Question about Kodak EasyShare DX7440 Digital Camera
Can't download pictures off of my Kodak EasyShare DX7440
I have tried computers at work and both of my computers at home and cannot get the pictures off of my camera onto the computer. The popup message is "a USB device has exceeded the power limitis of its hub port". I called our computer tech and he said I should probably fully charge my camera, which I did and I am still getting the message.
Greetings,
Ekse is most likeley right about the camera draining too much power. Howeaver, if the camera is working fine otherwise I would try using a card reader before sending in the camera for a repair. For example this one from Amazon is only 13 dollars:
http://www.amazon.com/eforcity-53-in-1-memory-card-reader/dp/B000FDTNZA/ref=sr_1_11?ie=UTF8&s=electronics&qid=1210258519&sr=1-11
Or perhaps you can seek out a friend with a card reader. To use a card reader all you have to do is locate the memory car in the camera, remove it and put it into the card readers slot, like a small floppy disc. Hope that helps.
Take Care,
-WN
Posted on May 08, 2008
    Genius:
  • 3,422 Answers
Here are few possiblities..
The error mssg may mean your device is pulling more that 500milliamps / or Its possible that you have an electrical short in one of the plugs or sockets in your computer causing the excessive pull (power/short). You should take your computer to a good repair shop and have them check it out.
You can ignore it. doesn't really mean anything. Pops up when there is to much power going through the USB port. But sometimes it comes up for no reason especially if you have a USB Hub connected. or a device that uses your PC power instead of its own power.
It's also a little bug in XP when the program that monitors the power is corupt. a repair install of XP might fix it.
Shut down the computer, unplug the power cable and wait 10 seconds. Connect the power cable and start the computer. That would reset the power on the hub port.
Goodluck,
Please don't forget to rate the solution
  • Priya darshan May 08, 2008
    If you want to rate my solution then please rate the sol. no.2
  • 3,037 Answers
Try repairing your operating system
also try going to the properties of "my computer" after that go to the hardware and click on the device manager after that click on universal serial bus controller in this right click on your usb and go to properties and click on advanced tab and and check on the box where this message is written don't tell me about the usb error. the popup message will not appear next time when you start windows
let me know if this works, otherwise, I would also try using a different cable,
you also said the pictures won't download, see if they will now and if not, I will further assist you in getting this working
good luck
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri May 08, 2008
    since it is on multiple computers, I doubt that it is the motherboard
  • Benjamin Patri
    Is it a powered hub on each computer ? i.e. it has a mains transformer plugged into it ?
    If it is, and the transformer is no longer powering the hub then the
    hub might be working as an 'unpowered hub' and doesn't like the extra
    load of your camera i.e. exceeding the current supply limits of
    unpowered hubs
    Check fuses, connections etc of the transformer
    You might also look into buying a card reader and then you won't have to worry about connecting the camera directly to the computers. I think this would be your best option seeing as you have the problem on multiple computers.
  • Benjamin Patri
    Benjamin Patri May 09, 2008
    Please don't forget to let me know your feedback about my solution.
    If your problem is fixed, please rate this solution as that is one of the biggest
    aspects of how this website works and in order to receive any credit in
    helping you, my solution needs to be rated.
    Otherwise, let me know if you have further questions and I would be more than happy to help.
    Thank you
  • Kodak Master
  • 13,433 Answers
Hello
The camera is draing too much power from the usb port.
possibly a fault in the mainboard.
You can get a free repair estimate from
http://www.advancecamera.com/repair/
if you dont have warranty.
Il check if there are other possible causes for this.
  • 1 more comment
  • Ekse May 08, 2008
    the camera should work even if you get the popup are you sure you have the drivers and software properly installed?
    check device manager do you see the camera there or does it have a yellow ! mark next to it?
  • Ekse May 08, 2008
    Another thing to try would be to buy a double usb connector cable
    which has 2 usb connectors for the pc and one for the camera.
    or a powered usb hub, so it doesnt drain power from your pc.
    Something similiar to this
    http://www.thinkgeek.com/computing/acces...
  • Ekse May 08, 2008
    BestDarnGood I ment the mainboard in the CAMERA
Will Kodak download the Easyshare software to connect my DX7440 to my computer?
You may download the Kodak software from here.
You don't need to use the Kodak software, however. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Oct 16, 2012 | Kodak EasyShare C330 Digital Camera
Kodak easyshare dx7440 won't be detected?
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Mar 28, 2012 | Kodak EasyShare DX7440 Digital Camera
I did not get the Easyshare dx7440 software disk with a 2nd hand camera. I cannot download my pictures into window xp os system with a card reader. what should I do to down load the necessary software to...
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
If you really want Kodak's software, you can get it from
http://support.en.kodak.com
Sep 05, 2011 | Kodak EasyShare DX7440 Digital Camera
DX7440 computer cannot read the device
Consider NOT connecting the camera to the computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Dec 20, 2010 | Kodak EasyShare DX7440 Digital Camera
Is the kodak dx7440 compatible with the sdhc cards?
Hi. Kodak DX7440 is using standard SD card or MMC card up to 1GB (some says it will read 2 to 4GB standard SD but I haven't tried). SDHC is high capacity, 4GB above and will not work on your camera.
Aug 19, 2010 | Kodak EasyShare DX7440 Digital Camera
Picture file size too big when loaded into easyshare software
Upgrade you computer.
You could also lower the quality of the pics on the camera.
Menu, Camera Settings. Pixel Quality.
Nov 22, 2009 | Kodak EasyShare DX7440 Digital Camera
I have a kodak 7430 camera and my operating system is winndows 7. Now my camera doesnt work how can I resolve this proplem
You could go to the support section of the Kodak website and download drivers for windows 7 or you could buy an inexpensive card reader to download your pictures.
Oct 26, 2009 | Kodak EasyShare DX7440 Digital Camera
Pictures wher not transferred
hey, i had this same problem and it took me forever to solve. i honestly tried everything.
here's what you do, go here: http://wwwcaen.kodak.com/global/en/service/downloads/dln_ekn034494.jhtml?pq-path=11895
and download the newer version, then it should work, at least it did for me.
good luck
Mar 20, 2009 | Kodak EasyShare DX7440 Digital Camera
Kodak EasyShare DX7440 Digital Camera Logo
129 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
