Question about Frigidaire FRS26R4A Side by Side Refrigerator
The freezer side every 2 to 3 days the fan makes a noise and the ice begins to melt. It drips from the ice dispenser. The following day every thing is frozen again. The refrigerator stays cold.
  • Frigidaire Master
  • 3,740 Answers
This may sound a bit harsh but turn off the water to your icemaker for several days. What your describing sounds like the icemaker water valve is leaking water by the diaphram and is leaking into your freezer. This is a common symptom of failing ice maker water valves. I just went through this on my own personal refrigerator where ice was building up. After changing the icemaker water valve all the ice build up ceased.
So turn off the icemaker water supply for a few days.. break out the ice trays if need be and see if the ice build up stops. If it does then the ice maker water valve will need to be replaced. Fyi they run $38 to 55.00 on average and you can change it yourself. Should the need arise here is a link to a replacement water valve source: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=113933&diagram_id=337176#d337176
Close up view: http://www.appliancepartspros.com/part_details.aspx?part_id=4298908
Thanks for choosing FixYa.
Kelly
Posted on Aug 30, 2010
GE Side by Side Refrig - loud noise behind the ice maker section Model PSS25SGMB BS
it sounds like the evaporator fan blade is hitting some ice that has built up around the blades i have seen this happen a lot on g.e. SxS lately,if you can remove the ice maker and dispenser you can see the fan blade,if you dont want to do this then shut down the refrigerator and leave freezer door open and heat it carefully with a hairdrier to speed the process up to melt this ice then restart it and the noise should be gone
Aug 30, 2012 | GE PSS25SGNBS Side by Side Refrigerator
I have a Kenmore side by side that is not cooling the way it was yesterday. The fan & compressor are working but its not blowing the cold air into the fridge or freezer. In the freezer, I hear as the...
It sounds like you are refering to the defrost cycle. This would make the noise you hear. Try cleaning the condensor coils and the fan that is in the bottom where the compressor is. This may help. let me know. have a great day.
Apr 27, 2011 | GE J Series 18.2 cu. ft. Top Freezer...
Our two door samsung has making noise from the motor and when you open the door it will stop. jackie.brincat@bigpond.com
Hi and welcome to FixYa, I am Kelly
The noise that stops when you open the door is the evaporator fan. If it sounds like blades striking something there is most likely too much ice in the evaporator coils and the fan blades are striking the built up ice. If it sounds like a vibration it can be bad bearings inthe evaporatof fan motor.
Ice build up is usually a sign of an automatic defrost circuit problem. The unit should defrost close to 3 times a day depending on the defrost control installed. What you should do is do a manual defrost session by unplugging the unit, removing the freezer contents and directing a fan into the freezer compartment for just over 2 hours. This will ensure that all of the evaporator coil ice has melted. (Yes it makes a water mess) Tidy things up and return the unit to normal service after your manual defrost session. NOTE: If you have an automatic defrosting problem the fan noise can repeat in as little as 2 days as the ice once again builds up on the evaporator coils.
DO the manual defrost, LISTEN for noise after 24 - 48 hours. No noise... no worries, NOISE after 24 - 48 hours = Defrost problem. Causes of a defrost problem can be the defrost control, defrost heating element, the defrost thermostat or a wiring problem.
Thanks for choosing FixYa,
Kelly
Feb 03, 2011 | Samsung RS2630SH Side by Side Refrigerator
From time to time stops working and making a noise like boling water
A refrigerator must defrost 2 - 3 times a day. It does this via the automatic defrost cycle. When the cycle starts alll motors shut off and there is a heating element that is in the evaporator / freezer section of your unit. That heating element melts the ice until the 60 Deg F bi-metal thermostat cycles and terminated the automatic defrost cycle. During the defrost cycle is is normal to hear a hissing sound as the melting ice drips on the heating element assy. Addiionally you may hear coolant gurgles as the unit shuts off to start the defrost cycle and the coolant system equalizes the internal pressures between the pressure and return lines. Again another normal sound. If your unit did not stop to defrost 2 - 3 times a day in a matter of 3 to 4 days you would have a large block of ice in the back of your freezer section and the evaporator fan blades would be hitting that ice block. The freezer would say cool yet probably no longer make ice. Also the fresh food compartment would start warming up. Hopefully this resolves your concerns. If you need more assistance just respond to this post and I will help you.
Kelly
Sep 05, 2010 | AEG S72348KA ST STEEL Refrigerator
The ice maker stops making ice, and the freezer goes into a melt-down mode. This goes on for days. Sometimes, I buy a bag of ice, pour it into the ice maker bin...and PRESTO, the ice maker begins to...
you may have a p c board failure . it has not completely it will . the board gets stuck in defrost and you have a melt down . ( main board d wr49x10152 ) / if not the board ck when it hapens the evap fan in back of freezer .. .. also ck for frost in back of freezer .. mm
Dec 17, 2009 | GE Profile PSF26PGSBB 36" 25.5 Cu. Ft....
When the ice maker start to rotate there is very loud noise
Dripping sound.
During the defrost, water draining from the freezer section will drip into the pan by your compressor in the back and bottom of your refrigerator.
* Air rushing or blowing.
There is a fan in the freezer section and in some models in the back and bottom of your refrigerator to circulate air. This is a normal sound.
* Louder when starting or coming on.
Compressor operates at a higher pressure when first starting and noise should disappear as refrigerator continues to run and balance pressures.
* Popping, crackling, or sizzling about once a day.
If your model is self-defrosting, the defrost system utilizes a heater to remove the ice and frost from the freezer coil. During this period you will hear some expansion noises as heat is applied to the coil and you may experience some sizzling sounds as the melting water drips on the heater.
* Running water.
If you have an ice maker equipped model, the ice maker will call for water as the old batch of cubes is ejected and the ice maker starts to make more cubes. This will last for about 10 seconds and is normal.
* Vibrating or rattling noises
Sep 22, 2009 | Kenmore 25.1 cu. ft. Side-By-Side...
Freezer Defrosts on its own
Yes it is supposed to. Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
If it seems to defrost too long and start thawing the contents then the defrost thermsotat may be bad. It's purpose is to stop the defrost heater when the temp reaches around 32 degrees. If it doesn't work the heater will stay on for the entire defrost cycle and possible melt things.
Check here for how to check it and where it is. http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 25, 2009 | GE GSH25JFR Side by Side Refrigerator
GE TFX22R SIDE BY SIDE
you defrost problem or check condenser fan at the back of refrigerator see if it runs
Apr 07, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
Load noise coming from freezer
nothing to do with light bulb - noise is probably fan hitting ice that has built up. to check, remove back panel inside freezer and check for ice build up. melt off with a hairdryer and get back to me if i'm right
Nov 12, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
My icemaker is not making ice. This has happened 3 times in the past 3 years but this is the longest it has gone without making ice. The other 2 times it lasted 2 days. It has now been 4 daysince the ice...
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
May 15, 2008 | Amana Refrigerators
Frigidaire FRS26R4A Side by Side Refrigerator Logo
94 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
