Question about Sony Hi8 Cleaning Cassette / Head Cleaner Hi-8 Tape
While playing an 8mm tape that was recorded, I have the problem where there was no sound from the camcorder and the picture was grainy.
    Novelist:
  • 169 Answers
Sounds like the record head(s) may be very dirty, check them, they should clean and shiny if dulled an brown with tape residue, you can clean them with a lint free cloth and head cleaner. tape based cleaners cassette may not be good enough if the heads are very dirty. ensure you give the heads enough time to dry after cleaning 2 mins should be good then run a test record to check them.
hope this helps
thanks for using FixYa
Posted on Aug 30, 2010
I have a GE CG818A Camcorder, when I play it it only plays black and white. Was wondering if there is a used Sony or any camcorder that would play my Video8 P6-120MP tape, in color.
I have the exact same camera and same exact same problem. Any analog Video8 or Hi-8 camcorder or VCR will play these tapes.
By using the same cassettes as Hi8, many (NOT ALL) Digital8 (produced by Sony exclusively) camcorders are able to play analog Video8/Hi8 recordings, preserving compatibility with already recorded analog tapes.
you can connect Digital8 camcorders to your computer to download your movies for editing or Internet use.
As of 2008, Digital8 camcorders have been removed from the equipment offered by Sony.
Sep 29, 2010 | Sony 8mm Stantard Grade 120 Minute...
Sony 8mm camcorder will record sound but no video
Since it is playing the tape, the play head is ok. Now recording is done by recording heads so you may have a clogged heads or damaged recording heads. Try to clean the heads with head cleaning tape to see if it would help. 1. remove the tape and leave the door open. 2. using a canned air, blow out any dusts in the tape area. 3. run head cleaning tape for about 10 seconds and no more. 4. try the recording.. If this does not resolve, you may have a damaged or heavy clogged video heads. Take it to nearest video technician for a diagnostic. -James
Mar 28, 2009 | Sony Handycam CCD-TR517 Camcorder
Mode for playback of older 8mm tapes using Sony DCR-TRV730 ?
In 1990s Sony camcorder records movie in analog format so playing in digital camcorder like DCR-TRV730 doesn't mean it will be converted in digital format and you can not import file in PC for editing purpose. You will get analog signal while playing back old cassettes.
Regarding SP, LP speed, its decided at time of recording. Camera sens SP or LP automatically in playback and set itself accordingly.
If you want to convert old cassettes into digital format, connect our camcorder to DVD recorder and burn DVD which is digital format, copy DVD files in to PC and do desired editing.
Nov 24, 2008 | Sony Handycam DCR-TRV730 Digital Camcorder
Viewing SONY 8mm Tapes -- Please help
The older tapes were shot on a 8mm camcorder and the camcorder you have wil not play them becasue it doesn't have backwards compatability with the older format. The tapes you recorded are on a digital 8 camcorderr and it is different encoding than the one you recorded the other 60 tapes with. You will need to find either a dcr-trv 350 trv 530 trv 730 ect as these have the ability to play all the tapes.
Or find an older 8mm camcorder to play your tapes with.
Hope this helps
Cheers
Al
Nov 01, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
I have an 8mm high digital camcorder tape which got tangled in the camcorder. when i wound the tape back in the case and returned it to the camcorder it would only play a high pitched sound with no...
I've had to fix this problem several times. You need to open the 8mm cassette, and manually rewind to where the tape got twisted around. Then untwist it, and manually wind the tape back on the reels. and then put the cassette back together. If the tape isn't torn you should be fine. There might be creases in the tape- but they will only give you a slight picture glitch or drop out. You need to run a head cleaning tape through your camcorder before you try taping again. It might hose up the next tape if you don't.
Jul 24, 2008 | Cameras
Sound
It's not tracking -- it's dirty heads -- you can purchase an 8mm head cleaning cassette and use it to cure these problems. Tapes recorded with the dirty heads may still have issues afterwards.
Nov 17, 2007 | Hitachi VME535LA 8mm Analog Camcorder
Multi-function DVD recorder VRD-MC5
Update to my 1/8/08 posting - my recorder is working perfectly! I found the installation of the needed file quite easy and all is good in the hood.
Later
Nov 10, 2007 | Sony DVDirect VRD-MC3 DVD Recorder
Adapter question
There are no such adapters that would allow 8mm, Hi8 and Mini DV tapes to be played in a VHS VCR. Only the old VHS-C tapes can fit and play in an adapter. There are several reasons why 8mm (or Hi8 and miniDV tapes) cannot be physically played in a VHS VCR: 1. 8mm (Hi8, miniDV) is a different format with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with current VHS technology. 2. 8mm/Hi8 tapes are 8mm wide (miniDV is 6mm wide), while VHS tape is 1/2" wide, making it impossible for a VHS video head to read the taped information correctly. 3. 8mm/Hi8/miniDV tapes are recorded and played at different speeds than VHS, so even if the tapes could physically fit into a standard VHS VCR, the VCR still couldn't play back the tapes at their correct speeds. 4. 8mm/Hi8/minDV audio is recorded differently than VHS. 8mm/Hi8 audio is recorded in AFM HiFi mode, while miniDV audio is recording in 12-Bit or 16-Bit PCM digital audio format. So, even if the video could be played back in a VHS VCR, the audio could not be read properly. 5. 8mm/Hi8 video is of higher resolution than VHS and is recorded in a different bandwidth length (miniDV video is recorded digitally), so once again, a standard VCR still could not read the information correctly, even if the tape could fit into a VCR.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Electronics - Others Logo
437 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
 Grubhead
Grubhead
Computer Links
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
