Question about Panasonic Palmcorder PV-D209 Camcorder
HOW TO FIX THE TRACKING PROBLEM IN MY PANASONIC PALMCORDER iq
    Scholar:
  • 95 Answers
If the camcorder has been sitting unused for a while, there is a good possibility that the capacitors on the PCboards have started to leak. A good test of this is to turn your camcorder on, let it heat up, and then smell it (inside where the tape goes is usually the best place). If you smell fish, your caps are leaking. Once this happens, it is recommended that ALL of the caps be replaced and this repair is not cost effective to do. Another sign of bad caps is if the image in your viewfinder rolls, is wavy, or smeared in any way.
If you think that it is not a "bad cap" problem, the mechanism may just need to be cleaned by a professional. If you have a VHS-C head cleaning tape, you can try that for 5 to 10 seconds and see if it helps. www.austintelstarservices.com
Posted on Aug 30, 2010
How to adjust the tracking for my camcorder
On this kind of cameras its impossible. U need a tracking adjusting button which is only on pro cameras. I doubt if its worth to give it in for repairs
Mar 06, 2015 | Panasonic Palmcorder PV-L452 Camcorder
The power on the Panasonic Palmcorder IQ PV-A206 turns itself off. I've tried plugging directly and with a fully charged battery, no luck.
please make this test and fix it. God bless you
If the video camera doesn't work, make sure the battery is charged (see The Battery Recharger Fix-It Guide) or replace a battery that won't hold a charge. Make sure the AC adapter is connected properly. Clean any dirty contacts on the battery, charger, and AC adapter with a cotton swab dipped in denatured alcohol. Remove corrosion with a clean pencil eraser, then wipe the area with an artist's brush to remove any debris. Find and test the fuse, if any.
If the power goes off soon after starting, recharge a low battery. Also, turn the video camera power off, then turn it back on and eject the tape. If the problem persists, check the fuse
If the battery won't charge, clean the contacts and fully discharge the battery, then recharge it. If the problem persists, replace the battery
If the video camera works intermittently, remove and reseat the to establish good contact. If necessary replace the fuse
Nov 08, 2013 | Sharp Panasonic Palmcorder Iq Model...
I just bought a Palmcorder but dont know how to work it
There should be either a USB Cable or a Analog cable which connects from the cam corder to the PC. Depending on the brand it may need software to copy the clips from the camcorder to the pc, or the connection will create a drive letter from which you can copy the clips from the camcorder to your computer.
Oct 03, 2009 | Panasonic Video Cameras
How do I connect my Panasonic PV-L353 palmcoreder to my computer
You don't give enough details. More details would help.
I have a Panasonic IQ PV-IQ403 old palmcorder. I know how to connect it to a TV screen. I am not sure how a camcorder would connect to a computer. Maybe this information can be of help to you. I have separate flap door covering my RCA connections on my camera, located near the battery compartment. I just plug one end of the RCA cord into those connectors and the other end into the RCA connectors on my TV. I have to change the power switch on my camera over to the VCR position (take it off of the camera position). The TV has to be on channel 3 (or 4). I push play on my camera, and I can see what I have recorded on my TV screen.
This might work on your computer monitor. I am not an expert, but this information may be helpful.
May 17, 2009 | Panasonic Palmcorder PV-L353 Camcorder
PANASONIC PALMCORDER IQ (PV-IQ204
Try removing the battery. While holding the eject button, re-insert the battery.
Dec 06, 2008 | Panasonic Palmcorder PV-GS15 Mini DV...
Video to cd or dvd
I am not familiar with this unit, but if it has a analog video output, you can try uploading VHS video to your computer for transfer to DVD
Apr 16, 2008 | Audio Players & Recorders
I need complete "operation Manual" for Panasonic make "mini-DV" Palmcorder
I have a pv-354d and i cant adjust the tracking, Its old and i got it on line with out a manual
Feb 17, 2008 | Video Cameras
Dew Detected
I've got the 203 and all i had to do was take the bat. off and give it a couple of good hits on my palm, hitting the bottom of the camera. At sounds odd, but trully works. On the 203 its an electrical issue. Before doing this, be sure to open open the tape case, and remove your memory card and, if you can, the internal bat.
it worked for me.
Good luck.
fisherman...
Dec 22, 2007 | Panasonic Palmcorder PV-D209 Camcorder
Audio jumpy on playback
these heads should be cleaned by hand, use denatured alcohol on tape cleaning sticks . never rub up and down on the video heads only sideways, be very carefull. after wardware blow the heads dry with commpressed air or wait a few hours before you stick a tape in or your tapes film will stick to the drum cylinder. if this does not work you can sometimes adjust the tape guides just little to get the audio track back on track. Larry
Sep 18, 2007 | Panasonic Palmcorder PV-DV53 Mini DV...
Panasonic Palmcorder PV-D209 Camcorder Logo
299 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
