Question about Whirlpool ED5GTNXMQ Side by Side Refrigerator
Frig clicks then off runs a few seconds and off. I tested the compressor motor and I have 00 on the 3 prongs and no short to ground form the 3 prongs. I took the starter device off and it rattles took it apart and it is in peices inside. with the compressor showing 00 on continuity if I replace the starter device kit will this work????
  • Whirlpool Master
  • 43,501 Answers
No, if the compressor is giving you 00 then it is shorted internally and is no good... you will need to replace the compressor...
heatman101
Posted on Aug 30, 2010
I hear it starting up, then after few seconds it stops and the most left right light (ref temp 5) keeps blinking on and off. Please help xx
AT TIMES YOU MAY HEAR THE COMPRESSOR CLICK OFF AND ON OVER AND OVER. Signs of a bad start relay or capacitor. Check with an OHMS meter for continuity (ohms) and voltage, capacitor can be checked for Microfares. ( if in series with the windings)
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, somes located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur start winding, 1 goes to ur run winding and the center goes to ur ground or COM
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
God is so good: so this is why I give free advice so please thank him not me.
May 22, 2015 | Refrigerators
Makes a clicking sound about every 12 mins but is cooling okay and sounds normal
THE COMPRESSOR:
If you hear a clicking sound coming from the back of your refrigerator/freezer, then the problem is most likely the compressor, relay and or capacitor is overheating or not getting proper power and will not start.The compressor is the component on your refrigerator that allows your refrigerator to cool. If this component is not working properly your refrigerator will stop cooling. Most of the time the compressor is not the component that has failed.
You wills see 3 prongs coming out of compressor. 1 goes to ur srtart winding, 1 goes to ur run winding and the center goes to ur ground.
Apr 09, 2015 | Roper Refrigerators
Fan in freezer works-tested-but won't come on to pump cold air into frig
u MEAN U TESTED WITH METER AND IT HAS OHMS READING? SHOWING CLOSED CIRCUIT? BUT STILL DOES NOT RUN?
check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
Apr 06, 2015 | Refrigerators
Noisy when compressor starts
MAY BE LOW ON FREON OR;
THE COMPRESSOR:
Read more:http://removeandreplace.com/2013/10/31/fix-refrigerator-freezer-wont-cool-freeze/#ixzz3WDEo5NDJ
Mar 28, 2015 | Engel 43 Qt.Portable Freezer.
Started to be noisy when compressor starts up. Tried cleaning dusting motor area including fan. Seemed quieter but becoming noisy again
Mar 28, 2015 | Refrigerators
Clicking noise in bottom of drawer refridgerator. Power and lights go on and off
Mar 25, 2015 | Refrigerators
The refrigerator - both freezer and fridge - turn off and warm up and then start running again and cool down. When it is running you can hear the motor/compressor and when its not running it is silent. I...
are u saying its turning off and on more than each 8 hours? if so u need to check ur thermistors, ur conld control, and ur defrost timer with a multi meter for continuity and voltage in thermostat
to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Mar 03, 2015 | Refrigerators
Intermittent clicking noise on Maytag side by side built in fridge freezer
Feb 16, 2015 | Maytag Refrigerators
Why refrigerator compressor will not start?
Feb 14, 2015 | Kenmore Refrigerators
How to troubleshoot refrigerator compressor
May 26, 2014 | Samsung Refrigerators
Whirlpool ED5GTNXMQ Side by Side Refrigerator Logo
104 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
