Question about Krups F203 Grinder
What is the best way to clean Krups F203 coffee grinder?
2 Suggested Answers
farmerbear
  • 490 Answers
SOURCE: where can I buy a
Here is the url for Krups online parts. Happy caffeination:)
http://www.krupsonlinestore.com/product_list.asp?MENU=parts&SELECT=grinders&SKW=acccoffgrind
Posted on Aug 22, 2010
Krups gx6000 grinder advertises removable burr grinders and there are no instructions, but is that the best way to clean them?
the Krups instruction manual is useless in this matter but if you do have some mechanical insight this is not very hard. You will need some tools, e.g. an Allen wrench to remove the housing lid.
Anyway, you should not have to clean the grinders very often, perhaps once a year is enough. It depends on the quality of the coffee beans you use; the more 'oily' beans the more frequent cleaning is required.
I would not use water to clean it, rather a small stiff brush (e.g. an old tooth brush), but if that is not enough, water will have to be used.
If so, be sure to assemble the grinder only after the burr is completely dry.
Check the link to Home Barista where a very similar grinder is shown, that should give you an idea about what to expect during the cleaning process.
Good luck;
Villi
Home Barista com
Jan 19, 2015 | Krups Gx600050 Conical Burr Grinder Black
Motor shorting out?
check ur switch better replace the switch
Jun 17, 2008 | Krups Burr Coffee Grinder
EA6935 krups powdered coffee inside grinder and coffee grounds noncompact
You will need to pull the grinder apart & clean it out. Most likely cause of the grinder blocking up is a leak somewhere inside the machine dampening the grounds as they exit the grinder. They bind up, won't fall out and there is your blockage. You will need to find and fix the leak, there are many, many places for the leak to be, it's a job for a Krups Service Agent. I have outer housings with cutouts in them so I can run them and look inside at the same time to find those troublesome leaks.
Feb 28, 2014 | Krups Coffee Makers & Espresso Machines
Grinder in Krups Espresseria EA8000 stops and whirrs.
Hi, i had similar problem on my Krups. Inner star plastic part which remove powdered coffee is maybe damaged. You need to replace or overhaul your grinder or you can replace inner star plastic part by yourself. Coffee grinder spare repair part plastic inner star Krups Mhle...
Feb 11, 2014 | Coffee Makers & Espresso Machines
My KRUPS GVX 2 Burr grinder won't turn on!! Is there something I should know before starting to use it??
some grinders had gotten lodged in the smaller crack between the grinder cover and the case, preventing it from settling in . cleaned with small knife, wallah!
Oct 26, 2010 | Krups GVX2-12 Electric Burr Grinder
I just got a brand-new Krups F203 grinder. I was grinding up a whole bunch of coffee at once and at about the fourth cup of grounds, while the button was still pressed down, it just shut off. And now it...
You may really have overheated it and it may not have a self resetting thermal fuse. Probably best you say nothing and take it back for repair or replacement under guarantee. When you are up and running again do much less grinding at one time.
Aug 06, 2017 | Krups F203 Grinder
Krups GVX2-12 grinder - ground coffee and container full of static so coffee sticks all over, including inside the container. Any ideas?
Most plastic products contain enough carbon black to neutralise this problem. Obviously not with yours.
Try a camera accessory cleaning cloth - specifically anti-static.
http://www.amazon.co.uk/gp/product/B00006IVV8?ie=UTF8&tag=shopwiki-uk-21&linkCode=as2&camp=1634&creative=6738
Cleaning less often will also help, and maybe a quick brush out would result in less mess.
Natural fibres like cotton cloths or bristle brushes will also help.
Coffee naturally has oils that, if left on, will eliminate this problem anyway.
Feb 07, 2010 | Krups GVX2-12 Electric Burr Grinder
Krups Orchestro Dialog coffee machine
that mean no coffee go through us if you dont use the machine often you might have coffee residue on the grinder teet remove the coffee bean in the hole were the coffee bean goes use a brush and clean the grinder teet very good with the residue of coffee gonna grind and gonna go through thanks for usig fixya pierre
Feb 07, 2008 | Krups Orchestro Dialog FNF2 Espresso...
Krups F203 Grinder Logo
95 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
