Question about Rangemaster Professional 90 SS (electric) Kitchen Range
I have just moved into my new home with a fitted cooker but the details on the temperature gage has faded so i dont know what temperature its on
  • 17,130 Answers
Use a good thermometer, if possible a probe type to check heat after oven is turned on , Now at different timing take the test while switching off oven or heating till the set levels of temperature can be marked and calibrated on the panel with the marking in place.
You can start by calibrating from 90 degrees and in steps of 30 degrees making sure it is marked with the set levels.
Thus it can be calibrated to work.
Posted on Aug 30, 2010
Coffee machine gage that doesent move
If the model is KES100 and coffee and steam are both at normal temperature then the problem is one of the following
1) The needle has come loose on the shaft. Solution; turn machine on and press needle back onto shaft in the usual position for full heat when the machine is on full heat.
2) The gas/liquid has escaped from the copper tubing to the gauge. Solution; fit a new gauge assembly.
Mar 26, 2014 | KitchenAid Coffee Makers & Espresso...
Setting the gage for fagor pressure cooker
The Fagor electric pressure cooker does not have a gauge that needs to be set. Instead, it has a handle that has to be turned to point to "PRESSURE" before the electric cooker can start cooking.
Then, you either press "high" or "low" pressure button on the control panel.
You can find detailed instructions in the manual, here:
http://www.hippressurecooking.com/fagor-electric-pressure-cooker-manual/
Jan 28, 2014 | Kitchen Appliances - Others
Setting the gage for pressure
Move the lever on the lid to the position indicated in the pressure cooker manual. You didn't state the brand, but if you don't have a manual you can find it and download it from here:
http://www.hippressurecooking.com/pressure-cooker-manual-library/
Voltmeter gage
if it goes right off its fine but if it stays on watch the gauges see if there is a light on you norm dont see
Sep 18, 2013 | Jeep Cars & Trucks
What do the cooking symbols on my cda oven stand for
Hi ive home and it has a cda cooker installed the only thing is is that the cooker has no symbols on the front so you dont know what settings it is on lol help please
Jul 13, 2012 | Ovens
How to refill gas in home spli a/c, advise presure details as wel
Charging AC by superheat and subcool
First charging a unit by superheat, this is only for Acs with an orifice or capillary tube.
Optimum superheat is 12° to 15° at the compressor or suction line outside the unit.
Hook up your gages and put a thermometer on suction line (large line), start the AC. Measure the temperature of the suction line and read the pressure on your gages. Theres a temperature scale on your gages for R-22 or R-410A the needle will show you the pressure on the outer scale and if you follow it down to the R-22 or R-410a inner scale that is the saturation temperature for that refrigerant, (you can also use a temperature pressure chart), now read the thermometer, let’s say the suction temperature( the thermometer) is 67° and the saturation temperature (the gages or temp. press. Chart), is 55°, subtract the saturation temperature from the suction temperature, 67°- 55° = 12° superheat.
Charging by Subcooling, this is for Acs with a thermostatic expansion valve, it’s common to see a sight glass on the liquid line (on these units with a sight glass just clear it, when, indoor room is at approximate set point of the thermostat). Optimum sub cooling is 12° to 15° at the outdoor unit.
Hook up your gages and put a thermometer on liquid line (small line), start the AC. Measure the temperature of the liquid line and read the pressure on your gages. Theres a temperature scale on your gages for R-22 or R-410A the needle will show you the pressure on the outer scale and if you follow it down to the R-22 or R-410a inner scale that is the saturation temperature for that refrigerant,(you can also use a temperature pressure chart), now read the thermometer, let’s say the liquid temperature( the thermometer) is 100° and the saturation temperature (the gages or temp. press. Chart), is 114°, subtract the liquid temperature from the saturation temperature, 114°- 100° = 14° subcool.
Mar 19, 2010 | Panasonic CW-1006FU Air Conditioner
Need a replacement glass lid for a west bend slow cooker model 84356. Not available on the WEst Bend appliance website. Any ideas?
I will give you mine if you want to pay for shipping. I have to order a new crock because mine cracked. Since they redesigned the crock, I have to buy the new lid that goes with it. Let me know if you want it and we can work out the details.
Jan 18, 2010 | West Bend 84356 6-Quart Slow Cooker
Top oven thermostat Stoves 800DF - fitting?
Hi, we have had one of these ovens for 8 years (it was in the house we moved into). We had a new control fitted for the top oven (it took the repair company three tries to get the right part) and the problem didn't go away. To be honest, we can't stand this oven but are waiting until we replace the entire kitchen to replace it. The bottom oven is fine. The top oven is fierce and burns food all the time. Overall it's a ridiculous oven - I'd much prefer a sensibly-sized one that actually worked well! Rant over.
Jun 10, 2009 | Stoves 800DFDOm Dual Fuel (Electric and...
Looking for Ultrex II Electric Pressure Cooker Cord
Any generic appliance cord should work. You can try Home Depot or Lowes they have some cords. Just make sure you get the same gage and approximate length cord. You can also buy cords on line from appliance supply websites. Good luck. If you have any more questions please ask. Please rate me so I know if I helped. Thanks.
Dec 30, 2008 | Ultrex II 8Quart Rice Cooker
Knob reagings faded
I need to know the readings on the knob, what is first, second and third
Jun 16, 2008 | Hamilton Beach 33163 Stay or Go 6-Quart...
Rangemaster Professional 90 SS (electric) Kitchen Range Logo
145 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Mike Carew
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
