Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
It is saying LFduring a wash cycle - Whirlpool Cabrio WTW6600SBT Top Load Washer
  • 347 Answers
LF is for long fill . First thing to check is turn off the water supply hot and cold to the washer. remove the fill hoses from the back of washing machine.looking at the hose inlets on the machine you will see a small screen in each opening with a small pick or other small tool carefully pry out the screens and clean them in the sink. then reinstall . Do not leave out or damage to the valve could result ..The cold water side will be dirtyer than the hot because most of the debris in the hot water side is caught in the hot water heater.. Let me know if you continue to have a concern
Posted on Aug 30, 2010
Machine starts to fill with water, then stops and drains water. This process continues over and over, never moving onto a cycle. I have tried resetting and unplugging at the wall to reset but no luck
sounds like a bad control board issue or timer. would say the water pressure switch but that only tells it went to go into wash cycle but not start the drain process? since its going to drain cycle b4 washing I say timer sending wriong signal
Feb 23, 2015 | Washing Machines
My washing machine only spins on the normal cycle, no spin at all on the gentle cycle. What do I need to replace?
your motor of ur washing machine have some problem , i hope so u go to a washing machine or manufacturer feed
Oct 14, 2014 | Washing Machines
How do I get the Clean cycle
You could just try doing a hot wash with no clothes in & some bi carbonate soda.just to flush the machine.If your problem relates to the water not pumping out then the pump is probably blocked & thats why its saying clean me.
May 30, 2010 | Fisher and Paykel GWL11 Top Load Washer
Dishwasher does not wash
If you are saying that in the wash cycle it fills and then stops it could be that your water temp is too low. Some models will stop to heat the water in the main wash before going into the agitate mode.
Apr 07, 2009 | Dishwashers
Not washing
helen going by what you are saying i would say its the program cycle switch needs replacing,adrian
Jan 13, 2009 | Bosch Classixx WFL 2066 Front Load Washer
END OF CYCLE ALARM
The manual on my Bosch 500 plus 4.2 says to select a cycle and then push and hold two option buttons until you hear the beep to turn off the audible end of cycle alarm. Hope this works for you! P.S. It says not to try this with a load of laundry in the machine.
Jan 08, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Washing machine
bottom right corner behind the little door
Sep 27, 2008 | Whirlpool AWM5125/1 Front Load Washer
Washer keeps beeping
HATE TO SAY IT BUT THE BOARD WOULD NEED REPLACEMENT.BEEPING NORMALLY INDICATES A FAULT CONDITION WHICH WOULD STOP THE CYCLE(WASH) OR THE COMPLETION OF A CYCLE.
Jun 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
63 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
