700S Front Load Washer
On a Kenmore Elite Model #11047781700 we keep receiving the error code SUD and F35. We are trying locate the drain pump filter. Could you please tell me where this item is located.
2 possible solutions:
1. Make sure small black hose connected to pressure switch is clear of obstructions by blowing through it
2. Replace pressure switch located at back top right of machine under top hood.
3. Make sure drain catch located at thebottom front behind the panel held in place by 3 screws is not blocked. It is the large white knob which can be removed by turning it counter clockwise and removing the tray to check for any items blocking it. Make sure you have towels in place to absorb any water when you remove drain catch
There are 2 videos on you tube taking you through these 3 steps
Jun 25, 2011 | Kenmore Elite 45986 Front Load Washer
Washer machine will not drain
Check for clogging in your drain hose, block inthe ddrain valve/ drain pump and foremost the voltage to the drain pump must be present when the machine program is reached.
If not the controller can be defective.
Sep 14, 2010 | Maytag Washing Machines
Suds or blocked pump for bosch washer
If suds put epsom salts in dispenser on rinse cycle,
this kills the suds instantly.most likely to be pump though.
Mar 18, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Washer is flashing the word sud
Hi, here is the meaning of the SUD error code and the corrective actions. If you have any other questions please feel free to comment. Mike
"Sud" SUDS LOCK (Overdose of Detergent detected during the Wash Cycle)
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
  • If too much detergent was used, run the unit through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
  • Check/Clean Drain Pump Filter of foreign objects
  • Check Drain Pump
  • Check Pressure Switch
  • Check CCU
Jan 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer will not drain or spin. It showa a "sud" error.
hello check the drain hoses make sure its not block check the pump
electrical wires make sure the pumps running check the drain pump filter if these do not work change the pump good luck
shaun
Mar 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Too many suds
Most probably a blocked or partially blocked pump.
Sep 18, 2008 | Fisher and Paykel GWL11 Top Load Washer
Aquasmart too many suds
means that the pump might be blocked and not drains too well
Please check this link for all drawings and or perts you might need. Please clean pump out first
LINK
Apr 30, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
114 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
