Question about Electrolux Poulan Bar & Chain Oil 12 each
I have a McCulloch Electrolux ES414 Eletric chainsaw the operating manual for which I have misplaced. I have looked on the internet under McCulloch and Electrolux for this and I could not find any informattion for this, nor any source for spares. Is there any other name I should search under for this? Any help in finding information will be gratefully received!! Regards, Roy Abey, London W4. (email: abey@heathfield.org.uk)
dontbother10
  • 2220 Answers
SOURCE: McCulloch Mac 10-10 LightWeight Chainsaw
It is listed twice with different data.
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/be486f1cb246b9fe88256b62001d1279?OpenDocument
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/45ae8764a038011288256b61001b21f9?OpenDocument
Recommended oil mixture both is 20:1. Sounds like a great way to foul plugs and score cylinders to me.
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine.
Try here for your manual. Please do a search first, it has probably been asked and answered. You need only query the person that has your manual.
Beg for manuals thread (ArboristSite) (free to join)
http://www.arboristsite.com/showthread.php?t=72322
I think this answers all your questions. HTH
Lou
Posted on Oct 11, 2009
  • 110 Answers
SOURCE: How to test magnito on McCulloch 310 chainsaw
The only way to test an ignition module on any small engine is on the machine. Simple and easy.First remove the spark plug , then remove the wire that connects the module to the kill switch, its located right next to the plug wire above the laminations. Put a spark tester in the pkug boot and ground the other end. Pull the rope and look for a spark. Its that simple. If you have a spark, check the switch and wire, if you dont,check the grounding screws that hold the module to the block for a clean contact.If you still have no good spark its time to replace the Ignition module (coil).If you dont have a spark tester, ask someone dumb enough to hold it. If they jump and cuss you out you know you have a good spark
Posted on Nov 15, 2009
SOURCE: NEED INSTRUCTION MANUAL FOR MCCULLOCH 838 AS CHAINSAW
Found it at
http://www.mcculloch.biz/int/support/owners-manuals/?query=MAC+838&types=O
Posted on Apr 16, 2010
Testimonial: "Thanks exactly what i was after,thanks again."
  • 122 Answers
SOURCE: Need a manual for a McCulloch SE2000 Chainsaw
http://www.mymowerparts.com/pdf/McCulloch_Parts_Service_Repair_Manuals/Gas_Powered_Chain_Saws/McCulloch_Gas_Chain_Saws_Parts_Manuals_11_600032_71_Silver_Eagle_2014_IPL_211229_01.pdf
Posted on Feb 08, 2011
  • 7 Answers
SOURCE: Somehow the clock on my
Have you tried electrolux direct, they should have a manuel, check their website.
Hope this helps
Posted on Apr 21, 2011
Hello, I am trying to find a user manual for a McCulloch XM-40 chain saw I just purchased from a friend
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
May 30, 2013 | McCulloch Garden
McCulloch 120 Chainsaw Owners Manual
McCulloch Manuals
Operators Manuals: are much more difficult. I have dialed this number many times (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it! If unsuccessful with McCulloch try here:
Beg for manuals thread (ArboristSite - free to join).
Include your e-mail address in your request or it most likely will not be answered.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 20, 2010 | Standard Oregon Chainsaw Chain For...
I am trying to obtain a copy of McCulloch 338 Chainsaw Manual
McCulloch Manuals
Illustrated Parts Lists: (IPLs) are fairly simple, on the underside of McCulloch saws is a black and yellow tag; the upper number (“Power Mac 320” 600021H) is the model, below it a serial number (11-18555). These 2 numbers are combined to create an IPL number (“Power Mac 320” IPL number = 11-600021H). The IPL number can be used to find the correct IPL for every McCulloch parts supplier I have found. If the parts supplier only list part numbers the proper IPL is the source for the part number.
Beg for manuals thread (ArboristSite - free to join). Please use the search function first, it has probably been asked and answered.
Include your e-mail address in your request.
Apr 07, 2010 | McCulloch Garden
Looking for a repair manual for a McCulloch 3216 gas chain saw.
What exactly do you want to do? You must purchase a repair manual from somewhere. I can provide an Exlpoded parts list for free. I can offer advise on a procedure for free. To do anything beyond try an Internet Search for "McCulloch 3216 Chainsaw Repair Manual" I need to know what you want to do.
Mar 11, 2010 | McCulloch Garden
I need a mamual for McCuloch chain saw CS 38EM
A more common model number is MS1838AV. Your IPL follows:
Chainsaws 32cc-35cc-38cc Anti-Vibe
Beg for manuals thread (ArboristSite - free to join). Please use the search function first, it has probably been asked and answered (I did not get any hits).
http://www.arboristsite.com/showthread.php?t=72322 HTH
Lou
Feb 17, 2010 | McCulloch Garden
Mcculloch 14'' ms1436nav. chainsaw I need an owners manual. I can find a parts list but I want the actual owners manual
Afternoon Jaches; Mac Operators Manuals are hard. Please try here if enough of us try maybe it will be fixed.
McCulloch Manuals
Lou
I searched for 1436, Mac 1436, McCulloch 1436, & MS1436NAV without a hit. Post your need someone may answer. This is where I got my Mac 110 and Power Mac 320 (through a contact made on FY) operators manuals. Good Luck
Nov 28, 2009 | McCulloch Garden
Looking for an owners manual for McCulloch Chainsaw MAC 130
McCulloch has traded hands so often lately Operator's Manuals are hard to find. You should be able to get some help here:
Normal business hours EST
1.800.521.8559
Tell them up front it is a chainsaw, They won't be much help but if enough people inquire perhaps they will improve. Please have saw within easy reach before dialing.
Once frustrated there, go here:
Do a search if not already listed post an inquiry, someone always helps.
An IPL can be found here:
The model number is usually on the bottom of your saw with the serial number. Precede the model number with the hyphenated number from your serial number.
HTH
Lou
Nov 07, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
I need a user manual for a McCulloch PM 310 chainsaw. 2.1cc,electronic ignition, 16 inch bar.
I did a search and got many hits for Stihl MS310 I didn't see any for a McCulloch 310 here:
I tried the official McCulloch site yesterday and got nowhere. GL
Lou
Oct 20, 2009 | McCulloch Garden
McCulloch pro/mac 10-10 chainsaw owners manual & gas to oil ratio?
I have an old McCULLOCH MAC 10-10 chainsaw that takes 40-1 gas. Take the metal air filter cover off, and look on the inside of it, it should tell you all the info you need like starting it, what kind of gas etc,etc
Oct 03, 2008 | Garden
Electrolux Poulan Bar & Chain Oil  12 each Logo
289 people viewed this question
Top Electrolux Garden Experts
Phil Walker
Phil Walker
John
Are you an Electrolux Garden Expert? Answer questions, earn points and help others
