Question about GoVideo Go Video DVD/VCR Combo
The deck 2 does not open to eject tape. can this be easy to fix?
    Genius:
  • GoVideo Master
  • 1,550 Answers
Yes change the belt on the vcr motor charge
Posted on Aug 30, 2010
How can I fix my 2002 Honda Civic cassette player from ejecting cassettes. I tried a cassette deck cleaner and that gets ejected the same.
The auto-eject feature is normally triggered by the tape reaching its end. This causes the tape to tighten and then activates a trip lever that starts the eject cycle. Most auto tape decks that are not auto-reverse eventually have this problem. It is not usually the deck's fault, but it is with the tapes themselves. After many plays the tapes get wound too tight on the reels and drag, causing the auto-ejection. This is especially true with the thinner, larger tapes found in the C-90 and C-120 varieties. Try taking the tapes to a regular tape player and then fast-forward them from one end to the other and them a full rewind as well to loosen the tape on the spindles and re-distribute the tension. Hopefully this will work.
Sep 25, 2015 | Audio Players & Recorders
MHC1500 Sony tape player is stuck! got deck door open, but tape will not eject. does not appear to be any loose tape. How can I get the tape cassette outf?
Prying the door open is not the first thing that should have been done. The mechanism for the tape transport is having a problem in that it either need service or the belt is too loose. A Technician would open the deck get the mechanism in the stop mode and then eject the tape. Any other way just damages the unit and might make it unrepairable.
Feb 14, 2013 | Audio Players & Recorders
Sony TC WR565 dual tape deck. Both doors will not
you can not fix it without tearing it apart. if you do take it apart, try to get the front panel off. Hit the eject button and look for a lever that is stuck.
Jun 17, 2010 | Sony TC-WR565RM Single Cassette Deck
Can't eject tape from deck
On Sony DSR-80P error 02-221 and 02-291 is a problem with the tape pull-in or eject. Mostly the tape stickers are bad situated over the stripe-cover at the top, which should be moving freely!
Remove the stickers from the tape or put them lower on the case. If the tape is already inside the machine is unable to reject the tape - disconnect the machine from electricity to open it or call service...
greetings from berlin, matt.
Jul 05, 2009 | Sony HVR-1500 HDV VCR
I purchased a Nakamichi 480 tape deck from a seller on eBay. All the push buttons work OK except for the EJECT button. It will not allow the compartment to open where you insert a tape. The eBay seller...
Hi there
It is probable that the head assembly or pinch roller assemblies are not returning to their correct rest position. The arms that carry the pinch roller assemblies develop dried grease problems in the bearing/post they are mounted to that prevent their timely return and fouling the casette shell preventing eject. Check them by seeing if they are clearing the cassette shell, and are "sprung into the home position with out binding.
I have repaired scores of these decks over the years, and am happy to talk to you more about the problem. Thanks for using FixYa.
regards robotek
Jul 02, 2009 | Nakamichi Audio Players & Recorders
Sony Dual-Deck Cassette Player/Recorder, doors won't close
Are both sides not staying shut? If it's only one side, look to see if the latch is broken. You should see an arm move when you press down the eject button - while the door is open, press the eject button and see where the arm moves. You should see a hook that catches the door and keeps it closed. It could be broken, or just jammed. Look at the other side of the deck and see it it looks like it's working the same. Unjam the latch arm if it's stuck, or replace it if it's broken.
Feb 23, 2009 | Sony Dual-Deck Cassette Player/Recorder...
My handycam sony steady shot , the tape deck will not open
Try using the battery charger while attempting to eject it. The battery, although you may not know it, probably cannot supply the power needed to open the tape deck. If it makes a little Ding sound when you press the eject button, that means it is trying to eject the tape. Hope this helps!
Jan 25, 2009 | Sony Handycam CCD-TRV318 Camcorder
Tape deck won't open
If this is a deck where the tape slides in horizontally, like most car stereo tape players, you may have a broken or slipping belt. The fact that you "haven't used it in a long time" suggests a worn-out belt.
In my car stereo, the belt slips when it's cold and won't play or eject the tape. After a few minutes, the unit "warms up" and the belt starts turning. Then everything is fine.
I think we both need to replace our belts.
Nov 17, 2007 | Audio Players & Recorders
Tascam 102 mark 2 cassette
there is a mechanical problem in your tape deck. probably a losen rubber band. it clicks because the rubber is too lose to move the mechinal parts. so when you power off, it losen the whole machanical parts..it is very easy to replace..opend the deck and check it out..good luck
Apr 13, 2007 | Tascam 102 MKII Single Dual Cassette Deck
GoVideo Go Video DVD/VCR Combo Logo
26 people viewed this question
Top GoVideo Televison & Video Experts
 Grubhead
Grubhead
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
