Question about Refrigerators
I have a GE GSH22JSTASS, same problem with both sides not getting cold. Previous answer about the PSS26MSRSS was helpful but the plugs on my model are not the same. (I think the posting was Pt# WR55X10942) Can you advise which plug wires to jump in order to confirm that the compressor is working or not? Thanks very much. I'd like to know whether or not it is the compressor or the main control board.
  • 2 more comments
  • Hookdriver Aug 30, 2010
    Sorry, I'm good with a volt-meter but the information was too general verses specific for my model.
    Again, this is very generalized information. I need information that is specific to the GE GSH22JSTASS. I would like Guru AASC to review the question.
    AGain, I am looking for an answer similar to WR55X10942.
    The compressor is running when I plug the unit in....so I don't believe there is a bad capacitor. Everything runs.
  • 10,515 Answers
You could read a nice article that i wrote for the same problem :-
http://www.fixya.com/support/r3886637-refrigerator_not_cooling_enough_or_not
Now,
Yes it could be compressor ( rare ) or compressor relay ( more often ).
On the side of the compressor you will see a box (maybe a cover) remove the cover if it has one and then remove the wire harness. next you will see the relay with the capacitor mounted to it. give the relay a tug and pull it off the side of the compressor. once you have it off pull the capacitor off and then give the relay a shake. If it rattles the relay is bad. if the relay does not rattle the compressor is bad and you will need to call a service guy to replace the compressor.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 30, 2010
  • taran_2005
    taran_2005 Aug 30, 2010
    Thanks for your response!!
    There is one more problem related to these GE models i.e Motherboard. Most of the times, when you look at the motherboard visually - you would be able to see burned solder joints. There were many recalls in the past for the same reason.If you have power into the board on, you should see a connector with three terminals. One of those terminals is marked COMP. Read this in reference to ground. If you do not have 120 volts, you're board is bad
    If you wish to consult with another expert, you could ' reject ' this solution and other expert ( AASC or any other ) would be able to assist you from here.
    Hope i helped you.
    President:
  • 1,070 Answers
Welcome to FixYa
Dear User
Make sure the lights go out when you close the door(s), make sure the doors are closing properly and the gaskets are closing fully and not torn. Check to make sure the evaporator fan in the freezer is working, this fan blows the cold air around. If the fan is not working, possible bad fan motor - check for power to the fan motor and also check the fan switches around the door openings.The most common fridge "not cooling" problem is a frost free failure. Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Make sure the condenser fan motor is also working properly. Check for any "clicking on and off" noises from the compressor, is the compressor running.
Thanks for Connecting FixYa..
  • 2,272 Answers
There is a start up capacitor or motor beside the compressor and a relay beside the compressor.If the capacitor/motor or relay is faulty then also compressor will not function as it should. If the fridge is less then 5 years old - the compressor should be under the full manufacturer warranty.
It covers the compressor, but does not cover the start device.
In that case do not worry about the compressor. Replace the start device and if the compressor would not work - call the GE authorized service.
If it's more then 5 years old, the only what you can test is the electrical part of the compressor (motor).
After the start device has been removed check continuity across each pair of the compressor terminals. They all should have the resistance reading between 3 to 8 Ohms. If any of the pair is open or shorted - the compressor is gone.
Even if the result is good it does not prove the compressor is good mechanically. You can see it only after the start device has been replaced.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
    Genius:
  • 1,478 Answers
If you like to test the compressor on your refrigerator, follow the steps below to test the compressor for continuity.
Unplug the refrigerator or turn off the breaker that powers it. Since you will have to get to the backside of the refrigerator anyway, I would advice you unplug it. With the cover off, you should see the relay, the overload protector and the terminals for the compressor motor. The relay can be removed simply by pulling it straight off of the compressor.
Use the needle-nose pliers to pull the wire connector off of the relay. Pull it off by gripping the connector, NOT the wire. Inspect both the connector and the relay for any signs of corrosion. If there are any, then you should replace the corroded part.
