Fitting insructions for electrolux 1300 blizzard air condnitioner to motor home
4 Suggested Answers
  • 400 Answers
SOURCE: Not cold enough
An air con unit of any make should never need to be regassed if initially installed correctly. If it needs regassing, there must be a leak. You would have to find the leak and repair it before regassing, or it would be the same as pumping a tyre with a slow puncture. Generally most simplex systems use around 750 to 800grams.
Posted on May 14, 2009
SOURCE: My caravan electrolux blizzard 1500 air
I have a unit for sale
Posted on Aug 29, 2009
amerigan
My caravan Electrolux Blizzard SA101 split air conditioner cools via compressor and heats via 1.5KW metal sheathed electric element. The element is similar to the coil on electric stove. It had 43mA leakage to earth enough to trip my RCD/safety switch. I pull the orange wire connector off the front panel heat switch and now the RCD does not trip out. If I am cold I will use a fan heater, it works better being at floor level and is quiieter.
Posted on Nov 22, 2013
Where do I get Electrolux motor in south Africa?
A local rewind or motor repair might prove more convenient and perhaps cheaper but Electrolux service is available in South Africa
Electrolux South Africa ' Home Appliances and Household Appliances
www.electrolux.co.za/
Welcome to Electrolux South Africa. Discover our range of ... Enter your postcode, town or city to find your nearest authorised dealer. Translation missing for ...
May 03, 2016 | Electrolux Vacuums
SOURCE: E50 what does it mean, Hello & Welcome to FixYa E50 in your Electrolux is a motor error and is displayed due to a bad motor or a bad motor capacitor. Check if the motor brushes are ok
Hello Baldur Thor, thanks for your inquiry!
From what you have described your Electrolux air conditioner is displaying an "E50" error code. I do not show an "E50" has a valid error code. Could you please verify which appliance you are having issues with? Additionally, you could perform a reset on your air conditioner which is disconnecting the power from it for ten minutes. If you continue to have issues please reconnect. -Matt
Dec 21, 2014 | Electrolux Heating & Cooling
99 camry rear driver side window came off track.sounds like motor still working.how hard to repair or costly to have done.
The regulator wires have broken.This is a do it yourself job if you are handy in the garage. You can buy the window regulator with or without electric motor. Your dealer is more expensive but will give you the right one. E-bay is cheaper but if it does not fit then what? Figure 1 to 1 1/2 hours if it is your first time. I highly recommend the Haynes automotive manuals. They are indespensable for the home repairman. They cover most foreign and domestic autos and trucks. They will have step by step insructions with photos for your job.
Jul 16, 2011 | 1999 Toyota Camry
Have a R-22 Rudd ait handler. Replaced the compressor with a 1.5 ton Goodman unit. My home is 1300 SF in NJ On hot days during the peak of the day the system seems to stop working for a period. The...
If your home is 1300 square feet 1.5 tons is not going to cut it you should have at least 2.5 ton A/C unit. sounds like your system is to small. let me know if this helps you out.
May 12, 2011 | Ruud UAKA037 Air Conditioner
I have a loud noise coming from the motor. Electrolux Epic 6500 sr Vacuum I have a loud noise coming from the motor. It smells like it is overheating. How do I open the canister to see the motor?
With the smell and the noise, it's likely the motor is shot. Unless it's seen heavy use, this is unusual for an Electrolux of this age. Or it could have been used to vacuum sheetrock dust, glass, or even liquids, possibly without your knowledge. Or "made to fit" bags were used, allowing more dust to get inside the canister and into the motor.
Unless other parts/accessories need replaced, it's much cheaper to have the motor replaced than to buy a new vacuum.
I recommend taking it to the nearest Aerus Electrolux store for a definite diagnosis (should be free), cleaning, and repair if needed. The technician will also let you know what other problems there are.
If you leave it for repairs, make sure you are given a copy of the work order for the vacuum that includes: type and model of vacuum, serial number, accessories left, your name and address, and an estimate. You'll need this to get your vacuum back. It's a good idea to also have this information written down at home.
Apr 17, 2011 | Electrolux Epic 6500 Vacuum
Tell me Electrolux spit Air conditioner fan part name its fit of out side of room window.
It is condenser fan. The motor has all info stamped on it.<br /> Call <a href="http://www.marcone.com">www.marcone.com</a> with your mod number<br /> <br /> If this was helpful please rate me.<br />Leo Ponder Appliance-Tyler,Texas<br /><a href="mailto:imufo2@sbcglobal.net">imufo2@sbcglobal.net</a>
Aug 26, 2010 | Electrolux E23CS75SS Air Conditioner
Not cold enough
May 09, 2009 | Heating & Cooling
Dometic Blizzard 1300 roof top unit blowing fuses
YES< this is a "direct ground and either the motor or compresso is grounded--(DEAD)!and needs to be replaced.
Sep 09, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
182 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
