Question about ASUS M4A77TD Motherboard
Hi i have a m4a77td pro motherboard with amd phenom quad core 810 cpu running a 9600 gt with win 7 32bit on 4gb of drr3 1333 clockspeed 9,9,9,24 im receiving problems while gaming the game might pause or go funny and i have to ctrl alt delete and go back into the game to fix it, i used to get a continuous sound loop like electricity and a instant reset no bluescreen this has stopped but it stil lfreezes in games requiring the ctrl alt delete method to refresh it/ unstick it, occasionally get a memory management bluescreen . i have updated the bios to latest drivers done fresh installs of win7 and kept it bare minimal and it leads me to beleive its a hardware issue can anyoen help me plz?
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 210 Answers
My first "guess" is memory timing. Are all your memory sticks the same size and speed? If that''s good, then you may want to play with the timing and speed. Slow it down a bit. For gaming, I would prefer 8Gb for a larger swap file. Hope this helps.
Posted on Mar 30, 2017
5 Suggested Answers
  • 69 Answers
SOURCE: hang up during playing games even the games has lower requirements.
it might be a prob with your OS. It is best to reinstall windows
If u have a AGP motherboard then its quite old technology i recommend get a new computer
Posted on Oct 07, 2008
jecboys
  • 35 Answers
SOURCE: with asus m4a785-m motherboard and amd phenom x4
Hmm, I've never seen a computer give a CPU fan error. Maybe if the fan is really dusty it's clogging it up, try getting some canned air and spraying it out.
Posted on Dec 17, 2010
shijin007
  • 64 Answers
SOURCE: Hi. I get a blue
Dear mariolama
It can be due to error in any newly installed hardware or software.
Most probably due to RAM. Check your RAM is perfect or not in other system. Or clean it and restart the system and check.
Reply me the status
Thank you for using FIXYA
Posted on Mar 14, 2011
  • 11 Answers
SOURCE: Hi.I have a ASUS M2N68-AM
What bios are you using? Usually that error message can be disregarded since you can manually set the CPU clock, voltage, etc in the bios and it should work. Also, this might mean that the bios currently loaded is corrupted/broke. But since you did update the bios, to what version?
Also, are you using the integrated graphics for gaming? If so, that would not suffice for heavy gaming at high resolution. You should be using a dedicated video card for that.
As for system performance, how slow is it? What is your OS as well? can you try to download cpuid, and see if your processor is detected properly in windows.
Posted on Apr 27, 2011
Can you tell me if AMD Phenom X4 9550 95W works with motherboard ASUS M2V-MX? Or if just that motherboard support quadcore CPU?
go to Asus web site and get the pecs for the board. it should tell you what processors will work with the board.
Feb 27, 2015 | AMD Phenom X4 9550, 2.2 GHz...
Need bios update for amd dual core 3.2 or phenom 9600
Hello here is the homepage:
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=498#cpu
Only the cpu on the list, will fit the mainboard.
Others will be not be compatible with the mainboard, and a bios upgrade will not help with that.
Good luck
Feb 07, 2013 | Biostar N68S+ Motherboard w AMD Phenom X3...
Phenom x4 9550
you don't need drivers for a cpu...
Dec 17, 2012 | MSI 785GME51 Motherboard AMD Phenom X4...
With asus m4a785-m motherboard and amd phenom x4 9600b quad core cpu why does monitor displays a cpu fan error when fan is running full speed.
Dec 17, 2010 | ASUS M4A785M Motherboard
I installed a AMD Phenom(tm) 9950 Quad-Core Processor which runs at a speed of 2.6 ghz but windows xp pro is only reading it at 1.3 ghz. I also have 4 gigs of ram but windows xp is only reading 2.75. The...
There seems to be some sort of incompatibility issue between your motherboard and the Phenom, or maybe some option is not enabled in the motherboard bios that windows is only sensing half of the GHz, like if the processor is only running 2 cores instead of 4.
About the memory diference, that same problem is because the 64bit difference. Unless you have a 64bit XP you won't see the full 4GB. Windows XP is limited to 3 or 3.5GB of ram it can use, you are showing 2.75 maybe because some video board is integrated in your motherboard and it may be borrowing an extra 0.25GB from the 3GB that are usable under windows XP 32bit OS.
Please comment what motherboard you have, since the cpu alone can't be blamed nor configured.
Jan 03, 2009 | AMD Phenom X4 9750 Quad Core Processor...
Setting multi processors AMD Phenom X4 9550 on ECS A 780 GM-A
The Motherboard should automatically detect the type of CPU. Mine did. I started off with a dual core and went to a quad and did nothing. After replacing with the new quad core the CPU was automaticaaly recognized at start up and it required me to do nothing.
Sep 07, 2008 | EliteGroup ECS A780GM-A Motherboard - AMD...
No Output to monitor, no beeps, fans all OK
Hi karanda,
The green led on the board shows green letting you know there is power to the borad.
Does your GFX card have dual outputs? Try plugging into the other output.
If your monitor light goes from green to amber than your PCI-E is not putting out signal. Pull & re-seat video card.
Did you check Asus to see if your CPU is supported & check what bios version you may need to run CPU?
Chcek here: Check what your M2M-E supports.
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us
Your board only supports these two CPU's
Phenom 9500 (HD9500WCJ4BGD),2.2GHz,95W,SocketAM2+,Quad-Core
Phenom 9600 (HD9600WCJ4BGD),2.3GHz,95W,SocketAM2+,Quad-Core
You need Bios version 0802 in order to run the above CPU's.
Good Luck & kind regards!
Mar 10, 2008 | ASUS M2N-E Motherboard
THE AMD PHENOM 9600 QUAD
off course is compatible.
see this page
http://products.amd.com/en-us/RecommendedMBFilter.aspx
if you see for asus there is only 4 motherboards compatible and the last is the motherboards that you propose.
Sergio
Feb 29, 2008 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
ASUS M4A77TD Motherboard Logo
106 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