On the compressor motor you should see three terminals. Set your multitester to read ohms, usually the RX1 or X1 setting, depending on the model of tester. Touch one of the tester's probes to one of the terminals and leave it there. Then, use the other probe to touch first one of the other terminals and then the last one. The tester should display a reading of "zero" ohms for each test.
Move the probe you held on the first terminal and hold it in place on the second terminal. Use the other probe to touch each of the other terminals. The tester should continue reading "zero" ohms with each test. Hold the probe on the last terminal and touch the other two terminals individually with the other probe. Again, the readings should all come up "zero" ohms. If the compressor motor fails any of these tests, it will need to be serviced by a professional refrigerator repairman. While you are testing the compressor motor, you might as well test the compressor for ground. Keeping your multitester setting on ohms, touch one probe to the side of the metal box that houses the relay. With the other probe, touch each of the three compressor motor terminals one at a time. The tester should read "infinity" every time. If it doesn't, the compressor motor will need to be serviced by a professional.
Ge frig not cooling
Is there anything getting cold at all?
Oct 22, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
It seems that the wiring diagram show the hot/black side going to the defrost timer AFTER the cold control/thermostat. how does the timer keep running when the cold control isn't...
If your model is the PSS26MSRSS the defrost timer is built into the motherboard and will be completely electronic. Click here for the=> Service Manual And then click here for=> GE Profile/Artica Technical Information Now it is possible that the model listed here requesting a solution may have been listed incorrectly by auto generated model numbers and not by your fault, it just happens here at times. So if this is what happened then try again to provide a different model number. Here is how GE locates their model numbers, Click Here=>
GE APPLIANCE MODEL NUMBER LOCATOR'S
Refrigerators
Freezers
  • Chest Freezer
  • Upright Freezer
  • Either way I am here to help and if your model is the model listed you most likely are having problems with either the compressor start components or the motherboard itself. If you would like me to assist you more just let me know HERE or here on Fixya. Seems lately customers are having a little trouble navigating the site due to so many new changes. Hope this helps, so let me know, Thanks, Sea Breeze
Sep 02, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
My ge refrigerator turns off on its on and when its shaken it turns back on?
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Aug 18, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE monogram has white panels, and I want to change them to stainless steel. Where can I buy them, and do I need a special trim kit? Thank you!
The model number that you referenced appears to be a stainless steel model. I know of no trim kits available.
Some of the older models did have door trim kits available.
Model PSS26MSRSS should be a stainless steel model unless this is the wrong number.
You can call the GE answer center at 800-626-2000 and get the information you need.
Jun 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
It will not get cold
If you are ready to do some checking around for some things I will help you solve this. I am very good with the PSS26MSRSS model.Let me know if you see any ice in rear of freezer or everything is warm,
Sea Breeze
Nov 19, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer Working Frig not getting cold enough at max setting
unplug 24 hrs with doors open plug in again if it works better you have a defrost problem. it may be the defrost termination switch.. burned out element or bad timer
Aug 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Gshs5kgx refrigerator not cold enough, controls
Did you solve this problem? We're having the same problem on our GE same model, but no turbo cool option.
Jul 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Side by side refrigerator not working
THE FREEZER FAN BLOWS COLD AIR TO THE FRIDGE SIDE, TO ACCESS THIS FAN YOU NEED TO EMPTY THE FREEZER SIDE AND REMOVE THE REAR PANEL SOMETIMES A WHIRL OF IT WILL GET IT SPINNING AGAIN BUT YOU MAY AS WELL CHANGE IT
Apr 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Side by Side is getting too cold on the fridge side.
I have a GE refrigerator with the same problem of my food freezing in the refrigerator. I spoke to an appliance part person and they sold me a temperature sensor for 20 bucks. They said it would be located in the control panel, but I took the control panel off and can't find the sensor. I'm now looking on yahoo answers to find out where the sensor is located.
Mar 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
603 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
