Question about Whirlpool Washing Machines
I have a whirlpool washer that is slightly more than one year old. Whenever I try to do laundry, water pours out from the base of the machine. I have checked all connections that are visible and all are tight. Can you suggest what may be wrong?
  • Whirlpool Master
  • 909 Answers
If a pipe is cut or has a hole in it,then water will pour out like you are describing. Take the back panel off and retry doing a wash. Look carefully andYou should soon see where the leak is comming from. Switch off fast and then pull the power (plug) out of the wall. Replace the faulty part then retry doing a wash.
Posted on Aug 30, 2010
Whirlpool washer rinses too many times!
The control board (machine electronic control) is faulty
Feb 06, 2016 | Whirlpool Washing Machines
Is there a way I can change the settings of Whirlpool Washer Model # CAE2743BQ, because this Machine has a very low level of water. Kindly teach us how to make the water plenty in the washer..
If you do not have owner's manual, try manualslib.com Double check the method for setting water level (load size). There may be an "energy conservation or water conservation" mode.
I would also take the purchase receipt to Home Depot and ask for help. If it is all machines, there may be a factory defect. Hopefully, you are within the factory warranty time.
Apr 01, 2015 | Whirlpool Washing Machines
I have the Whirlpool Topload Cabrio washing machine and it will be a year old on Jan. 15, 2011. It is really starting to stink up my laundry room. I have run the wash cycle through with distilled vinegar...
Here is what I do. I run "Tide Washing Machine Cleaner" thru the washer first with HOT water. Then, I recommend running a rinse only with hot water & bleach to rinse the washer out really well and don't forget to leave the lid opened when the washer is not in use.
Jan 07, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Suds and F35 keep shuting down my laundry day:(
Remove the service panel and see if the filter has something in it77cb04b.jpg2402fad.jpgf032166.jpg
May 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Help ! I own a Miele Touchtronic W1113. I put to0 much Zero liquid soap , using cold water . Now the machine flashes " Fault " for intake and drain . I opened the trap door and let the water drain over...
Sounds like you may have flooded the base of the unit and activated the float switch. Tip the unit forward slightly with a towel at the base and all the water will pour out. You should be right to run the unit after that and any other water inside will dry up. it won't rust as it is stainless steel inside.
Feb 15, 2010 | Miele Touchtronic W1113 Washing Machine
Fabric softener isn't dispensing
it may be all gooed up. try pouring some very hot water into dispenser (fill it right up). let sit for half hour then do a load of laundry.plz rate-bozcro
Sep 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Duet Front Load Washer WFW8300SW00 Problem: I am using HE detergent and using less than the recommended amount; however, there is always a small ***** of suds sitting on the seal when I open the...
If you have a water softener or very soft water, soap will suds up more than if your water is normal or hard, so you'll need to use less than recommended. Obviously soap breaks down the dirt, but the dirt also breaks down the soap, so if your clothes are not very dirty to start with, you'll need less soap than if they were more dirty. Soap can also be stored in laundry like towels and cleaning rags and when combined with the laundry soap will suds more. You can try raising the leveling legs in the front to tip the washer back. This will help the water drain back into the tub instead of pooling on the boot. You can also try using the 'extra rinse' option. Keep cutting back on how much soap you use until your laundry is not as clean as it should be. You might be surprised how little soap you can use!
Jul 21, 2008 | Whirlpool Washing Machines
Washing machine woes
Buy a new machine. You have used it well. After Two repairs I suggest replacements
Since you are not paying for water I would suggest a top loader. I have been Happy with Kenmore (Whirlpool in Kenmore skin) or look at a Speed Queen Top loader.
Dont over load your new machine, learn what it can and cant handle.
Best of Luck T
May 28, 2008 | Whirlpool LSR7333 Top Load Washer
Washing Machines Logo
12 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
