Question about Whirlpool Washing Machines
I'm getting a F 51 code during the washing cycle and does not clear.
  • 4,323 Answers
Hi
F51 error is a rotor position sensor error. This is a hardware error either due to a faulty rotor position sensor or due to a faulty control board. Motor is located directly underneath the tub. The RPS board is mounted on the right side (follow the brown wires) and under the motors rotor disk. An Allen wrench is used to remove the rotor and then the four bolts holding the motor stator to the tub can be removed. You would need to check the motor by running Motor test. Please follow the steps from the service manual given below---
1. Unplug washer or disconnect power.
2. Check to see if basket will turn freely.
3. If basket turns freely, go to step 4. If basket does not turn freely, determine what is causing the mechanical
friction or lock up.
4. Remove the console to access the machine/ motor control assembly.
5. Visually check that the P5 and P10 connectors are inserted all the way into the machine/motor control. If visual checks pass, go to step 6.
If visual checks fail, reconnect P5 and P10 and repeat step 1.
6. With an ohmmeter, check for 16 ohms resistance at the P5 connector between pins P5-1 and P5-2, and also between pins P5-1 and P5-3. Also measure the resistance at the P10 connector between pins P10-1 and P10-7 and verify that the resistance is within the range.
If the resistance is correct, go to step 11. If the P5 connector resistance is much higher than 16 ohms, or the P10 connector resistance is out of range, go to next step.
7. Tilt machine forward to access the bottom of the machine and the drive motor area. See Figure 1 on page 6-13. Remove the motor bolt, then the motor cover to access the motor connections.
8. Visually check the mounting bracket and electrical connections to the motor and rotor position sensor board. If visual check passes, go to step 9.
If visual check fails, reconnect the electrical connections, reassemble stator and motor cover and repeat step 1.
9. With an ohmmeter, check for continuity between all pins on the P10 machine/motor control connector and the motor rotor position sensor (RPS) connector. See Figures 2 and 4, pages 6-13 and 6-16. If there is continuity, go to step 11. If there is no continuity, replace the lower machine harness.
10. With an ohmmeter, check for continuity between all pins on the P5 machine/motor control connector and the drive motor connector. If there is continuity, replace the drive motor. If there is no continuity, replace the lower machine harness.
11. The drive motor and lower harness are good. Replace the motor RPS board and perform the Diagnostics test in step 1 to verify repair.
12. If the Diagnostics motor test in step 1 failed, then the machine/motor control has failed: Unplug the washer or disconnect power. Replace the machine/motor control assembly. Perform the Motor Diagnostics in step 1 to verify repair.
Please post back if you need more details. Hope this helps...
Daniel
Posted on Aug 30, 2010
Can you tell me what e6 on the display means as the machine wont work when this shows
Not sure of the make/model, but with Samsung washing machines that usually means 2 things. If you get it when entering the spin mode and the system stops and displays the code, the water heater is heating too quickly. Press the power button once to clear the code and finish the cycle before repair.
If you get the E6 during the spin cycle that can mean a problem with the main controller board.
You can keep resetting to get past that code but if you continue to get it during a spin cycle or part of the laundry where hot water isn't used, then usually that controller board is bad.
Good luck.
Apr 08, 2015 | Washing Machines
Hi My F&P washer has been doing a error 51 for a couple of weeks, havent had a chance to get someone to kook at it, I stop it and restart it and it washes all the way through the cycle only did this on...
Error code 37 indicates a blocked or not working drain pump but the slight burning smell likely indicates a burned out drain pump motor. Do not use the machine unless the drain pump problem is addressed as it will result in the damage of the motor controller module. It has been found that electrical problem in the drain pump motor leads to the burning out of the motor controller module.
Error code 51 indicates a blocked or damaged diverter valve. It is where the drain pump and the recirculation pump inlet hoses are attached from. It works in directing (diverting) water to the recirculation pump during the wash stage and to the drain pump during the drain and spin stages. Click on the link below for the troubleshooting details of this problems.
Troubleshooting Fault Code 37 on Fisher and Paykel SmartDrive and EcoSmart Top Load Washing Machines
Mar 17, 2011 | Washing Machines
During a normal wash cycle, the error code FH occurs. The owners manual says inlet problem. All water pressure is good and inlet screens are clear. Drain function appears to work well. Repair guy came...
If the flow meter does not register 10 and 1/2 gallons of water in 8 minutes the FH code appears.
Could be a bad flow meter, sensor, wiring harness is loose or a bad CCU Central Control Unit.
At the RINSE cycle if water enters the machine you must time the water fill for 8 minutes or less.
If water does not enter the machine suspect the CCU as bad.
Jan 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a Kenmore Elite HE 4t front load washing machine. Code F ud is currently flashing and the door won't open. I've tried canceling but it just beeps and keeps flashing this code.
Remove the bottom panel. The tech sheet is located beside the white box to the left.088d3fc.jpg It gives diagnostic directions and failure codes. Suggest you clean the dispenser area up04f0b28.jpg and use the correct amount of HE detergent.
Seems to me like that is a suds detect:All front load washers require "HE" detergent (a low suds type detergent).
There are three commonly sold concentrations of HE type detergent.
HE : (2) Tablespoons Per Wash Load
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated) : (1) Teaspoon
Most consumers follow the directions on the bottle or box of detergent--which is normally the correct thing to do. However, the amount recommended in nearly all brands of HE detergent are excessive & incorrect.
Additionally---using the correct amount of HE detergent will end issues with:
1) Musty Odors
2) 'LE" Errors (that can cleared by unplugging the washer)
3) L-O-N-G cycle times (longer than time displayed).
A 51 minute cycle can take 120 minutes to end.
4) Insuffificent Cleaning Results
5) Small water leaks behind the washer at the air vent.
(Suds oozes out during the spin cycle)
May 19, 2010 | Kenmore Washing Machines
Fisher&Paykel Intuitive eco IWL 16 Auto washer Fault code 51
Our washer did the same but it was after I took the excess drain hose and pushed it into the drain in the wall. I thought it looked "more tidy" In doing so I created a siphon effect. Once I pulled the excess hose back out it was fine.
Jan 23, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Kenmore Oasis Washing machine makes noise during Spin cycle
with the machine empty see if you can lift up only the tub and see if it drops down.check to make sure there is nothing between the tub and outer tub have you gotten an f-51 error?
Nov 11, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
41 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
