Question about Canon ZR900 Mini DV Camcorder
When put in a new tape it sound like something is off track what do i need to do to get working?
  • Canon Master
  • 17,129 Answers
Perrhaps the pinch roller is chewing up the tape and is guiding it down.Look for possible dirt on the drum. the tracks or the roller. Also check for free movement of the idle rollers and action of the take up spool. Make sure that the tape is of good quality.
Posted on Aug 30, 2010
Chat room
If he had it done by a person who knows what he is doing he most likely used a 1/2 track tape recording device. These are different than 1/4 track unit as they are used professionally an for mastering. You would need to find a 1/2 track type deck to play the tape back- they are made by Tascam, Otari, Studer, Pioneer, Sony and other lesser brands.
Feb 02, 2014 | Audio Players & Recorders
Hi On my Pansonic DMR-EZ49V, I get distortion along the bottom of the screen when playing back vhs tapes that have been recorded on an older machine, I have adjusted the tracking but it has made no...
This is a real bad problem to solve. Unless your new video has been set up badly, there's little you can do. You see it's like this either your old machine was set up badly or your new one was! To get your new one to play back the old ones would require the aligniment to be reset to the old machine settings. However when you put a new machine previous recording in - that would now badly track. A new recording (made after the adjustment) played back would be ok though.
The only way you can tell if the new machine is set up right is by putting in a commercial film video tape. If that tracks badly it has been set up wrong.
I can say this however Panasonic VCR's have a reputation of being set up well and good at tracking videos. So if it can't track the old video tape it might be well out of alignment, especially if it is not a Pansonic model.
If the old machine is still working, it would be best to play it back and re-record with the new machine.
Otherwise you would have to carry out an alignment - play back the tape and re-align back to the correct setting.
Sep 03, 2010 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Auto tracking makes no differance.pic.covered by sound bars,black border at top of tape.vcr had stood for 3 months ununsed.on inital play,snapped tape,removed cover to extract tape. new tape kept ejecting...
Sounds like the guideposts need realignment to center the tracking or something got bent in the tape jam removal, check the tape path!. Also could try a take apart cleaning of the head with a piece of paper and some alcohol.
Mar 13, 2010 | Panasonic PV-V4522 VHS VCR
8 track player moters run but it doesnt pick up the music.
Sounds like either the head is open circuit or more likely the pre-amp for the 8-track has gone. Follow the leads from the head and it should lead you to the PC board of the amp. Check for broken connections first. You should get the pre-amp to buzz by touching the terminals where the head leads join. As you are getting no sound from either channel it might be the power to the board. But if you see a single IC it might have gone. For the power option (if the channels are seperate) suspect the largest electrolytic capacitor on the pre-amp board first.
By the way if you get a buzz from both channels the head has gone.
Apr 19, 2009 | Audio Players & Recorders
Memorex MVD4544
Low FM from the video heads is a common cause of this lack of tracking.
Jul 13, 2017 | Memorex MVD4543A
VCR tape playback not good
Check your "tracking" If the tape played fine in the old machine, then tracking is the answer, provided that the new machine records good.
Jun 27, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Tracking
the video heads are probably dirty. it only takes one tape with one little spot of cola or juice or something on it to gum up the heads. a vcr cleaning tape may or may not clear it up. otherwise it needs to be cleaned by a proffessional, by hand, to clear it up.
Apr 30, 2008 | Mitsubishi HS-U447 VHS VCR
Recording problem on Sony SLV-R1000
The deck needs a good cleaning. Try using a brand new tape and run it on playback for 20 min or so. You could try using a cleaning tape, but many of them are abrasive. If this doesn't work, you need a deck re-alignment which will cost more than your set is worth.
Nov 13, 2007 | Sony SLV-R1000 S-VHS VCR
Canon ZR900 Mini DV Camcorder Logo
141 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
