Question about Maytag Neptune MAH5500B Front Load Washer
My Neptune MAH5500BWW washer makes a loud noise while spinning. Sounds like whatever is supposed to stabilize the movement of the drum is either out of place or broken. Please advise.
    President:
  • 670 Answers
If it is making a thumping noise when spinning, it could be that the spider arm supports are broken. It is expensive to repair. Get a few estimates, but depending on the damage, could cost more to repair than buying a new washer. Sorry.
Posted on Aug 30, 2010
Maytag neptune front loading washer
What is the model # of your machine???? The loud banging noise sounds like the loads were getting unbalanced. This is the most likely since i have no problems with the suspension all of a sudden not stabilizing tub properly. If the washer was moved or transported than that would make more sense to me. please provide as much info as you can. Try doing a load of 10 towels. Let me know how that does and with the model # i can help with pulling some diagnostic codes
Oct 02, 2007 | Maytag MAH6500 Neptune Front Loading...
Maytag Neptune - MAH5500BWW makes loud, loud noise during spin cycle. What parts are necessary to repair the unit? I assume there are bearings and seals needed. Thank you.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
May 26, 2011 | Maytag Neptune MAH5500B Front Load Washer
Model MAH5500BWW Why after I am all done with the wash and have everything unloaded can I hear water below the tub when I turn the tub manually? This is at all times.
This is not water that you hear. It is a form of liquid ballast that stabilizes the drum and counterbalances the weight of the clothes when the machine spins the clothes dry.
Aug 18, 2010 | Maytag Neptune MAH5500B Front Load Washer
My washer sounds like an airplane taking off when in spin cycle. It is really loud.
its probebly the main bearing. disconect the power and remove the back. then slide the belt off the big pulley. if you see alot of brown splatter you know its the bearing.if not with the belt removed go to the front and open the door spin the drum fast, if it makes the same noise its the rear bearing.
Jan 15, 2010 | Maytag Neptune MAH5500B Front Load Washer
Makes a very loud sound when in the final spin cycle. Model MAH5500BWW
The sound of the tub spinning is a smooth and not ruff sound. and with speed it sounds like a 747 taking off ( when your inside not outside ) when the brgs go bad it will sound like a train on the tracks when your waithing to cross. ( very loud as it speeds up and very ruff. if you remove the 4 screws in the back can ck just below the center shaft. there may be brown water stains on the base frame . / water has got in the main brg . and the brg's are failing . hope this helped. mm. ( could be the drain pump / ck for coins ect. drain pump runs just before and during spin/ but not soloud like brg's.. **** .
Dec 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
When spinning washer making an unusually loud sound. Sounds like a bearing. Can you confirm?
Does it make the noise when spinning the drum by hand? If so, chances are you're right, the bearing is shot. No way to confirm without taking it apart and isolating the shaft and bearing then checking for noise or play. Good luck.
Aug 11, 2009 | Maytag Neptune MAH5500B Front Load Washer
Loud whining noise when my washer is spinning
could be two things
1) thrust bearing
2) transmission
Jun 11, 2009 | Maytag MAV6200 Top Load Washer
Maytag Neptune makes loud drums like sound 5 min before it stops.
its probably because of the way the clothes are in it. you have to make sure the clothes arent leaning to one side and that they are evenly set up. otherwise when it goes into the spin cycle itll lean and hit the side of the washers inside and make it shake and do what you said it was doing.
Jun 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
583 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
