Question about HP L1706 17" LCD Monitor
My hp L1706 flat monitor display not working properly. It will be takes long time to display.
  • 11,361 Answers
Look for bad caps with leaking/bulging tops/seals in the power supply first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Aug 30, 2010
How to take off sleep mode on hpl1706
This is a link to the user guide for your monitor
HP L1706 17 inch LCD Monitor
Page 4-10 might be what you're looking for
Jul 31, 2014 | HP L1706 17" LCD Monitor
WHAT IS PRISE OF HP L1706 DISPLAY UNIT PART??
Check this price on E-bay. That's how I always do it.
If you go through HP, you will probably be paying over US$100
Oct 22, 2011 | HP L1706 17" LCD Monitor
HP L1706 vertical lines
Check that the connection from the graphics card to the monitor is good and that the graphics card itself is in working condition by testing the computer on another monitor.
If the problem persists, the issue is with the monitor and possibly a connection to the display internally which will require a competent electrician to check out
Jan 08, 2011 | HP L1706 17" LCD Monitor
Monitor is changing color when power on:- red, green, yellow, violet, white, blue etc......repeating continuously ...... more tha ten times switch off monitor but the problem remain the same... VGA...
1706,
the monitor is bad if OSD , menu shows bad colors
try the reset in the OSD menus,,
google, HP L1706 manual, read it.?
some newer hp monitors even have test pattern in the OSD pages. (on screen display) try that.
Oct 04, 2017 | HP L1706 17" LCD Monitor
How to check the backlight life of my hp l1706
Claimed life for the lamp is 50,000 Hours, but in real life, no way to tell. You can look here what is failed in the backlight lamps, it can be from worn out (blacken ends is one sign of bad lamps, same as home fluorescent lamp), poor soldering works on the lamps. see pictures here: http://s807.photobucket.com/home/budm/allalbums
What is the problem with your monitor anyway?
Mar 30, 2010 | HP L1706 17" LCD Monitor
How do you take off the mounting on a HP L1706 monitor? They are three screws took two off but the third behind the mount is the problem... Does it come apart or has anybody been successful taking it off?
Insert a small flat tip screwdriver about two inches from the top section of the mount. About an inch from either side is the clips holding it into place, be careful not to break the two in the back. If you lean it back toward the monitor as the front clips are loosened, it should just pop out.
Jun 08, 2009 | HP L1706 17" LCD Monitor
HP L1706- screen is blank when I switch on
First if you have a extra monitor try to plug it in and see if it works. If not then check your video card. or get into the computer and try and remove and reseat the memory. Sometimes by just doing that can solve the problems
Feb 06, 2009 | HP L1706 17" LCD Monitor
HP L1706 17" LCD Monitor Logo
85 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
