Question about Fujitsu 24C1 Air Conditioner
Flashing green light persist even after the filters are cleaned and properly reinstalled. no air conditioning function
  • Fujitsu Master
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Aug 31, 2010
I have a Maytag window air conditioner unit (model M6T12FSA). The 'check filter' light came on and after I cleaned the filter, the 'check filter' light remains on even after a few hours of...
Turn the unit OFF & Unplug it. Remove the filter and reinstall it, being sure that it's installed properly. Particularly, which way the plastic filter frame is facing when installed.
Plug the unit back in and turn it ON. Hopefully, the electronics now will accept the filter being properly in place.
Hope this helps and thanks for choosing FixYa.
Jul 25, 2011 | Maytag Heating & Cooling
I have installed ac of whirlpool. after 2 month the indicater of filter started blicking, i called the respected people and made it clean. until the indicater is continuously blicking. the sales person...
If the filter was removed and replaced while the unit was ON, it doesn't sense that it was replaced or cleaned. Turn the Master ON/OFF Switch to OFF, unlpug it from the wall, remove the filter and reinstall it properly. Then, plug the cord back in and turn the Master ON/OFF Switch to ON. The Clean Filter indicator light, should have stopped blinking or will shortly there after.
Hope this helped you.
Jun 20, 2011 | Whirlpool ACC108PS Air Conditioner
I am replacing the water filter how do I reset on the outside door
The Water Filter Status Indicator Light serves as a
reminder to replace the water filter. A green light
indicates that the filter is in good condition. A red light
indicates the filter should be changed. Once light turns
red, it will remain red until function is reset.
To Reset Indicator:
• Press and hold both the Lock and Water
buttons simultaneously for four seconds. The
green filter status indicator light will flash
three times when the function has
successfully reset.
Thanks, Sea Breeze
May 17, 2010 | Jenn-Air JCD2295HES Side by Side...
My husqvarna chain saw bogs down even without chain on it.
I think your "L" adjustment is off by a little, but because it will not hurt, costs nothing, and might be the cause of this, remove, clean and reinstall the muffler and spark arrestor. If the problem persists try this, it is by far the best carburetor adjustment I have found.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too. Good Luck. HTH
Lou
Feb 24, 2010 | Husqvarna Forest & Garden No.967012396 345...
My chain saw bogs down like it is binding up with the chain on or off
I do not recommend operating your saw at full throttle without the bar and a properly adjusted chain.
Remove clean and reinstall the air filter and muffler, do not forget the spark arrestor. If it the problem persists turn the "H" needle valve CCW 1/8 turn. Better?
This is a very good adjustment procedure.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too. HTH
Lou
Feb 19, 2010 | Echo Garden
Red light stays on after changing the water filter and running about 2 gallons through it
Light (select models)
To Reset Indicator:
successfully reset.
Nov 27, 2009 | Maytag MZD2665HE Side by Side Refrigerator
Change filter light
To Reset Indicator:
successfully reset.
Sea Breeze
Nov 25, 2009 | Maytag MSD2650H Side by Side Refrigerator
Changing light after installing new water filter
(select models)
To Reset Indicator:
• Press and hold both the LOCK and WATER
successfully reset.
Aug 12, 2009 | Jenn-Air 21.6 cu. ft. Side-By-Side...
I have noticed in the past 24 hours that my air conditioning has not been as cool as it normally is. I changed the air filter in my furnace and my air is still not getting any cooler. I checked the...
Your AC inlet might have been blocked by dust. So it is adivisable to clean with water using pressure hose. This could solve your problem.
Sep 07, 2008 | Heating & Cooling
Filter light keeps flashing
The light flashes after a certain amount of run time. It is a reminder to check the filter to see if it needs cleaning. Once you have checked/cleaned the filter and reinstalled it, press the filter button for 5 seconds and the light should go out.
Jun 18, 2007 | Whirlpool ACQ158XP Wall/Window Air...
Fujitsu 24C1 Air Conditioner Logo
306 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
