Question about GPS
What do PO 171 and PO 174 system lean on my Mercury Sable?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Codes PO171 and PO174 in your Mercury sable means a bad Mass Air Flow (MAF) sensor as a bad sensor will cause the vehicle not to start. Also these codes indicate a lean fuel mixture. Check for vacuum leaks by spraying carb cleaner around the intake manifold and any vacuum lines. If you do not find any intake leaks, replace the mass air flow sensor. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 30, 2010
2009 Mercury Sable P0442 code how bad is it and how costly to fix?
PO 442 Evap System Small Leak
Have a shop smoke test the system,find
the leak & the solution
Nov 17, 2014 | 2009 Mercury Sable 4WD
2001 Mercury Sable: code for System Lean to Bank 2= Car Idles too high. Possible causes?
sounds like a air leak ,, bank 2 sensor 2 ?? refers to after the catalytic converter ... could be a faulty sensor but more likely an air leak .... even a faulty fuel tank cap seal is enough to cause problems on these systems
Nov 06, 2013 | 2001 Mercury Sable
Solutions for code p1131 problems mercury sable 1998
The code is for the upstream O2 sensor bank one stuck on lean.
Could be a faulty sensor, or low fuel pressure, or a vac leak.
Aug 29, 2012 | 1998 Mercury Sable
1997 mercury sable po 420 bank 1 which sensor do i change.
That could be the cataylic convetor you could try the oxygen sensor behind the cat the last one to the rear of the vehicle bank 1 sensor # 3 but P0420 is TWC system witch means low efficiency in the cat but it could be a sympthom of an other problem but if the code is 0420 thats where i would start
Nov 17, 2010 | Mercury Sable Cars & Trucks
I have got a P0171 & P0174 engine codes on my 2001 mercury sable. What do I do to fix it.
P0171 System Too Lean Bank 1
P0172 System Too Rich Bank 1
P0173 Fuel Trim Bank 2
P0174 System Too Lean Bank 2
OK, that's a partial list of codes, the fuel delivery is controlled by the oxygen sensors, so it's possible that something in that area could be causing your problem.
However, it could also be clogged fuel injectors that can't deliver enough fuel to the cylinders compared to the air that is pulled into the engine.
Try some fuel injector cleaner for that poured into the gas tank.
How does it run?
Does it miss at all?
Oct 08, 2010 | 2001 Mercury Sable
1998 mercury sable wagon with the V6 Duratec engine getting a P1131 reading what is it
its running lean on bank 1, eitehr a vacuum leak, or an o2 sensor.
http://www.denlorstools.com/autoblog/2009/07/ford-p1131-p1151-fault-codes-30-dohc-o-2-diagnostics/
Sep 03, 2010 | 1998 Mercury Sable
What is error code po 304 and po316
P0304 is Cylinder 4-misfire detected-probable cause is as follows. Engine mechanical fault, wiring, ignition/fuel system, injector, ECT/MAF sensor, ECM
P0316 Misfire detected during startup-first 1000 revolutions- probable cause is as follows-Engine mechanical fault, wiring, ignition/fuel system, injector
Aug 18, 2009 | 2003 Mercury Sable
Check Engine Light Problem
Codes that tell you your engine is running lean can be caused by a number of things. First thing to do (and cheapest) is to get some fuel injector cleaner and run it for awhile. Dirty injectors can cause these codes. I recommend lucas brand myself but there are several different cleaners to choose from. The second thing is checking your vacuum lines. If there is a leak it can cause the engine to **** in too much air and cause the codes. Anything beyond that gets into alot of mechanical work and should be done by a certified technician
May 21, 2009 | 1998 Mercury Sable
GPS Logo
124 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
