Question about GE PTS22LHR Top Freezer Refrigerator
My refrigerator will NOT stay cold, the freezer is fine. The temp in the frig is around 40 degrees. What do you think the problem could be???
  • GE Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 30, 2010
Freezer temp cycles above freezing
If you have a frost free refrigerator then temp jumps as you discribe are somewhat normal during a defrost cycle. However it sound like your defrost temp may be getting too high. There is a limit thermostat on the freezer coils that keep the defrost temp from getting too high. The part is called a (defrost termination thermostat) and is a round disk about 1 to 1.5 inch in diameter clipped to the top of the freezer coils with 2 wires coming out of it. When cold, it allows power to the defrost heaters. At around 35/40 degrees it opens and shuts off power to the heater. 35/40 degrees sounds high for a freezer temp but that is behind the wall and only for a short time. Yours may be staying on too long or out of temp calibration needing replaced.
Mar 20, 2015 | Refrigerators
Freezer in the gararge redfrigerator quits working when outside temps get real cold
hello. this is a common problem. The thermostat for a refrigerator/freezer is in the refrigerator part. Normally the refrigerator is kept at around 40 degrees. The compressor turns on as required to maintain this tempearture. The evaporator coils are concentrated in the freezer side, so that the freezer stays at around 0 degrees while the fridge side is held at 40.
If the ambient temp is around 25 degrees, the refrigerator compartment will get below the setpoint of 40 degrees, and gradually continue down towards 25 degrees. The compressor will not have to run at all to maintain this. In fact, the compressor is designed not to run, once the refrigerator compartment gets below the setpoint, for fear of freezing the contents of the fridge.
The lack of circulating refrigerant due to the non-running compressor means that the freezer compartment will gradually warm up to 25 degrees.
If the unit were just a freezer, it would work fine in the unheated garage. If it were just a refrigerator, it would not run in these conditions, and the contents would eventually freeze, but it is otherwise OK.
Regards, Joe PS kindly rate my answer. Thank you.
Jan 19, 2010 | Refrigerators
Whirlpool frig. Freezer warm, frig seems ok.
Since the temperature is already 40°, the cold control is satisfied and will not run. Thus the freezer will warm up to 40°.
Jan 06, 2010 | Refrigerators
Freezer works, frig doesn't
there is a fan on many newer units that blows cold air from the freezer side to the frig. If that fan is not working, the frig will be cool, but not 34° like you want it.
Nov 25, 2009 | Frigidaire Refrigerators
Frig is staying at 64 degrees, freezer is very cold, it is a whirlpool made frig, under kenmore name
set freezer temp warmer, this allows more air into the fridge compartment, its opposite from hoe=w they look! and a common service call issue thats nuisance related
Aug 23, 2009 | Kenmore Refrigerators
Frosting up of freezer fan/fan runs continuously
Clean and check the seals around the doors, the unit is trying to compensate for temperature loss.
Jul 27, 2009 | Refrigerators
My Jenn-Air frig, model JCD2389G,isn't cooling. It's less than 7 years old. Freezer seems fine. Frig is set at coolest and still is only 55 degrees. Cleaned back of frig, what else do I check? thank you,...
Check the fan located in the freezer compartment.
This fan blows the cold air from the freezer into the fridge and is about 40 dollars for the part. Simple to fix too.
Gary
Jun 05, 2009 | Jenn-Air JCD2389G Side by Side...
We have a LG Two Side Fridge.
Look for the air ciculation regulator sliding vent between frig & freezer section open accordingly. Set both sides to #3 on dials if frig not cooling to less than 40 degrees, might need new cold/temp controller behind frig dial
Apr 30, 2009 | LG LRSC21934 Side by Side Refrigerator
Freezer is freezing but fridge is not cold as it was
Sounds like defrost timer is not putting the refrigerator in defrost every 8 hours. You freezer should be below -5 degrees. Also the condenser beneath the refrigerator possibly needs cleaning. First slowly turn the defrost timer clockwise until freezer goes in defrost. You should hear the sound of crackling noise in freezer after about one minute into defrost. If timer does not come out of defrost or does not turn itself then replace it. Let me know what you find, Thanks Sea Breeze
Feb 07, 2009 | Frigidaire FRT15G4B Top Freezer...
GE PTS22LHR Top Freezer Refrigerator Logo
157 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
