If an electric discharge produces 500 cm3 of ozone (O3), how many cm3 of oxygen (O2) are required? 3O2(g) ---> 2O3(g)
2 Suggested Answers
HoweToFix
  • 49 Answers
SOURCE: ecoquest fresh air
Yes it will. But do not run it on ozone mode while you or pets are present.
Posted on Apr 02, 2010
2005 toyota tacoma 2.7 code p0037 replace rear 02 and computer code keep coming back.
P0037 - O2 Oxygen Sensor Circuit High Voltage (Bank1, Sensor2)
The Heated Oxygen Sensor (2) located rear of catalytic converter produces an output signal relative to oxygen storage capacity of catalytic converter. Ho2S 2 signal is less active than signal produced by front oxygen sensor. This code sets when HO2 Sensor voltage is greater than 999 mV for more than 2 minutes (time depends on model. Could be as high as 4 minutes)
Symptoms: There may be no noticeable symptoms except for MIL illumination. Possible high fuel pressure can over rich the system.
Causes: A code P0138 may mean that one or more of the following has happened:
* Faulty O2 sensor
* Short to battery voltage in O2 sensor signal circuit
* High fuel pressure (not as likely)
Here are some potential solutions:
* Replace O2 sensor
* Repair short to battery voltage in o2 sensor signal circuit
If you replaced the O2 sensor, then its possible that you have some electrical problem there; reset the codes first, and if this come on again, check in this link TSB P0037 electrical diagnostic procedure.
Keep us updated.
Jan 27, 2011 | 2005 Toyota Tacoma
I just purchased a used XL15s. The unit when in manual mode emits an oder, but the air feels oxygenated. When you breath close to the machine the air seems to irritate or kinda burn my eyes. When in auto...
This is what the machine is designed to do! The machine emits a low amount of ozone, which is the purifier/sanitizer created by sunlight. Close to the machine, it's concentrated. When it spreads throughout the room, it kills odors and bacteria, and creates the fresh smell of clean air. The air truly is "oxygenated," because ozone is simply O3, instead of O2, and breaks down quickly.
If the numbered dial is set too high (try it at 300 to 500) it will smell "bleachy." Your "rule of thumb" is that when you've been away, and enter the home, you should experience the same fresh, clean smell that you get when you step outdoors on a bright spring or winter day.
When you're doing something that creates odors, like frying fish or cooking sauerkraut, turn the dial up to take care of that odor quickly, then turn it down for normal operation.
Leave it on the manual setting for continual purification. Often, the auto setting has been disabled, which might be the case in your older machine. (These machines can be 12-15 years old!) For an owners manual, go to www.vollara.com (new name of Ecoquest/Alpine). They may be able to help you.
Jan 17, 2011 | Alpine Air XL-15 Air Purifier
I was considering Biozone for restrooms etc and I assumed,as your info.says that it would be odour free?Some I have seen are not odour free.Is it just a uv lamp system or is there some form of ozone...
the UV lamp does produce some ozone .. this one specifies .04 ppm .. thats not very much but might be detectable as a slight fresh air odor .. some other types use electrostatic filtering and some even have strong ozone generators .. ozone does kill bacteria, fungus and such and will freshen the air removing many odors but is not considered healthy in large or concentrated amounts or for prolonged periods .. the UV lamp will also kill bacteria and fungus without producing so much ozone.
Purifying Method: Photoplasma, UV, ions, and ozone.
Oct 09, 2010 | Biozone 500 Air Purifier
Broker wire to my O2 sensor
Try to trace the white wire that leads to the o2 sensor by unwrapping the harness that is in the vicinity of the o2 sensor. Try to fiind the wire that way. That's the way an electrical shop would do it. Resplice the wires together. You've done most of the hard work. Good luck to you. Tprev.gif next.gif --- Oxygen (O2) Sensor OPERATION All Fuel Systems Fig. 1: A standard oxygen (O2) sensor, as shown, is used in all fuel injection system covered in this manual 86734gb4.gif
Fig. 2: On non-turbocharged engines, the oxygen sensor (arrow) is mounted in the exhaust manifold 86734p07.jpg
The oxygen (O2) sensor is a device which produces an electrical voltage when exposed to the oxygen present in the exhaust gases. The sensor is mounted in the exhaust manifold or turbocharger outlet and is electrically heated internally for faster switching when the engine is running. When there is a large amount of oxygen present (lean mixture), the sensor produces a low voltage. When there is a lesser amount present (rich mixture) it produces a higher voltage. By monitoring the oxygen content and converting it to electrical voltage, the sensor acts as a rich-lean switch. The voltage is transmitted to the engine controller which changes the fuel injector's pulse width. The injector changes the mixture.
