Question about Toshiba Satellite 1805-S204 Notebook
My display goes blank when booting-up or when returning from hibernation. I can get it back by moving the display fully open (flat) and momentarily pressing the "cover closed" switch located below the cover hinge at the top right-side of the keyboard. Sometimes it takes several pushes of the switch and seems to be getting more reluxtant to revive. Any ideas of what might be going on here? Any suggestions would be appreciated.
  • Anonymous Jul 04, 2008
    when booting I get a freezed screen and then it starts fading out and blank eventualy.. re-installed windows. it's fixed for awhile and then starts doing the same thing... what gives...
A bon me ma qu qet llaptop
Posted on May 08, 2008
I have a Samsung SuncMaster 940BW 19'' LCD Monitor. It's a geat Monitor in my humble opinion in everything, except that since i got it i have one problem with it, and it wasnt possible for me...
This is a common problem with monitors when changing resolution. What probably happened is you may have tried to change the resolution, or an application changed the resolution, to an incompatible resolution.
For example, if you have a tiny little screen it can't display that huge resolution that a 32 inch monitor has. So, your monitor is stuck in that wrong resolution.
To fix this problem, you need to boot into Safe Mode. Restart your computer, and as it is booting up tap F8 a bunch of times, and then select Boot into Safe Mode.
When it boots up, right click on the desktop, click Properties (Windows XP) or Screen Resolution (Windows 7). When the window pops up, click Settings (if on Windows XP, if on Windows 7 skip to next step). From this window, change the resolution back to the basic 800 x 600 screen resolution.
Now, reboot your computer normally. You should be able to see the desktop. Now, you can do the same thing that you did in safe mode and turn up your resolution. BUT, when you change it, if the screen goes BLANK again, DO NOT press anything. After 15 seconds it should go back, and you can try a lower resolution.
Hope this helps! Thanks for using FixYa.
Aug 27, 2011 | Samsung Syncmaster 940BW LCD Monitor
Blank computer screen 3 times out of 4 when booting computer
there must be the problem of your lcd backlight chek that properly by open it or tack it to the engg.near you.
Jan 27, 2010 | Samsung 226BW Monitor
Blank screen
Turn Hibernate off for one thing. Hibernation leads to registry problems and boot issues. Go to control panel > power options > hibernate tab > uncheck the box. Reboot the machine. If you want, the laptop will go into standby mode after a period of time and will wake up with a touch on the touchpad. Go back to power options and there are settings in there that you can tailor to your liking.
Sep 30, 2009 | HP Pavilion dv2000t Notebook
Screen goes blank after hibernation - Dell Inspirion 530 Vista
Turn off vista hybrid sleep and hibernation mode. It causes more problems then it helps.
Jun 25, 2009 | Computers & Internet
Video will not return after after sleep
This is a Hibernation problem,
Turn off your Hibernation settings in control panel
Power options.
choose a different Power setting.
You will not have the problem,
Alot of PCs suffer this problem
Regards
Richard.
Apr 25, 2009 | Computers & Internet
Canon DR7080 won't come up--
Sorry, but this one will require on-site service. From your description my guess would be home position or motor encoder fault, but even if I guessed right you still need a tech there to fix it.
Apr 04, 2009 | Canon Office Equipment & Supplies
PC won't wake up after Hibernate, Standby or Restart
You need to take off your hibernation.
In control panel display then screensaver.Then click power at the bottom of that screen.
You'll see a setting for system standby you can set that to never.At the top click on hibernate remove the check in enable hibernation.
Click apply restart and your system should work.
Jan 12, 2009 | IBM ThinkPad R40 2722 Notebook
No Display - Screen says "NOT SUPPORTED"
Turn your computer on.
When the boot screen cahnges to black start pressing F8
You should get a Windows startup screen
If you see the Windows Logo loading page, then hit the reset button and tray again.
On the Windows Start page, select Safe mode.
Press enter twice and Windows will load
Go into display properties (right click on the desktop and you will see it on the menu)
A box will pop up, select the last tab (Display Properties) there will be a slider on the left side. Move it left to around 800x600.
Select apply and then close the window.
Restart Windows normally and it should be fine.
If not, post back and we will try something else.
Hope it helps =)
Apr 12, 2008 | Computers & Internet
Will not record
the classic cdr201 will not record it will go to wait and return to cd status(blank cd etc) there is no led display of sound during this operation you can hear the audio for brief couple of seconds before it goes back to cd mode
Nov 28, 2007 | Classic Electronics CDR201 CD Recorder
Toshiba Satellite 1805-S204 Notebook Logo
78 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
