Question about Zanussi Washing Machines
Zanuzzi Jetsystem XC6 not draining fault E20 coming up on screen
  • 2,272 Answers
This particular code is used when the machine detects a pump problem or water draining problem (failure to properly pump all the water off in the designated time). It turns out to be a blocked filter, accessible from the bottom front of the machine.Get the filter and drain pump checked.Any of the one is checked to be faulty.But if both checks out ok then its faulty control panel board.There is a short and this is causing the problem. You can get required parts from www.repairclinic.com
Thanks. Keepupdated for any more query. You can rate this solution and show yourappreciation.
Posted on Aug 30, 2010
My Zanussi Jetsystem Timeline washer/dryer starts its wash cycle, but when it comes to draining, it wont drain and flashes E20.
Have you taken the filter out at the front of the washer and cleaned it. Mine wouldn't drain but once I did that it worked ok.
Mar 04, 2011 | Zanussi ZWD1680W Front Load Washer / Dryer
Washing machine keeps stopping
E20 not draining error. Since you checked filter at bottom right corner for blockages, then maybe the drain pump has gone faulty or something jammed in it. You can also check the drain hose for kinks or blockages. You can try blowing out any cloggs in the machine with an air compressor.
Please let me know if you need any further help, otherwise good luck on fixing your problem.
Apr 13, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
I put on a load of washing and it stops half way through the machine flashes E20 n just stops the machine is a zanussi jetsystem zjd12191
Error code E20 relates to the pump/filter blocked.Drain the water either manually through the filter or drain hose.Check that filter is clean and pump can turn by hand.
Hope this helps.
May 19, 2010 | Zanussi FJS1225W Front Load Washer
Error code E20 on Zanuzzi washing machine. Not draining/washing.
Simple in most cases its just the filter outlet has becopme full of day to day junk, debris and slime.
Slowly release the water by turning the handle to release the water. Ensure power is off.
Once water has been drained into a shallow tray you will be able to open the door.
Once the drum is empty, unscrew the handle completely to remove filter housing an clean out thoroughly.
replace and tighten up.
Turn on power and reset all programmes.
this should work, total cost about 15 minutes of your time.
If it doesnt work it may then be your pump, time to think about and engineer
Nov 29, 2009 | Washing Machines
Error code E20 comes on during a wash cycle. i
If the filter is clean and the hoses are free of obstructions,you will need to replace the pump
Oct 18, 2009 | Washing Machines
I have a zanussi jetsystem iz16s and it keeps pausing just after its filled up with water and coming up e20 (I think thats the error code) any ideas what the problem might be.
Sep 11, 2008 | Zanussi FJS1225W Front Load Washer
Zanusssi jetsystem turbodry 1200
clean out filter, door bottom right, unscrew filter and clean it
Aug 02, 2008 | Zanussi IZ161S Front Load Washer
pull the machine out and put the drain hose into a bowl to empty the water out when you have emptied it try cleaning the pump filter and check the drain system for blockages if that is ok then it looks very much like your door interlock is duff good luck and rate me.....
Feb 17, 2008 | Washing Machines
Washing Machines Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
