Question about Hayward SAND FILTER, PRO SERIES
Inground with hayward pro series we replaced lateral and sand all was fine 2 months have passed and now i have sand in pool again
    President:
  • Hayward Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
First of all, are you certain it is sand? We have received many a phone call claiming sand is back in a pool only to find yellow algae instead. If it is sand again you will need to look at the lateral assembly again. If you didn't add the sand correctly last time you may have cracked a lateral and it has now moved enough to allow sand out. If it is only a small amount of sand inspect the bottom of the multiport valve. Backwashing can bring a small amount of sand into the valve and if you do not rinse the valve following backwash you can get small amounts of sand in the pool.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Sep 05, 2010
Hayward pro series s244 im getting large amounts of sand in pool and the system is drawing lots of air what could be wrong
Either broken lateral drain assembly or the manifold.
If fairly new filter, it could be that you have overfilled the amount of sand, as it is too close to the bottom of the variable position Multiport filter valve.
Hayward SX244DA Lateral Assembly With Pipe
May 24, 2015 | Hayward Industrial Products Hayward Pro...
After backwashing dirt and sand blow back into the pool...the laterals look fine and sand was replaced 2-3 years ago
make sure the spider gasket in the multiport is not damaged or out of place. Also, make sure the spring is not cracked and the spider gasket seats well when it's on filter mode. If the laterals are good, this is the most likely problem.
Aug 23, 2010 | Hayward SAND FILTER, PRO SERIES
I have an inground pool with a Hayward S220T Pro Series Sand Filter. During normal operation, I am getting sand in the pool, through the inlet vents. I am wondering what the problem could be. I suspect the...
You would be correct; replace them with part number SX220DA and you should be all set. If the sand is older than 3 seasons, replace it too while you have to empty the filter.
Aug 23, 2010 | Hayward S220t Top Mount Pro Series Sand...
I recieved a Sp 0711-A13 Hayward Pro Series sand Filter and I have no idea how to hook it up. What are the requirements to attatch it to my above ground pool? There is no paper work.
you can go to http://www.haywardnet.com and get all the info you need. You can download a manual there. Go to products, and then above or inground and then on literature&manuals
Jul 23, 2010 | Hayward SAND FILTER, PRO SERIES
I need to change the sand in a hayward model 711 sand filtration system. Are there any instructions for this out there?
While there is a model 711 Hayward Valve assembly, the actual filter is a different model number. You might be able to find your model here...
http://www.haywardnet.com/inground/products/filters/sand.cfm
Apr 08, 2010 | Hayward SAND FILTER, PRO SERIES
We have found sand in the bottom of our inground pool we have a hayward pool sand filter what could be the reason
have you added sand to filter if so may be to much make sure that handle is in the right position check by changing setting several times to make sure sprocket under handle is not damaged sounds likeit is not seated
Jul 14, 2009 | Hayward SAND FILTER, PRO SERIES
When vaccum dirt, comes back in thru jets. \have a hayward filter
Do you back-wash your filter regularly?
Sound like dirt build up.
Jun 29, 2009 | Hayward SAND FILTER, PRO SERIES
Vari flow is on filter but dirt is passing into pool.
You can replace the spring inside if it is too loose, however you are unlikely to see damage on laterals. It only take a couple thousanths of an inch wear for them to allow sand and/or dirt past.
Jun 12, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward SAND FILTER, PRO SERIES Logo
135 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
