Question about Nokia E63 Cell Phone
When saving data in calender it shows "system error". what should i do?
    Sergeant:
  • 237 Answers
A hard reset (which wipes the memory) should fix it:
type *#7780# to Hard Reset
CommCentral
Posted on Aug 30, 2010
What does error CE-36329-3 indicate on a frozen PS4?
per Sony's site :
Here are a few ways to deal with the error message:
Option 1 (Update system software and application data): Close the application, install the latest system software and game update, and restart the system.
Option 2 (PS Camera Compatibility): If a PS Camera is connected to the system, remove it and reboot the system, then go to [Settings] > [User] > [Login Settings] and turn "Enable Face Recognition" OFF.
Step 3 (Save Data Issues): If the error occurs again, back up your saved data, and then go to [Settings] > [Initialization] and choose [Initialize PS4]. If it continues after initialization, check to see if you have save data in online storage. If you suspect incorrect save data in online storage, remove the affected save from system and online storage.
Things to remember:
  1. Check to see if this error occurs with multiple titles. If not, you may be dealing with a game or app specific crash that may be helped by re-patching/re-downloading.
  2. If you suspect issues due to your local network, try using a wired connection and/or checking your network settings results http://manuals.playstation.net/document/en/ps4/settings/nw_test.html
  3. Periodically back up saves to USB and/or online storage if you have Save Data concerns.
Oct 11, 2015 | Video Game Consoles & Games
Tip
How to fix No Bootable Media Error Message
FAT (File Allocation Table) is one of the most widely used file systems used now-a-days with various versions of Windows operating systems and memory cards. Every logical partition contains a FAT that consists of file allocation information and the information of free allocation units that need to be assigned to files. Although the FAT file system is reliable, corruption still occurs due to various reasons. In such situations of FAT corruption, your system becomes unbootable, resulting into inaccessibility of data saved in FAT based hard drive. To access the data after FAT file system damage, an easy way is to restore the data from an updated backup. But, with inaccessibility of data backup or backup falling short to restore the required data, an ideal option left is to use an advanced FAT Data Recoveryapplication that can recover the lost data.
To illustrate the above scenario, consider a practical case the below error message pops up when you attempt to boot your system:
“No Bootable Media”
As the above error message appears at the time of booting the system, you wont be able to access the data saved in the hard drive.
Cause:
The above error message because the FAT file system has been corrupted. Few main causes for file system damage are improper system shutdown, human errors, and virus attack.
Resolution:
To isolate the above error message and to access the data after the above error message appears, you will need to follow the below steps:
Run CHKDSK utility to repair the FAT file system. If the problem persists, format the hard drive.
While the latter resolution resolves the above error message completely, it also deletes the data saved on your hard drive. In such cases, if the backup is not available, then you can only recover your formatted data by using an advanced third-party FAT Data Recovery software.
A FAT Partition Recovery utility thoroughly scans a FAT based hard drive and recovers almost all data, even after formatting. The data recovery utility can be downloaded from the Internet.
Stellar Phoenix Windows Data Recovery is an efficient FAT Partition Recovery tool that recover lost, deleted, and formatted data from both FAT (FAT12, FAT16, FAT32, VFAT) and NTFS (NTFS, and NTFS5 ) based hard drives. The detailed help manual attached with the tool allows even a new user to perform recovery easily without any technical knowledge. It supports Windows 7, Vista, XP, 2003, and 2000.
on Jun 30, 2010 | Computers & Internet
Message keeps popping up....
Frequently, this happens do to a problem with your contacts or calender. It's a problem with syncing those items with your Google account or PC. If the problem is with one of these, you should try to manually synch the calender and contacts. (Go to Settings > Accounts & Sync > (Go to Gmail account). You'll see the option to sync the Calender, Contacts and Gmail. Select each one to manually attempt to sync the files. Determine which item is providing the error; you will need to clear the data from the problem application. (Note: back up your contacts first. Use the People > Menu > Import/Export > Export to SD card option if you can.)
Next un-check the sync option for the problem app (calender or contacts) under the Google Account > Accounts. Then go to Settings > Apps > Manage Apps > All and clear the data and cache for the problem app. (The contacts may be under the Running list.) Then re-enable the sync feature. If the calender is causing the error, you may need to erase and re-create your recurring item.
For some scrolling down to the Google Frameworks service in the Manage App > Downloads (or Running) menu then clearing that data. Then chose the "force stop" works to fix the problem. (However, this can put your cell phone into a factory reset state and may cause other problems.)
You will need to turn the cell phone off and back on before re-enabling the sync.
I hope this helps.
Jan 09, 2014 | Samsung Galaxy GT-S5570
My Nokia E63 calender entries was working till a week ago. Now it says Systems error and does not save any entries. I have tried putting off & restarting. What do I do?
May be your Phone Software is got corrupted so please visit your nearest nokia care (nokia service center. They will update your Mobile Software & renew it ok.
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up //
Jun 17, 2011 | Cell Phones
R 4 card installed nintendo on message reads system data error please check NDS system data
this happened to me. all you have to do is take the card out, go to options, click on the calender and set it back about a year. thats what i did and i fixed it.
it'll work for you too
Apr 16, 2010 | Nintendo DS Lite
When loading a game an error comes up "saved data appears to be damaged" then we hit "ok" and error "unable to save data if you continue without loading" apperars. Any ideas how to clear this
I would go into the system settings and move the saved game data to a memory card if possible. Otherwise delete it. Basically you are moving it so it can force it to make a brand new save file that is not damaged.
Jul 30, 2009 | Microsoft Xbox 360 Console
On my Dash, when I synch, I want the dash to be master, not PC
hi.my phone is bestel D5000.my messages in box always empty.plese help me.and tel me how can format and reinstall my phone data(software).give ne best help.
Feb 02, 2009 | T-Mobile Dash Smartphone
Cannot sync with my computer
start ,control panel,performance and maintenance,system,hardware,device manager...hope it working for you
Feb 16, 2008 | LG Prada KE850 Cellular Phone
I lost my calender during a Hotsync.
Hi mikeand,
you could check the calendar on your computer using Palm Desktop application. You could restore the data to handheld only if the Palm Desktop show the data you need.
Nov 08, 2007 | Palm Treo 650 Handheld
Nokia E63 Cell Phone Logo
96 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
