Question about Car Audio & Video
Rear Speaker Vibrations
Harmonic vibrations from radio stations and cd
  • pumdavid14 Dec 12, 2008
    need a speaker box specs for this product having problem building
    a box for it
    Genius:
  • 1,224 Answers
Just right off hand does your rear speakers have a port so that air traped can be released if you port your box sound would get better
air inside of a speaker box has no where to go so it bounces off the speaker makin it vibrate out perfect harmony
also some stations and cd's can have a bad tune too them or signal which can give distortion greatly not appreciated sound
but i would go with the port suggestion first
when i built my first speaker box from scratch i found out the smaller the box the more air would dammage the speakers so i ported the boxes sound increased so much better
bigger the box better the air flow and bass
Posted on May 09, 2008
How to remove the harmonic balancer on a 2005 x5 4.4l
If you are removing the harmonic balancer for repairs, you will need to remove the engine and use a harmonic balancer bolt puller.
Do not try to remove this and run the engine. This will cause crankshaft failure due to the engine vibrations caused by the firing cylinders.
Jul 29, 2016 | 2005 BMW X5
How to replace a Dorman Harmonic Balancer on a 2001 Chevy venture van
What is a Harmonic Balancer?
The Harmonic Balancer, or vibration damper, is a component connected directly to the front of the engine on the crankshaft. Its sole purpose is to reduce torsional vibrations created by the engine as the cylinders fire.
What causes Harmonic Balancer failure?
There are a variety of possible causes for balancer failure. Most common among these are heat stress, wear from road salt, oil leak, or ozone attacking the rubber components, damage inflicted by road debris, crankshaft failure, stress from integrated drive pulleys, and stress caused by loads from other devices such as power steering pump, AC compressor, alternator, air pump, and water pump.
Jul 18, 2015 | Cars & Trucks
Why is the crank pulley dampered?
No, you do not want to replace the crank pulley with a solid one. The hub is also know as a Harmonic Balancer. The explosions that happen inside of your engine cause vibrations or harmonics, the balancer greatly reduces these vibrations. Without the ruber insulating ring the harmonics can cause part failure at certain frequencies.
May 28, 2015 | 2006 Mahindra Scorpio 2.6
Hi i have a 95 buick lesabre i bought from a friend everything works great sides the radio i have an after market stereo jvc model no kd-g320 not sure witch color the antenna wire would be car has a power...
Antennae wire and other wires for the stock stereo are listed below:
1995 Buick LeSabre Stock Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Orange
Car Radio Ignition Switched 12V+ Wire: Yellow
Car Radio Ground Wire: Black/White
Stereo Radio Illumination Wire: Gray/Black
Stereo Radio Dimmer Wire: Brown/White
Stereo Radio Antenna Trigger Wire: Dark Green
Stereo Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 5 1/4? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Front Speakers Location: Doors
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6? x 9? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
Feb 19, 2015 | 1995 Buick LeSabre
Harmonic body vibrations at highway speeds
Check engine mounts. If it is a rear wheel drive or 4 wheel drive- inspect driveshaft(s) for damage or missing weights. Also check universal joints for wear, and the rear driveshaft slipyoke for leaks and wear. If there is a leak, the rear seal and bushing should be replaced.
If front wheel drive, inspect drive axles for damage, and inspect the steering components for damage or wear.
Jan 24, 2012 | Toyota Highlander Cars & Trucks
Vibration when idling in Drive. Vehicle idles fine in all other gears.
VIBRATION CAN BE CAUSED HARMONIC CRANKSHAFT BALANCER.BAD TORQUE CONVERTER ON TRANSMISSION CAUSE VIBRATIONS.
Apr 19, 2010 | 1999 Oldsmobile Alero
The clarion cz209 receiver has two constant 12v yellow wires, which one do i connect the constant 12v on the wiring harness for my 1995 jeep wrangler?
do u have a red as well or just two yellows if so it trial and error connect one to the constant and one to switched then program your radio channels then turn the ignition off then turn it back on if the radio stations stay then you have the right wire if they dont then switch the two yellow ones around
hope this helps pls rate
oh here's a wiring diagram for your car too
1995 Jeep Wrangler Car Stereo Radio Wiring Diagram.
Car Radio Constant 12V+ Wire: Red/White
Car Radio Switched 12V+ Wire: Purple/White
Car Radio Illumination Wire: Blue/Red
Car Radio Dimmer Wire: Red/Black
Car Radio Antenna Trigger Wire: N/A
Car Radio Amp Trigger Wire: N/A
Front Speakers Size: 4′ x 6′
Front Speakers Location: Dash
Left Front Speaker Wire (+): Gray
Left Front Speaker Wire (-): Yellow
Right Front Speaker Wire (+): White/Red
Right Front Speaker Wire (-): Brown/Red
Rear Speakers Size: 4′
Rear Speakers Location: Rear Roof
Left Rear Speaker Wire (+): Gray/White
Left Rear Speaker Wire (-): Brown/White
Right Rear Speaker Wire (+): White/Black
Right Rear Speaker Wire (-): Brown
Sep 08, 2009 | Clarion CZ209 Car CD/ MP3 Player
My saturn vue radio does not work. CD player works
it probably in the radio it self .some of have 2 fuses check them.better check all fuses. good luck
May 09, 2009 | 2004 Saturn VUE
This is a 1974 charger,360 ,4bbl,auto-problem is engine vibration. engine is running good, butvibrates almost like a miss,noticeable even in neutral, but more noticeable as the rpms are higher.when...
vibrations over 55 mph are usually balance related (tire balance, drive shaft balance, motors)
vibrations at lower speeds are usually mechanical (bent rims, out of round tires, bad tie rods)
Therefore the suggestion for checking the harmonic balancer is perfect in your case.
Thanks
May 09, 2009 | Dodge Charger Cars & Trucks
Speaker Pop when i turn on or change tune on radio
the speaker is probably worn is it factory is the speaker wires crossed need more detail
Mar 09, 2008 | Sony CDX-GT710 CD Player
Car Audio & Video Logo
341 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