Jul 05, 2010 | 1990 Dodge Shadow
Where exactly is the front O2 sensor on a 1999 S70?
For 1998 Volvo V70 2.4L MFI DOHC 5cyl the Oxygen Sensor is located under vehicle, center, below front seating area, mounted in top of exhaust pipe.
The oxygen sensor produces a voltage within 0 and 1 volt. When there is a large amount of oxygen present (lean mixture), the sensor produces a low voltage (less than 0.4v). When there is a lesser amount present (rich mixture) it produces a higher voltage (0.6-1.0v).The stoichiometric or correct fuel to air ratio will read between 0.4 and 0.6v. By monitoring the oxygen content and converting it to electrical voltage, the sensor acts as a rich-lean switch. The voltage is transmitted to the engine controller. The controller signals the power module to trigger the fuel injector.
Hope this helped (remmeber comment and rated this).
Apr 06, 2010 | 1998 Volvo V70
Ozone smell
When the unit is clean it will produce more ozone. If the unit is a bit oversized then it becomes worse. As an installer I have to be carefull to not oversize these units. O3 is harmless and actually will only stay in the air as O3 for about 1/2 hour. Because of this it will not build up in the air. O3 also in a powerful disinfectant and will help kill mold and bacteria in the air. As soon as the filter gets a little bit of dust on it the O3 production will become much less. Run your fan continuously for a day or so and it will go away.
Nov 15, 2009 | Honeywell Enviracaire Elite F300E-1019 Air...
XL-15S, NO OZONE
Hello fleamrk,
Several possiblities here. Not static sound means the plasma discharge plates aren't energized.
1) Missing, cracked or defective discharge plate (you say you cleaned the filter - did you mean the lint screen in back, or the glass or white ceramic plate inside)? No plate, no ozone (O3) production.
2) Bad connection in the high voltage leads*.
3) Bad electrical components*.
*I'm not an electrician, and recommend that only qualified personnel troubleshoot high voltage electronic, both for safety, and for preventing further damage to circuitry. Visible problems, such as corroded or broken terminals that can be swapped when it's de-energized (unplugged) is one thing; having to dig deeper into the electronics is something that I expect to rapidly end up costing more than it's worth.
Sep 29, 2008 | Ecoquest Living Air Classic Air Purifier
I wish there was a manual for repairing these expensive air cleaners. i would gladly buy one at toddyo@zoominternet.net
Hi Todd,
Here's the owners manual; I don't think they ever produced a _repair_ manual for outside consumption. They want you to buy new hardware, not make what you've got last forever. 5-10 years, fine, but not forever.
http://www.ecoquestintl.com/support/US50300_Living_Air_Owners_Manual.pdf
Beyond that, there are several things that can cause the ozone (O3) production to stop.
1) Missing or damaged plasma discharge plates.
2) Safety cut-out switch not engaged by lint screen.
3) Damaged high-voltage wiring.
4) Damaged high-voltage controls or electronics.
I'd need more details to go beyond this. Let me know.
Jon
Aug 07, 2008 | Ecoquest Living Air Classic Air Purifier
When ionizer is on even
Hi willy,
The ionizer itself shouldn't smell. I wonder if you're smelling O3 (aka ozone or activated oxygen), or if there's a short-circuit of some kind that is causing electrical components to overheat/burn. Burning electronics and singed hair smell more alike than ozone (which isn't the same as ionization, incidentally.
Write back with more details if you can, preferably with any details about your observations.
If I can be of further assistance, let me know. If this solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Jan 17, 2008 | Ecoquest Flair Air Purifier
XL15
The ozone plates need to be cleaned monthly to work effectively. You can get an owner's manual for free from the manufacturer's website, it's at:
The manual has a description of the type and frequency of cleaning of various parts of your air purifier. Hope this helps!
Oct 29, 2007 | Alpine Air XL-15 Air Purifier
Computers & Internet Logo
286 people viewed this question
David Payne
David Payne
