Question about Sony PlayStation Portable (PSP) Console
Problems with the umd
When I try to put a game into the psp it will not play. I have a fully charged battery help!
  • 65 Answers
Do you have a slim or an old one?
Posted on May 11, 2008
My son psp beep when you put a game in and the umd does not come up can you help please
f you are experiencing issues when using a Universal Media Disc (UMD™) on the PSP system, try these troubleshooting options:
  • Issues with PlayStation®Store content Click here for help with content purchased from the PlayStation Store.
  • Restore Default Settings Restore Default settings will default the PSP system to its original settings. A setting change may be the reason the PSP system is having difficulties. Click here to learn how to restore default settings on the PSPgo / PSP system.
  • Confirm UMD is properly inserted
    Make sure the UMD is properly inserted with the label facing the back of the PSP system. Try removing the UMD and reinserting it.
    Please note, it is normal for the PSP system to make noises while it is reading from a UMD.
    For PSP-1001, slide the latch to open the UMD door. For the PSP-2001 and PSP-3001, simply lift the door open.
  • Try playing the UMD on a different PSP system If possible, try playing the UMD on a different PSP system. If the disc still does not function properly, it might need to be replaced. If the disc does function properly, the PSP system may need service, see PSP Service for details.
  • Try playing a different UMD on the PSP system If possible, try playing a different UMD on the PSP system. If another UMD plays, the original UMD may be the problem. If none of the UMD's play, the problem may be isolated to the PSP system.
  • Check for moisture Do not let the PSP system or any PSP® accessories come in contact with liquid. Also check for moisture condensation in the PSP system. If moisture condensation occurs, remove the disc from the PSP and do not use the PSP until the condensation has evaporated, which can take an hour or two. In general, if any part of the PSP gets wet, discontinue use until it is completely dry.
  • Check the regional code Check the regional code on the UMD™ Video. The only regional codes that the North American PSP® is tested to work properly with are "ALL" and "1.
Tried these steps and still need help?
If you have tried the troubleshooting information above, but continue to experience problems, please contact our Consumer Services department to have your PSP system serviced.
Jun 28, 2011 | Sony PlayStation Portable (PSP) Console
My umd game will not play, it shows game sharing??
open psp umd drive bay, slide the moving motor thingy to the centre, turn back on psp and put in a umd, hope this helps.
Mar 14, 2010 | Sony PlayStation Portable (PSP) Console
I can't get Valhalla Knights 2 to load on my psp
Update the system,....Alot of UMD games hang when they try to updeate from disc..If you download the update via internet and install it from the memory stick duo you should have no problem playing your game, the system will see that the firmware is up to par for the umd and will not do the system check so no lag time with loads...good luck hope this helps
Oct 11, 2009 | Marvelous Interactive Valhalla Knights for...
How do you copy games onto your memory stick on a sony psp piano black?
If you have custom firmware installed you can download umd dumper: http://www.psp-hacks.com/file/38.Just put the umddump and the umddump% in PSP,GAME and then put the umd you want to copy on your psp and on your psp go to game, memory stick and click x on umd dumper.Then when its done coping go to game, memory stick and there should be the game of the umd and you dont have to had the umd to play the game.
Mar 21, 2009 | Sony PSP (Piano Black)
My PSP Don't Read Any UMD!!
get your psp modded,i mod them in cali and its great you play games of the memory stick so no need to use the umd drive.play emulators,homebrews and back ups
Feb 03, 2009 | Sony PlayStation Portable (PSP) Console
I want to load a game to my new PSP with 1gb memory stick
  1. Slide the open latch on the top of the PSP? system. The disc cover opens.
  2. Insert the UMD? with the disc label facing the system rear. Slide the UMD? down the metal guides and press down until fully inserted. You should hear a slight click, indicating that the UMD? is held in place.
  3. Close the disc cover.
    the Latch your looking for looks like this
    "Please Rate"
Dec 19, 2008 | Sony PlayStation Portable (PSP) Console
I have problems with my umd
when i put a game it says that dic cant read so what is the problem
May 08, 2008 | Sony PlayStation Portable (PSP) Console
PSP CHARGING PROBLEMS
The way to properly break in a lithium Ion battery is to run it dead before you recharge it. Then fully recharge it and run it until it's dead again. Do this about 3-5 times and then the battery is properly broken in. If you charge it before it dies on a new battery you can build what they call a "memory" where the battery thinks it's fully charged however it's only maybe half charged and you will lose alot of life out of your battery. So make sure you properly break it in.
Feb 02, 2008 | Sony PlayStation Portable (PSP) Console
PSP won't play any games
the reason the umd wont load is because someone shut the psp off when the game was loading. so whoever did that just messed up your psp. i know cause someone did it to mine now i have to get it fixed or buy a new one. and to get the psp fixed its not guna be cheap.
Dec 25, 2007 | Sony PlayStation Portable (PSP) Console
Psp-lazer ain't reading the games
This link should help.
  • Make sure the UMD is properly inserted with the label facing the back of the PSP system. Try removing the UMD and reinserting it.
  • Try playing the UMD on a different PSP system. If the UMD plays, the original PSP system may be the problem. If the UMD does not play, the problem may be isolated to the UMD itself.
  • Try playing a different UMD on the PSP system. If another UMD plays, the original UMD may be the problem. If none of the UMD's play, the problem may be isolated to the PSP system.
  • Make sure the exposed UMD surface and plastic casing is not damaged[2]. Do not use if plastic casing is cracked, collapsed, or if foreign materials have entered inside the UMD enclosure.
Nov 10, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
24 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
