Question about Kicker Car Audio & Video
My kicker amp got wet during rain, trunk leak. I heard 2 pops 1 loud 1 softer, smoke, then nothing, how do i fix or is it just dead?
  • 55 Answers
SOURCE: No Power light or sound from kicker amp and speakers
OPEN UP THE AMP AND CHECK THE FUSE HOLDER THAT IT IS CONNECTED TO THE BOARD
IT MAY HAVE GOT BUMPED AND THE CONNECTION MAY HAVE BROKE IT MAY BE A HAIR LINE BREAK WITH THE COVER OFF AND THE POWER ON MOVE THE HOLDER MAY NEED TO BE RESOLDER THE CONNECTON THATS ALL IT IS GOOD LUCK
Posted on Feb 20, 2009
SOURCE: Kicker 550.3 amp will not power up
do u have the remote wire hooked up to the (rem) spot usally inbetween the pos and neg?
Posted on Mar 15, 2009
  • 11 Answers
SOURCE: i have 2 kicker l7 12 dual voice coil subs.. i
it all depends on the impendance of your subs if u have duel 4ohm or duel 2ohm, 2 duel 4ohm speakers can be wired at 1ohm to the amp, and with a kx1200.1 that would be pushin 2400 peak and 1200rms
if ya have 2 duel 2ohm speaker than you can only wire them to 2ohm and would be pushing 1200 peak and 600 rms with the kx1200, so if you have the duel 4ohm i would go with the kx1200.1 and if u have the duel 2ohm i would go with the hifoncs
Posted on Jun 16, 2009
etirbynnor
  • 655 Answers
SOURCE: i have 2 kicker l7 12s 4ohm speakers and was
Hello gonenutz14,
It depends on how you define the "best way". Driving each sub with a separate 750 watt amp will result in about 50 percent more power than having them share the output from a single 1000 watt amp. But with 2 amps, there's more wiring issues to contend with and the adjustments are more complex. The 2 750 watt amps will cost more than a single 1000. Plus if the 1000 watt amp is stable to 1 ohm, the power difference will actually be less than 50 percent because of the lower impedance. But if the 750 watt amps are also stable to 1 ohm and their outputs can be combined, we're back to 2 being better than 1.
I'd say that the simplest, most economical way is to use a single amp. If maximum power to the subs is the highest priority, and cost and wiring is not an issue, then 2 is better.
Hope this helps.
Posted on Jul 12, 2009
  • 8457 Answers
SOURCE: Heard a loud pop and picture went out. Still have sound
Ur tv have burns capacitors,look for pop ups caps.
Posted on Oct 22, 2009
Why does trunk leak on passenger side?
Inspect the gasket around the perimeter of the trunk opening for damage or separation due to adhesive failure and make the necessary r && r.
Jan 08, 2016 | 2008 Chevrolet Impala LTZ
Why does water get in trunk lid & every time it rains I open trunk & stuff gets wet
Usually the leak is from a faulty gasket, or the lid is not adjusted correctly to seal against the gasket.
Jul 16, 2014 | 2009 Dodge Avenger SXT
HAVE NO PICTURE....HEARD TWO LOUD POPS, SAW SMOKE & SMALL FIRE
Smoke is never a good sign, is this the model indicated above?
If handy you may want to open set and see where the damage is---may just narrow things down.
OF COURSE IF IT SMOKED DO NOT PLUG IT TO POWER OR TRY TO TURN IT ON AGAIN---nothing to be gained by doing that.
Dec 04, 2012 | Sony WEGA KE-32TS2 32 in. HD-Ready Plasma...
Heard a loud pop during turn on, not picture but
Ur LCD inverter board it dead.Replaced this board u will get ur picture back.Tries websites like shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long shape board.
Apr 26, 2010 | Toshiba 32HL66 32 in. LCD HDTV
No power to my kicker ZX 1000.1
sounds like you blew a fuse for the battery power supply to the amplifier
Mar 23, 2010 | Kicker ZX10001 Car Audio Amplifier
1997 Toyota Camry LE. During wet weather, water
Most of the problems come when its raining and if its not being driven and water still comes in then its the bonnet rubber and if when its being driven then its due to the rear wheel throughing up water under wheelarch and somewhere theres a crack in the weld or somewhere and it will find its way in..
So if not using it clean it out and when rain stops look inside no rain no leak Have a goodday
Oct 09, 2009 | 1997 Toyota Camry
Trunk water leak 1993 buick park avenue
Mother nature is too slow in finding leaks. Have someone small get in the trunk with a flashligh and watch as you run a hose over everything. LET THE PERSON OUT!
Jun 11, 2009 | 1993 Buick Park Avenue
Amp messed up got 24 volts instead of 12 how to fix
Here is what I need you to do so that I can help you try to fix this. I need you to open up your amp take some pictures. I will need some of the overall view, then take two seperate picteures closer dividing the amp in half. They should look like one really big picture of the overall amp. Then finaly I need you to take some pictures of the problem. I am sure that witht the pop and smoke that you saw and heard you shold be able to find the problem really quick. With all of this and from the way is sounds this could be a really easy fix. onle last thing do you have a soldering iron, solder and a wet sponge.?
Apr 11, 2009 | Metrik Amplifiers MAX-1202 Car Audio...
Mar 15, 2009 | Kicker ZR360 Car Audio Amplifier
Trunk leaking water when it rains
The rear window seal may be leaking into the trunk.The window may need to removed to fix it correctly then you can see if there is rust holes in that area.
Jul 22, 2008 | 1998 Honda Civic
Car Audio & Video Logo
158 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
