Back to:
Tags:
Audiovox FPE1078 7.8 in. TV/DVD Combo
Still having issues
posted by carolaysedai on May 08, 2008
You posted a solution to my problem before with only being able to use the remote to turn on & off the tv, continuous channel searching when I switch to TV from DVD mode, etc. I don't have a cable box, it's just a cable line from the tv to the wall, and the cable people have checked and think it's not the cable, it's the tv. Any ideas? Once I tried turning on the power and clicking the tiny "program" button on top of the tv with a pencil, which got it back to normal for a week or so, but now I'm back to the same issues.
Thanks!
Carol
Comment by carolaysedai, posted on May 08, 2008
I'm having several problems with my tv. First, as of today I can only turn it on using the remote, not the power button on the tv itself. When I do turn it on, it goes automatically into DVD mode, but when I switch the mode to tv, it goes through a blue screen channel search, climbing into the 100s, briefly flashing a picture on channel 2, then goes back into the search endlessly. I can only turn off the tv at that point by unplugging it. Is it the tv? My cable? Please help!
Still need a solution for this problem?
Try our Premium Assistance plan
Solution #1 posted on Mar 21, 2008
accordianman
Rank: Wiz
Rating: 82%, 364 votes
What source are you using? If cable, you should only be able to pickup channel 3 or 4 if you're using the box. If there is no antenna, that would be the only other answer if the set checks out...accordianman
Thanks! How do I select CATV?
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
Not Rated (0)
accordianman
Rank:Wiz Wiz
Rating: 82%, 592 votes
Please refresh my memory; What was it that I had suggested originally?
Comment by accordianman, posted on May 08, 2008
Okay. It's coming back to me..Be sure that you have CATV selected as your antenna options, and then run a setup sequence (which I believe the set wants to do anyway) and see if that does it. If not, the TV will require what is known as a tuner pack, as this one might very well be toast. I hope this helps...accordianman
Pull up your on-screen menu and find the desired options you want. All the different options this set has to offer are done from the on-screen prompts....accordianman
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on still having issues:
I don't want to Accept this solution
Can you Help with these TV Combos problems?
TV Combos
Hi I want to add new channels to my (daewoo) 20 inch...
TV Combos
I have been getting a humming sound and I have to unplug...
TV Combos
Help, i need advice or an schematic diagram for an...
sd card reading problem.
I have had my tv for approx 2 years, I heard a noise and...
Loading problems.
Repair Service
Find TV Combo Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
